1510 Electrical problem
/ 1510 Electrical problem #1
209001745
Ford 1510
I have a Ford 1510 (12V system) that while I was replacing the battery, accidentally created a short across both terminals.
It appears this mishap has created a whole set of issues. I have found two known problems: first I have replaced the alternator, as the short blew out the diode bridge, and secondly have replaced the wire from the starter to the alternator, as it appeared damaged due to the short.
My problem is that it after careful examination and inspection; I still have a current draw when I connect the battery. This indicates to me that there still may be a short somewhere. Now when I disconnect the hot wire to the alternator, I have no short (but obviously the tractor will not start).
I am at wits end, and would appreciate any suggestions or perhaps a wiring diagram for the 1510.
Thanks
/ 1510 Electrical problem #2
Thanks
It is so difficult diagnose, but I suppose I eliminate one by one. I'll look at the wiring harness exposed to see if anything shows sign of burning on the electric tape they used. I hope the diagram below help you. Attached, you can find a wiring diagram from IT-F044 in ref to your tractor.
JC,
/ 1510 Electrical problem #3
My first question is do you have an external regulator.
Bill
yes, the tractor has an external voltage regulator
/ 1510 Electrical problem #5
I would have the regulator checked or replaced. If the regulator is shorted it will put voltage to the alt when it the ign is off.
Bill
2023 J&J TRAILER (A63569)
2023 J&J TRAILER...
2017 HINO 268 4X2 S/A SERVICE TRUCK (A59910)
2017 HINO 268 4X2...
2001 TRAVIS 102" X 37' DUMP TRAILER (A63290)
2001 TRAVIS 102" X...
2017 CATERPILLAR 980M WHEEL LOADER (A62129)
2017 CATERPILLAR...
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A64194)
2010 International...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7731 Miles (A63118)
2019 Cadillac XTS...
