rswyan
Super Star Member
- Joined
- May 12, 2004
- Messages
- 13,397
- Location
- Northeast Ohio
- Tractor
- Kubota B2910, Cub Cadet Pro Z 154S, Simplicity 18 CFC, Cub Cadet 782
You didn't say what causes you to believe there is a high water table ...... or whether the barn has a poured concrete floor or not ..... but ....I have a Menards Pole Barn. It was built in an area that seems to have a high water table. The poles are pressure treated 4x6. There is a concrete pad at the bottem of each hole and then the holes were backfilled with dirt. I think the dirt in several of the holes is constantly wet and now I have what looks like black mold on the poles near ground level.
Any ideas if this is going to be a long term issue and what I can do about it?
First thing I'd do is determine whether or not you actually do have a high water table - dig a couple of holes 3' or 4' deep around the perimeter of the barn and have a look at what's actually down there - see if they fill up.
If you find sub-surface water, then consider installing a french drain system around the perimeter of the barn. If you don't have concrete you could even install some lines inside the barn itself.
If you do not have enough elevation to get the water to flow away from the barn and drain out somewhere you may have to build a sump and then use a pump to empty the sump ...... well away from the barn.
