Battery boiling while charging; YIKES
/ Battery boiling while charging; YIKES #1
beppington
Elite Member
of my
Here
I have a one-year old Walmart 12V deep cycle battery I just charged overnight with a Sears DieHard charger I've had for over a decade. I've never felt real knowledgable about battery charging; Just connect it up overnight & hope for the best. I did read the manual but never used the charger often enough to feel like I really knew what to expect/ whether I was really doing it right.
This time the deep cycle battery started boiling :eek:
The charger has three switches:
- 6V / 12V
- "Automatic Regular" / "Automatic Deep Cycle" / "Manual"
- 2 AMP / 10 AMP / Engine Start (which is 60 amps)
Per the charger's book, I set it on 12V, Automatic Deep Cycle, & 10 AMP. And the battery boiled. When I checked the battery this morning after charging overnight, the meter display, instead of showing its green "Full Charge" light with the needle pointing to 100% charge, it showed maybe 75% charge & of course the battery was boiling.
Is it normal/ OK for a battery to boil while charging? Did I do something wrong? Could the battery already be a dud?
This is a marine deep cycle battery that was used only 2 or 3 times last year, then sat until last weekend when I charged it just for a few hours (no boiling). I figured that was good enough for then, then went to do a good, full charge last night.
Thank you ...
/ Battery boiling while charging; YIKES #2
Is the battery hot to the touch? I suspect that the 'boiling' you are seeing is just the off gassing when a battery charges. Automatic chargers can usually do a decent job of charging properly. Make sure to use distilled water if you need to add some.
BTW, one of the checks for a bad battery is with the caps off watch for bubbles in each cell. Often a bad battery will have one or more cells that do not bubble when charging.. usually means a dead cell, resulting in bad battery.
Always think safety, wear eye protection when messing around with batteries.
Good luck!
/ Battery boiling while charging; YIKES #3
Set on 10 amps the charger should have had the battery fully charged in a few hours.
It is one of two things.
1. The battery is bad. Check it with a voltmeter. If it is below 12 volts it is bad and the charger will never shut off.
2. If the battery has 13+ volts and the charger is still running then the charger is bad.
I always charge a battery overnight on 2 amps. If you are in a big hurry, use 10 amps.
/ Battery boiling while charging; YIKES #4
The battery is not really boiling. The bubbles are hydrogen and oxygen gasses coming from the H2O as the current passes through it. The reason a shorted cell does not bubble is because the positive and negative plates are touching thus no current travels through the electrolyte.
As a battery becomes closer to being fully charged, more and more bubbles come from the electrolyte. This is when the battery is more likely to explode. Ever heard of spontaneous combustion? These gas bubbles like to stay attached to the surface of the battery plates much like bubbles like to cling to the side of a bottle when shaken. This causes a problem because even hours after you have taken the charger off, it only takes a couple of the hydrogen and oxygen bubbles to get together to begin the combustion process. If you are ever looking at a battery closely when it explodes, you had better look closely because you will never see it happen again. Why? You are going to be blind. I have seen one explode from a distance. It really shook the building.
A fully charged battery will be 12.6 volts. However, if you check the voltage of a battery right after it is removed from a charger they all will read a little over 13 volts. If you place a meter on the battery at this time it, you can watch the voltage slowly come back down to 12.6 volts. I think the previous post was refering to a 3 minute charge test. In that case if the voltage is higher than 15 volts after charging at a high rate, then the plates a sulfated.
/ Battery boiling while charging; YIKES #5
First I'd make sure the battery is good. 2 sure-fire signs it's not:
1)If the sides are bulged out and hard (you can't push in on them because the plates have expanded. Lots of batteries have sides bulged out but you can usually push them in by hand.
2)f the positive terminal has 'raised' (the top of the battery is no longer flat near the positive terminal, it actually sits up a bit higher than the negative one. Sometimes you'll even see stress marks or cracks in the plastic around the pos. terminal.
Also make sure the water level is not too high/low. (should be no more than a 1/4 to 1/2 inch above the plates.) If it's low, use distilled water. Check level before and after charging.
Sometimes though a good battery can sit around dead for a while and it gets sulfated and boils at pretty low voltage. If you keep charge on it for a long time the voltage at which it 'boils' may rise and the battery might come back to life. 12.3 volts is below full charge -Put a good load on it and see how much capacity it has.
And just like Norm Abrahm says, ALWAYS wear safety glasses when working in the shop. (Especially around batteries/sulfates!) Latex gloves ain't a bad idea either.:D
/ Battery boiling while charging; YIKES #6
I have the same charger the OP has and I can charge a fully dead battery on it overnight on the 2 amp setting and in the morning it will read "fully charged".
If I set it on the 10 amp setting the battery will read "fully charged" in about 4 hours or less.
If he had the charger on 10 amps all night and it wasn't reading "fully charged" in the morning, either the charger or battery is bad, probably the battery, because if it doesn't reach a certain voltage, then the charger won't read "fully charged" and cut off.
Naturally, the battery should be full of water before charging but if it wasn't, then all the cells wouldn't be "boiling".
Very, very warm but not gonna burn your hand.
I forgot to mention in my OP that the water level is perfect-O.
This I didn't do, but can. Maybe I'll stick the charger back on it tomorrow & check it that way.[/QUOTE]
I didn't know it'd be that fast.
