HOME BREW SNOWBLOWER MOUNT-DRIVE
/ HOME BREW SNOWBLOWER MOUNT-DRIVE #1
vayidaho
SW Washington State
Kioti CK20H
Being somewhat disabled and not being able to turn my head around 180 degrees, I hated the thought of a new rear three point snowblower. I was not looking forward to weekly visits to my Chiropractor. I mounted a SPEECO Category 1 Quick Hitch in the bucket of the front loader, installed a hydraulic reservoir in front of the radiator, a hydraulic motor drive for the blower, and a PTO mounted hydraulic pump. I can blow snow looking forward and have height control using the loader controls. As it is only September 2010, I wont be able to test it until December. Requests for pictures should be sent to vayidaho@gmail.com. Will respond when tested and approved. Blowing snow in the panhandle of Idaho south of SandPoint, north of Spirit Lake. Tom
/ HOME BREW SNOWBLOWER MOUNT-DRIVE #2
Would you post some pics on TBN showing your new rig?
We like pics and sounds like you have a clever design and approach.
/ HOME BREW SNOWBLOWER MOUNT-DRIVE #3
Sounds like a winner!
I've thought of doing something similar but run the blower with a hydraulic motor connected to the power beyond.
M.D.
/ HOME BREW SNOWBLOWER MOUNT-DRIVE #4
Sounds ingenious!
Love to see it.
/ HOME BREW SNOWBLOWER MOUNT-DRIVE #6
Would be good to see some pictures if you can post them. I'm a bit leary receiving email with attachments to open from someone I really don't know.
/ HOME BREW SNOWBLOWER MOUNT-DRIVE #7
Sounds like you also saved some $$ here.
A similar upgrade to mine more than doubled the cost over keeping it on the rear - about a $2000 option to mount it on the front.
Jon
/ HOME BREW SNOWBLOWER MOUNT-DRIVE #8
Not gonna be powerful enough. I went through the steps and calculations on a 10HP chipper shredder and 7gpm wasn't enough flow. The snowblower is gonna need 15+HP from the same.
/ HOME BREW SNOWBLOWER MOUNT-DRIVE #9
All i know is MI and E has done 7ft blowers off of the pto of the tractors and done well with it.
/ HOME BREW SNOWBLOWER MOUNT-DRIVE #10
Right, you're talking about a PTO pump with reservoir. I'm referring to MD talking about a hydraulic motor run from the tractor's pump. Different setups.
/ HOME BREW SNOWBLOWER MOUNT-DRIVE #11
I need some info on how to mount a snow blower to my 2004 Murray Wide Body with a 40"cut I'm thinking of using a used auger from a 2-stage reject with a blown engine . Thanks.
pgondos
/ HOME BREW SNOWBLOWER MOUNT-DRIVE #12
Why do we have to send you an email for pictures.?
Case Titan 3530 (A63688)
Case Titan 3530...
2022 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2022 CATERPILLAR...
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A63689)
Snap-On Gold Medal...
Front Tank Bracket (A64127)
Front Tank Bracket...
2007 Freightliner Semi Truck (A66285)
2007 Freightliner...
2013 FORD E-350 11 PASSENGER VAN (A65643)
2013 FORD E-350 11...
