Update on broken mower and bent cylinder
/ Update on broken mower and bent cylinder #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
So, my belt was indeed stretched. PT sent me a new one to the tune of $42.72
I bent my tilt, dump cylinder rod so they sent me a news one. Honestly, it looks like the pulled the entire cylinder apart and sent me the whole rod, including seals. There was pipe wrench marks on the screw in end (did not expect to see this). It cost $61.90. I got a seal kit ($19.95 for one cylinder) as well thinking that all I was getting was a rod and not the cylinder cap and piston assembly.
It was replaced easily.
The spider on the mower was indeed shot. $ 22.50 per spider.
But here is the rub. Another bad weld from PT. As I said before, there was this vibration. It turns out the arm that holds the hydaulic motor plate steady on one end, the weld was busted off (no penetration. To really fix this I should have torn it apart, but that looked to be a major nightmare. Instead i got a long welding rod, and ran a hot bead again. Marginal but it held for 8 hours of mowing today.
Carl
there was no markings on the belt (other than what is in the picture and I can't get a cross reference so far), but I have the old one and will tape measure it up. The stretch is minor, and if it wasn't for the broken motor mount I would have never noticed it.
Just FYI, Terry told me to keep the belts very loose.
I like the Spring Hollow name Ken.
/ Update on broken mower and bent cylinder #4
The belt size is B 180-- that means B cross section, length 180 inches.
If the belt has any reverse bend or small pulleys I have found that BX belts work better and last longer. They cost a bit more and often have to be special ordered.
McMasters Carr carries the B 180 for about $40 and the BX 180 for about $55.
McMaster-Carr
/ Update on broken mower and bent cylinder #6
I replaced the belt on my 48" mower with NAPA part # A105 I got at a local Auto parts store. That was in 2008 and I have not had any issues with it since.
/ Update on broken mower and bent cylinder #7
McMaster-Carr
Thanks, Bob. I just broke mine and it says B 180 on it. Found a good site that has the Gates B 180 for ~25 and the BX 180 for about $33. Because of your recommendation, I am ordering two of the BX 180.
BX Tri-Power Belts - ROYAL SUPPLY
Ken
/ Update on broken mower and bent cylinder #8
McMaster-Carr
wish I had read this a week ago. I just replaced the belt on my 1850 with a b 180 instead of a bx ...
/ Update on broken mower and bent cylinder #10
You ate your belt already? that seems quick...
there's always a story right?....so the belt kept coming off the pulleys.....so i, in my newbie wisdom, pull the belt covers off so i can better observe pully action.
"edumacation" says i to meself as i plunge downhill into a fresh batch of overgrown locust and brambles standing well over my head.
i learned that the blades indeed slow down significantly when confronted with substantial obstacles...and that (predictablly) the belt will come off if the vibrations get gnarly.....
i'll just pull down to that levelish spot over there says me.....then i hear a snap when the belt slips (unbeknownst to me) unde the tire as i slow to a stop....
2007 Yamaha Rhino 660 (A61307)
2007 Yamaha Rhino...
2014 Jeep Cherokee Sport SUV (A59231)
2014 Jeep Cherokee...
2012 INTERNATIONAL PROSTAR+ (A60736)
2012 INTERNATIONAL...
2019 Caterpillar 259D (A60462)
2019 Caterpillar...
203201 (A60429)
203201 (A60429)
Sakai SW354 (A60462)