Just checked it: 12.85 volts
OK, I'll do that from now on. Again, just didn't realize how quick it would charge. I've always just "set it & forget it" :)
The sides are not bulged out at all, but I'll have to run out & check for softness.
Not this either. The battery's physical shape & appearance look great. It's practically brand new.
Again, the water level is perfect.
Will check it tomorrow.[/QUOTE]
/ Battery boiling while charging; YIKES #10
Why only distilled water?
/ Battery boiling while charging; YIKES #11
Tap water generally has minerals that are not needed in the battery and can shorten its life. Distilled water does not.
/ Battery boiling while charging; YIKES #12
Most of the larger size deep cycle batteries are around 105 amp hours (AH) with the smaller ones around 80.
You can't fully charge a dead 105 AH battery overnight with a 2 amp charger, or maybe even a 10 amp charger depending on how long one defines "overnight".
Simple math..
For the larger battery a 2 amp charger will take at least 52.5 hours if the battery is truly dead. In reality it takes longer since there are inefficiencies in charging..ie you may have to put back 120 amp hours, it always requires more put back in than you got out in the first place.
As for 13 volts and still charging indicating a "bad" charger....many of the microprocessor controlled chargers run the battery way above 13 volts as part of their 3 part strategy to properly charge a battery. It doesn't mean the charger is necessarily bad.
/ Battery boiling while charging; YIKES #13
If your battery was sitting a long time in a discharged state there could be serious sulfation on the plats, they will look white or white-yellow. Sulfation can be very difficult to deal with when left to harden for a long time. Can a sulfated battery be recovered? Sometimes, its 50-50, you will first need a battery charger with a de-sulfating option,
Vector VEC 1097A
I have batteries well over 15+ years in service. When new I give them a good dose of Charge-it to dissolve any sulfation and a cycle or two on a battery charger with the de-sulfating option.
BATTERY ADDITIVES - JCWhitney
http://www.batterystuff.com/tutorial_battery.html
http://www.battery-additive.com/ProperBatteryCare.html
http://ebld.net/website.mv?webuser=hsi88&website=goldenagemotorcycles&webpage=link_page17
Good luck.
/ Battery boiling while charging; YIKES #14
be careful of overcharging your battery in trying to get it charged faster.if you get it to hot you can warp the plates,shorting the cell
By choosing 10 AMP & "Automatic Deep Cycle", I was just following the book. Really didn't have any time frame in mind. If it said use 2 AMP, I'd have used that.
/ Battery boiling while charging; YIKES #16
What charging rate you choose depends on the Ampere Hour rating of the battery and how much charge needs to be put back into the battery. Vector uses a 3 step process, Bulk charge > Absorption charge > Top-off charge. :thumbsup:
/ Battery boiling while charging; YIKES #17
Yes! OP its stuck in bulk charge mode due the battery V not rising enuf as its charging ... so the charging voltage is not bucked appropriately by the batt V. This leaves the current too high for the lower current Absorption and Top off charges to kick in. Put the battery on the 2A charge overnite and check the V in the morning while still under charge. It should be 14-14.6 V or higher, and very low current if the charger has not turned off completely from detecting full charge.
larry
/ Battery boiling while charging; YIKES #18
Vector VEC 1097A
Battery Tutorial
Proper Battery Care and Maintenance of Industrial Forklift Batteries
New Life for Old Batteries!
Good luck.
Is the Vector that much better?
I've got at least 20 automotive style batteries to deal with... several years ago, I bought several Battery Tenders that have helped...
My batteries are 12v with several 6 volt and two 8 volt.
I don't mind spending the money for a good charger... the Vector at around $100 doesn't seem very expensive?
/ Battery boiling while charging; YIKES #19
Vector has many models to choose from. I have not seen any other than 12 volt models. Compare other smart chargers,
Price vs. charge current features. I have a vec1097A, it uses inverter power supply, not subject to low voltage, 2/10/30 amp charge rate, 3 battery types, 80 Amp boost/start charge, pulse de-sulfating, float/trickle charge, Diagnostics for battery and Alternator. Paid less than $100 for it three years ago.
How do I pick a Battery Charger
VECTOR BATTERY CHARGER:VECTOR VEC1097A 2-10-30 AMP BATTERY CHARGER WITH 80 AMP ENGINE START ASSIST
http://www.dewaltservicenet.com/documents/English/Instruction Manual/Vector/HSK1084HD.pdf
Vector smart charger testing
/ Battery boiling while charging; YIKES #20
Boiling, the bubbling sound anyway, is totally normal during charging. That was your question, mine boil all the time.
I do a full recharge of the RV batteries after a long outing with a car charger that has an automatic 10 amp charge setting. It takes at least one night IF the batteries are discharged. Of course it is quicker if the batteries didn't get discharged fully.
Batteries boil, the gasses are explosive. It's normal.
2023 CATERPILLAR 289D3 SKID STEER (A62129)
2023 CATERPILLAR...
2011 John Deere 1770NT Planter (A63109)
2011 John Deere...
2018 Caterpillar 308E2 CR Excavator (A61166)
2018 Caterpillar...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
Wooden Three Headed Native American Statue (A61569)
Wooden Three...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
