Imagine the letter "I" in the ground with concrete around the bottom (footer)and small diameter concrete in the middle (and then larger again at the top. If you drill holes through the lower portion of the timber and run rebar through it, it will attach to the concrete and never be able to be lifted from the hole without pulling the ground around it. Around here, when inspections are required, the inspector wants to see a large diameter hole approx. 18" in diameter and 36" deep with a taper in the bottom. The bottom needs to be undisturbed soil and gravel set in the bottom for the post to sit on. I mix a little crete with the gravel, set the post, then pour crete around it. Another method is to drive galvanized pyles to bed rock and build on the flanges on top of the pyles. At a cost of about $500 per pyle, every 7 feet, it isn't cheap, but it lasts forever. Each pyle is rated to hold 20K lbs.
