beenthere
Super Star Member
- Joined
- Aug 16, 2001
- Messages
- 18,626
- Location
- Southern Wisconsin, USA
- Tractor
- JD_4x2_Gator, JD_4300, JD_425, JD_455 AWS, added JD_455, JD_110, JD_X485(sold)
......... but I am worried about the snow when it melts off the tractor after using it this winter. have no floor drains in the garage. Instead, the floor is pitched about 1/8" per foot to drain the water to the front towards the door. The problem with this, is it will hit my door seal and pool to the sides, which will then hit the wooden base of my work bench which is simply not acceptable...
:confused2:
First, I don't think the tractor needs to be stored inside.
But the reasons you listed for not storing it inside shouldn't keep you from doing that. IMO
Put the work bench on blocks to keep any moisture from contacting the wood base. And minimal effort clearing some melted snow/water from the tractor will (should) keep the door from freezing down and water pooling. I wash my car in the garage in the winter, and some of the water pools against the garage door rubber astragal and doesn't present a problem.
And very little salt will take care of it if it does.
