New to me 3320
/ New to me 3320 #21
Also the bar is stronger and has holes in it for teeth. You can put another edge on it too if I remember.
Maybe you can talk to your dealer about a trade up, might be cheaper than reinforcing it. The HD bucket is 73" long, the 3320 can take it with ease. I fill it to overflowing with rocks, etc.
Rob
Yes the HD bucket is pre-drilled to accept the bolt on reversible cutting edge (the bolt on edge is worth it in my opinion; about $130.00).
The HD bucket is available in both the 61" and 73" size (bolt on cutting edge is $154.00 for the 73" if I recall; yep, I put the bolt on edges on both) if nothing else it makes the bucket that much less prone to bending. As I stated above, I have both and the 3320 handles the 73" just fine.
/ New to me 3320 #22
Nitro,
How does that bolt on edge work if you want to put a tooth bar on? Does it fit over it or do you take it off?
Thanks,
Rob
/ New to me 3320 #23
I have been told you can have either the edge OR a toothbar on at one time.
/ New to me 3320 #25
I can put the tooth bar on with the cutting edge, but I had to modify the tooth bar; I had to make slotted cut outs (in the tooth bar) for where the bolts that hold the cutting edge on were prohibiting the tooth bar from being installed.
/ New to me 3320
I dropped my bucket off at the welding shop today.....and picked up my new grapple. I'm going easy on my back.....so.....the welding shop is going to add 3" x 1/4" flat iron at the bucket sides and reinforce the top of the bucket with with a custom plate to form a channel on the underside. Then, I am adding a Markham tooth bar to the bottom edge and calling it good to go.
I'm adding weld on bucket hooks to either side at the "quick tach" bosses....and adding a 2" receiver in the center for moving trailers, etc.
Not adding a second cutting edge (with toothbar) will allow me to use my clamp-on bucket forks (Panes).....which prove handy from time to time.
With the new Markham grapple.....I betcha those forks will see limited duty. :licking::D Tommorow I get my couplers....and give this bad-boy a go. :thumbsup:
There will be pics. ;)
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2020 John Deere HPX615E Gator 4x4 Diesel Utility Cart (A61572)
2020 John Deere...
JOHN DEERE 6120M TRACTOR (A64280)
JOHN DEERE 6120M...
LMC Nitrogen Applicator (A62177)
LMC Nitrogen...
John Deere 2155 (A62177)
John Deere 2155...
CRAFTSMAN 10" RADIAL ARM SAW (A63291)
CRAFTSMAN 10"...
