3-Point Hitch Lost pins in both arms.
/ Lost pins in both arms. #1
Rickstir
Hard by the Elk Fork of the Salt River, Missouri
2009 Mahindra 4110
Looking for the problem with my finishing mower leaving streaks, I verified the blades were clean and the belt tension was right on at 2 7/8 inches. Then, wow, there were no pins in the hitch arms. I can see how the mower would move side to side without those pins. Guess I will have to put those on the "pre-flight" list I use every time I use my 4110. THese are not the pins where the unit attaches. They are ones on the arms to adjust the length.
These were simple pins with "bobby-pin" type clips. I am replacing them on my way home tonight but I was wondering what others do to prevent this. I will look at wrapping some baler wire around them if it will fix it. Anyone use a nut and bolt? Is there some other kind of pin to use?
/ Lost pins in both arms. #2
I will look at my 4110 tonight to see how they are installed. Never had the problem.
/ Lost pins in both arms. #3
Are you talking about swing link pins? My 6520 had wire "key rings" holding the pins in. Mowing heavy brush would snag them and straighten them out and lose them. I replaced all of them with locking lynch pins from Tractor Supply. FYI.......my pins have factory chains to keep from losing them.
hugs, Brandi
I stopped by my dealer last night, nice that he is in the same town, and got a "D" shapped pin that clips on fairly securely. I am gong to run some wire through both ends for extra protection. I am sure it was the high weeds that got mine the first time, but like I said before I am going to visually check them during my pre-flight steps. Live and hopefully learn.
/ Lost pins in both arms. #5
My 4110 has turnbuckles with a ring and shackle on each end. Just tighten or loosen the turn buckle to adjust side motion or width of arms. No pins to adjust the side swing.
/ Lost pins in both arms. #6
Bill,
The 6520's swing links are telescopic with pins. I thought that Rickstir was talking about swing links.
hugs, Brandi
/ Lost pins in both arms. #7
My 4110 has the telescopic check linkage ...
/ Lost pins in both arms. #10
I replaced all pin keepers that are not removed for impliment changes with heavy cotter pins.
