3-Point Hitch Lost pins in both arms.
   / Lost pins in both arms. #1
Rickstir
Hard by the Elk Fork of the Salt River, Missouri
2009 Mahindra 4110
Looking for the problem with my finishing mower leaving streaks, I verified the blades were clean and the belt tension was right on at 2 7/8 inches. Then, wow, there were no pins in the hitch arms. I can see how the mower would move side to side without those pins. Guess I will have to put those on the "pre-flight" list I use every time I use my 4110. THese are not the pins where the unit attaches. They are ones on the arms to adjust the length.
These were simple pins with "bobby-pin" type clips. I am replacing them on my way home tonight but I was wondering what others do to prevent this. I will look at wrapping some baler wire around them if it will fix it. Anyone use a nut and bolt? Is there some other kind of pin to use?
   / Lost pins in both arms. #2
I will look at my 4110 tonight to see how they are installed. Never had the problem.
   / Lost pins in both arms. #3
Are you talking about swing link pins? My 6520 had wire "key rings" holding the pins in. Mowing heavy brush would snag them and straighten them out and lose them. I replaced all of them with locking lynch pins from Tractor Supply. FYI.......my pins have factory chains to keep from losing them.
hugs, Brandi
I stopped by my dealer last night, nice that he is in the same town, and got a "D" shapped pin that clips on fairly securely. I am gong to run some wire through both ends for extra protection. I am sure it was the high weeds that got mine the first time, but like I said before I am going to visually check them during my pre-flight steps. Live and hopefully learn.
   / Lost pins in both arms. #5
My 4110 has turnbuckles with a ring and shackle on each end. Just tighten or loosen the turn buckle to adjust side motion or width of arms. No pins to adjust the side swing.
   / Lost pins in both arms. #6
Bill,
The 6520's swing links are telescopic with pins. I thought that Rickstir was talking about swing links.
hugs, Brandi
   / Lost pins in both arms. #7
My 4110 has the telescopic check linkage ...
   / Lost pins in both arms. #10
I replaced all pin keepers that are not removed for impliment changes with heavy cotter pins.
International 1420 Combine (A50514)
International 1420...
91013 (A48082)
91013 (A48082)
Wolverine Quick Attach Power Rake (A50514)
Wolverine Quick...
2009 Chevrolet Cobalt Sedan (A50324)
2009 Chevrolet...
2001 STERLING WATER TRUCK (A50458)
2001 STERLING...
New Calf Hut (A50515)
