Backhoe 485 Backhoe removal & hook up
/ 485 Backhoe removal & hook up #1
USMC2531
Upstate New York
John Deere 4120
Hello,
Looking for advice on hooking up my 485 John Deere backhoe to my 4120.
First and foremost I love my 4120 and all it's implements. It does everything I ask it to do with no headaches EXCEPT when I try to put my 485 backhoe on.
The entire process goes quickly and smoothing exccept when I attempt to hook up the hydraulic hoses to the backhoe ! I don't know if its pressure or what the causes it, but it takes forever to get the hydriliuc hoses (two) to seat/lock in correcting.
Any advice would be greatly appreciated !
thanks,
steve
/ 485 Backhoe removal & hook up #2
I was having a heck of a time getting my 448 hoe onto my 4300 until I got used to the procedure. When I first got the hoe it took a while to hook it up from every aspect -- hoses included. Now I have it down to a science and can hook it up in about 2 minutes. Long story short, where it applies to your question is that before I unhook the lines I release the pressure in them much better than I did before. Now the hydraulic lines slide right on. Man I can remember a few times early on cussing like he11.
During hooking the loader up, I also release the pressure on the main lift cylinder and this serves two purposes. First, once the 3pt hitch locks into the hooks on the hoe and engages and lifts it if I release pressure on the main lift cylinder it drops/rotates the bottom catches on the hoe into their position on the subframe. This makes it much easier to raise everything into position, and it takes out any built up pressure in the line out and therefore makes life much easier when its time to hook up the hydraulics.
/ 485 Backhoe removal & hook up #3
Hi,
I'm not sure I'm following you 100%. The main lift cylinder? I have a 3320 and only took off and put on the 485 (448) BH once but it took me about 20 minutes and I had to use the stabilizer arms to get it in position not the 3PH.
Thanks,
Rob
/ 485 Backhoe removal & hook up #4
I've had the 485 BH on/off my 4320 several times since new about a year ago. Two things. First, when removing the hoe make sure it is resting with little/no pressure on the cylinders and the hose connections will be much easier to connect/disconnect. Second, there is an up-stop adjustment for the 3ph which when adjusted properly will enable lifting the hoe high enough to insert the two top pins w/o using the stabilizers. The up-stop adjustment has been discussed before and can be found with the search mechanism. I had to do it on my current 4320.
Edit/Add: Here is the link for adjusting 3ph up-stop http://www.tractorbynet.com/forums/...rating/170046-adjusting-3-ph-485-backhoe.html
/ 485 Backhoe removal & hook up #5
Yeah, that's how mine works using the 3ph. Once you adjust that and get the pins to slide in using that only, then take the pressure off of all the cylinders and the lines will go on much easier.
/ 485 Backhoe removal & hook up #6
After the pressure is off remember to shut down the tractor before you try to hook up the 2 hose.
/ 485 Backhoe removal & hook up #7
I read somewhere that you had to be very careful adjusting the pin because you could over extend the 3PH and do damage. So I haven't touched the adjustment.
Rob
/ 485 Backhoe removal & hook up #8
Rob
My JD dealer told me this also. He said very little adjustment is usually needed to raise the 485 far enough to insert the pins. They routinely have to do it. If memory serves me correctly, it only took about 1/4 turn to raise my 3ph to easily install/remove the pins.
/ 485 Backhoe removal & hook up #9
Thanks, I'll check it out.
Rob
Thanks for all the information ! You guys are spot on !
I forgot to mention that the 3pt was out of adjustment so I can't pick it up high enough to get the pins in so I've been trying to use the stablizer arms/etc. to get it up high enough.
Sounds like once I get it adjusted I will have no more problems.
thanks,
~S
/ 485 Backhoe removal & hook up #11
thanks,
~S
When it comes to tractors and equipment, this TBN forum is an invaluable resource for getting advice and help from others.
/ 485 Backhoe removal & hook up #12
I have a 4520 with the 485 backhoe, when new, it took forever to attach and take off. The dealer had all kinds of ideas, none of them were right and it was all because it was not set up right. After watching the Deere video on how fast and easy it was put on and remove, we took it back. I got my dealer to watch the video as well and then they went to work. After a day of making adjustments I can now connect and disconnect the 485 in about two minutes and the 485 sits on it's frame with no support. So to you that are having troubles, watch the Deere video on their web site and then make your dealer make the necessary adjustment for it really is a piece of cake and you DO NOT need any help from the 485 arms or supports to do the job.
/ 485 Backhoe removal & hook up #13
Thanks PHJ!
I never knew it was there.
Here's the link if anyone is interested:
Tractor backhoe hookup
Rob
/ 485 Backhoe removal & hook up #14
I played with installing and removing the 485 and the 3PH doesn't lift it high enough to engage the two locking pins. I see the adjustment but I've heard you can damage the 3PH if you adjust it too far so I'm reluctant to do it.
Right now I'm using the stabilizer arms to install the BH, takes me about 10 minutes to get it on this way.
I can see where pin 14 can be over extended and cause problems, also part 12 can hit the front of the housing if the adjustment is wrong.
Rob
/ 485 Backhoe removal & hook up #15
Can you send a link to the video, I was unable to find it on the deere web site. Thanks.
SET OF (20) ACE CATTLE PANELS W/CONNECTION JOINTS (A63569)
SET OF (20) ACE...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
Poly Machine & Parts (A64047)
Poly Machine &...
2008 Kubota RTV 900 4x4 Fire Rescue Diesel Utility Cart (A61572)
2008 Kubota RTV...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
Adams Nurse Trailer Tank (A63118)
Adams Nurse...
