Foam marker for sprayers
/ Foam marker for sprayers #1
hrcarver
Gold Member
NC
jd 6120, 7200, 7700 - ford 2910, 3000, 7610, 7740 - IH 140(2), Super A - kubota m6040
I don't know how many of yall run sprayers, but here is a easy to make foam marker that I put on my little sprayer.
Saves several hundreds off commercial versions. Even if it isn't quite as durable, it works just as well. Pays for itself($35) in a very short amount of time if your spraying skills are poor as mine.
You need
1 portable gas tank
1 tubeless tire valve
1 cheapo 12v air compressor (I used this one Amazon.com: Slime COMP03 12-Volt Air Compressor with Gauge and Light (300 PSI): Automotive)
Some hose that fits over the nozzle of the gas tank, how much depends on the length of your boom.
foam marker concentrate+water
Drill a hole(small enough for the tire valve seal up, don't remember which size I used:eek: ) in the bottom of the perfectly good portable gas tank.
Insert tire valve
Attach hose to nozzle of gas tank and run your hose to the end of the boom. On the new idiot spill proof gas cans, you will have to cut off the idiot proof part.
Attach el cheapo 12v air compressor. You can cut off the 12v plug and wire directly, or install a 12v outlet on your tractor if you do not have one already.
These compressors are cheap and do not last forever, I usually can get a couple years out the one on the lil' food plot sprayer if I remember to take the compressor off and put it inside when I finish.
I use a plastic shield on the bigger sprayer I use more often(~50 acres per week), usually get three months out of it.
Put in foam marker concentrate and water and go!
This size(1.5gal) will run for over 30 minutes on a fill up(1 gal), 1-6 acres depending on the size and speed your sprayer(2.5 acres on this 10' boom at 3.5mph). 5 gallon tanks will run for over an hour easily. The tanks do better if not completely full, I usually fill to about 2/3 full. No sort of regulator, just blows into a open hose. Really not very much pressure needed at all. If I have a larger spot to do you can take a few jugs of water and foam concentrate premixed to the field.
I know its not a straight line, but you try to take pics while driving a tractor that old!:D
/ Foam marker for sprayers #2
What a great idea! I don't use my sprayer often enough to justify a foam marker, but I sure need one. Thanks for sharing. I'm going to start buying parts now!
Sod field. I have used the same setup on my 60' sprayer for years. Never took the time to take pics though.
/ Foam marker for sprayers #5
I think thats a great idea, before I build one, just to understand how it works, the compressor bubbles it up and it just overflows down the big hose?
Yup, that's it. Blows the foam out of an open hose.
/ Foam marker for sprayers #7
Thanks
/ Foam marker for sprayers #8
that looks very good the cheapies on i have ever saw was a can of shaving cream with a cable small lever and a cam that pulled the cable every rotation of the wheel.
/ Foam marker for sprayers #9
Great idea! I'm definitely going to have to try that. The shaving cream can idea is pretty cool, too.
/ Foam marker for sprayers #10
Nice job!
I played around with the same idea a couple years ago, never got it finished and put on my lawn sprayer (a little overlap = extra crispy weeds :D)
I sort of remember on my smaller-sized unit using one of those bubbler stones (porous rock kind of thing) from a fish aquarioum to generate more, smaller bubbles. I was trying to use laundry detergent rather than the real foamer solution, so maybe its a moot point for a larger system with the real marker foam stuff.
For a larger sized "bubble stone" maybe one of those sintered brass "mufflers" or whatever for compressed air systems would flow better under the higher pressure...
/ Foam marker for sprayers #11
HRcarver, does the tire valve push in from outside the tank, or does it pull through from the inside? Most valves I've seen at the tire dealer pull through from the rear of the rim and sort of snap in place when pulled through the hole. Any help or insight would be helpful. I have all the pieces except the tire valve that I want to try out tomorrow.
Thanks.
/ Foam marker for sprayers #12
Thanks.
Looks like it went in from the inside in the pictures he posted.
Aaron Z
Yes from the inside. Just some careful jiggling, and a long screwdriver to help guide it. After you get it started, you can pull it through with some pliers.
Here is a link from a different forum where some improvements were discussed.
Po boy foam marker for sprayers - QDMA Forums
Mine doesn't leak bad if you screw the top on just right, but it does leak some.
/ Foam marker for sprayers #14
bump the thread
Am building one now, almost complete. This thread and links tell all. I'm getting ready to spray and recalled this thread from some years ago, need foam marker. Ideas I am using include:
use old 5 gal fuel container
aquarium or tire pump for air supply, I'm trying both
run air hose to bottom of can thru screw top air intake
use aquarium air stones to start with micro bubbles, lead weights on stones
use dawn dishwasher soap
use o rings on spout and screw air intake to achieve air tight fit
use PVC large inverted cone with mesh covering to get large globs of foam
planning on foam blobs down center of RTV travel path
broadcast sprayer with 40 ft swath.j
/ Foam marker for sprayers #15
Oh geez...just what I need, another future modification to my FIMCO sprayer. :laughing:
Good job, and thanks to TexasJohn for reviving this thread.
2016 Dodge Charger Sedan (A61569)
2016 Dodge Charger...
Lift cylinder for model 48 john deere loader
Lift cylinder for...
8x5 Cattle Panel Gate (A64047)
8x5 Cattle Panel...
Sellick S60 Forklift (A62180)
Sellick S60...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
2020 Bobcat MT85 (A62177)
2020 Bobcat MT85...
