Oil & Fuel Filter front end low-vis hyGard
/ Filter front end low-vis hyGard #1
bobsphotos
ME
JD 3320 Ford 641 Ford 861 Kubota L3400
I changed the front end oil in my 3320 at 137 hrs. and the oil I drained out apeared dark and cloudy. There did not appear to be any machining chips in the oil but I was able to use a magnet and get some metalic sludge. After a call to the dealer we agreed I would redrain the fresh oil after 50 more hours and check it again. Any thoughts on a good way to try to filter the oil to segregate any sludge?
/ Filter front end low-vis hyGard #3
Hey Bob,
Your thread title states you want to filter the Low Vis Hy-Gard in the front end?
If you're talking about the front axle,(I'm assumming the 3320 is the same as the 2520),it uses GL-5 gear oil, NOT hydraulic oil.
Correct me if I'm wrong about your tractor.
Greg
/ Filter front end low-vis hyGard #4
Hey Bob,
Greg
the 3000 series call for hydraulic oil in the front axle. 2000 series is gear lube.
Your front-end holds 1.3gall ; why do you want to recycle 25 Bucks
of oil on a 21 Grand base unit ?
The only reason for trying to filter the oil was to prove or disprove that there are metal prticles in the oil. After 50 hours the oil is coal black. According to my JD service manager it is clean and he will not even discuss with me why it is changing color. The picture shows 50 hour oil beside new oil.
/ Filter front end low-vis hyGard #7
Why don't you slowly pour the oil through a paint filter (inverted cone) or a coffee filter. Your going to have to do a little at a time....but that should show any metals.
/ Filter front end low-vis hyGard #8
This is 3 hours in my HST ;
http://www.tractorbynet.com/forums/...80869-problem-international-dry-shipping.html
The black is oxidation from original manufacture . This is why I
think it is foolish to believe this "many-hours from new is now OK"
for oil changes . The machines haven't changed , but these Manufacturers
are all on the up-the-anti bandwagon . It's the same with cars too .
I ignore my instincts and commonsense at my peril (expense).
I assume you've used a magnet for the ferric ; is there any brass in the
system ?
system ?
Not sure what that all means. I did use a magnet and found no iron. The service manager has agreed to send the oil out for inspection.
The next oil change will not repeat this . It's a first change
only , so don't be concerned .
That is by BIG concern. The pic that I posted WAS the second oil change. The first change was @ 137 hours and that oil was BLACK and absolutely had metal in it. I drained it @ 210 hours and it had no metal in it but as you can see in the pic, it certainly is BLACK.
/ Filter front end low-vis hyGard #12
Just a question here. Does Deere offer the option of using a low vis, 75w-90 synthetic gear lube in the front axle? Not either/or on this series? Curious.
/ Filter front end low-vis hyGard #13
...... first change was @ 137 hours( metal in it) 2nd @ 210 hours ( no metal in it) but BLACK ....
250 hours and still giving black oil in a front mech drive.
I would have honestly said the case-hardening was gone
, but with no metal whatsoever , it's peculiar indeed.
My LR3 front diff was replaced last week due to case-hardening
failure , but the black oil was full of metal too . On a tractor there
is too much noise to hear the diff.
Patterson water pump (A59230)
Patterson water...
(50) UNUSED 3'x8' CORRUGATED METAL SHEETS (A64281)
(50) UNUSED 3'x8'...
KITCHEN AID REFRIGERATOR W/DRAWER FREEZERS (A64281)
KITCHEN AID...
UNUSED WOLVERINE MAD-12-12D (A64281)
UNUSED WOLVERINE...
4'X4'X4' MANHOLE W/ COVER (A64281)
4'X4'X4' MANHOLE...
Bobcat 763 (A64126)
Bobcat 763 (A64126)
