Bucket Upgrades
/ Bucket Upgrades #1
lostcause
Maine
for years i've been meaning to do some work to the bucket on my jd770, but i never seem to get around to doing it. last sunday morning i finally took the plunge and got to it. part of the reason i never put any hooks on it was that the bucket does not have a strong enough top edge to make a solid support point, so i needed to strengthen the top edge a little too.
i don't like keeping my trailers in the driveway or on the lawn, so i often park them in the field behind the house when not needed (along with the carcasses from a couple of old project trucks), and in order to keep the grass from dying under them, i have to move them around and mow the tall grass. rather than drive a truck out back, i often just use the tractor, and wrap a chain around the bucket and lift up the tongue of the trailer. this is a rubber-band operation at best with the chain, so i decided to make it so i could put a hitch on the bucket to make it easier. obviously i'm not the first with this idea, since i came across another post a while back where someone had the same idea and already did this. mine was built from necessity and availability though - i just happened to have part of an old receiver hitch i had torched off an old 1-ton dump truck lying around.
here is what i did:
the jd770/model 70 loader bucket is pretty thin - i'd say about 11ga (1/8") steel bent into a j-shape on the top. i had a few lengths of used 1 1/4" galvanized pipe sitting around, so i used a length of that right under the top of the bucket by the front edge. it's not bend resistant, but to be honest, it's light and that tractor doesn't have a ton of lift capacity anyways, so i didn't see the sense in overkill. plus, i had dragged some of it home for free a few years ago, so cost was zero.
i just used an intermittent weld along that edge. i couldn't really get the head of the wire feed in behind it well, not to mention that i couldn't see back there anyways. i could have stuffed the stick back in there and got some strength by feel, but i decided i'd try something else later.
i flipped the bucket over and drilled several holes through the top of the bucket and plug welded it to the pipe i had put in. i might get around to grinding them down and painting over them, but don't hold your breath. i then cut the head off the old hitch and put it on a piece of 1/4" plate.
i really need to get a new vise for that thing.
rather than just put washers and nuts on the backside, i wanted a little more support to keep things from pulling through the top of the bucket, so i dug through the scrap bin and found a length of pre-drilled 1x1/4 flat from a garage door opener bracket. i cut it into two pieces then drilled and tapped the end holes.
i drilled the top of the bucket and bolted it all up.looks like it will work well. also helps that i've ended up with a pair of 6" drop drawbars from buying different used vehicles that i never had a use for until now.
/ Bucket Upgrades #2
Interesting..keep the updates coming.
/ Bucket Upgrades #3
I mounted my receiver offset so that I can see the ball when hooking up. The receiver is just to the inside of the loader arm.
/ Bucket Upgrades
back home for a couple days so i dumped out a scrap bucket and found a piece of 2x2x1/4 tube and made a drawbar with a hook.
a pass across the mill and then a couple more on the bandsaw...
add a hook and it's done.
/ Bucket Upgrades #6
Nice to have all those fancy tools!:drool: Main thing is to change what you don't like or want to improve.:) After all that is half the fun of owning a tractor and being somewhat handy.:thumbsup: Sometimes you just can't buy the tool you need and have to make it. That is how many products come into being. TBN seems to be a showcase for people sharing ideas/projects of what they did and how.
/ Bucket Upgrades #9
Its probably not a real good idea to run an end mill in a drill chuck. You do need a vise!
/ Bucket Upgrades
yeah, i know. thing is, i don't use it all that often, so i keep forgetting that i need to order a few things... like a set of collets and a vise. i bought the mill/drill used this summer for not much more than the good harbor freight (is that an oxymoron?) 20" drill press, and it came with a bunch of miscellaneous end mills - about 60 or so, not to mention a few other odds & ends.
i've checked ebay a lot for collets and vises (cheap import ones) and there are no better deals than buying them from a place like enco. i've got the free shipping code for august, now it's just a matter of getting the ambition to place an order. problem is, i always hold off, thinking there might be something else i want to add to the order, and then i forget to place it.
/ Bucket Upgrades #11
lostcause,
The 2x2 Rcvr has to be the best idea I have seen in a long time, I like it.
As you have already setup a hook there is no limit to the tools that can be used with this setup. I was thinking a Vice in the field, mounted to a 2x2 Pipe will work wonders when needed.
Great idea is all I can say, thanks.
/ Bucket Upgrades #12
lostcause,
You mean like this.
/ Bucket Upgrades #13
The original cost of a mill or lathe doesn't count. It will still cost more to tool it up than what u paid for it. I have a lot more in tooling than in my machines.
David from jax
/ Bucket Upgrades #14
Thanks for the picture of how you clamped the tubing down. I have thos but was not sure how they were used.
2014 Caterpillar CB54B Articulated Vibratory Tandem Smooth Drum Roller (A64553)
2014 Caterpillar...
2015 Nissan Leaf Hatchback (A64557)
2015 Nissan Leaf...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
JCB 3TS-8T TELESKID (A65053)
JCB 3TS-8T...
Case IH DX25E Tractor (A66408)
Case IH DX25E...
New 1.5x27 Ratchet Strap (A65579)
New 1.5x27 Ratchet...
