Pallet Forks?
/ Pallet Forks? #1
robertwhite
Posted in the general forums, but then I figured someone here will know for sure..........
Will this set of John Deere pallet forks with whatever type of QA it has work with my Bobcat CT335 QA plate and lock on?
Seller says it will work with skid steer and I believe the CT335 uses the same plate as the skid steer.
/ Pallet Forks? #2
It is not obvious to me that those forks are skid steer QA.
I would have to see a picture of the back of the forks to be certain, by my SS QA forks have holes in bottom back bar for the QA pins to lock into.
/ Pallet Forks? #3
thyey do not appear to be QA forks from the front, but who knows.....
:confused::confused2:
/ Pallet Forks? #4
Not sure it they are QA or not but they definatally look like they were made for a SS given the step on both sides.
/ Pallet Forks?
I'm working on getting a backside photo.
/ Pallet Forks? #6
how much do they want for them?
/ Pallet Forks? #7
That really looks a regular skid steer fork with side step and will work with your CT335... but will be certain if you can have the back picture taken and post here as others already said.
/ Pallet Forks?
Asking is $375 complete. I figure I could get at least $50 knocked off.
At $300-325, if would be a good price, no?
I talked to the guy today and he said the mount has the hook plate at the top and the hole for the QA pins at the bottom just like a BC quick mount needs. I will have to take a ride up and check them out for myself.
/ Pallet Forks? #9
I just paid $450 for brand new Bobcat Bobtach forks, but I did have a $250 off coupon
/ Pallet Forks? #12
That is about right with the coupon. I was quoted $700 by local Bobcat dealer here in NJ. I bought mine on line for $400 but it was only 36" but is good enough for my use and 48" will be too long for me. The one on the picture appears to be a 48". If you can get it for that price, grab it and run.... :D
/ Pallet Forks?
Got 'em!
It is actually a John Deere "Deere Pro" set of pallet forks (48 inch) w/mount.
The grille guard was bent (as you can see in the photo), but some heat from oxy/mapp in the correct places, a few blows from a sledge, and it straightened right out.
The bottom slot in the mount needed to be opened up slightly with a grinder as the QA pins didn't quite fit through and its good as new.
Forks are fully adjustable for width too.
JD sells it for $850 and I was able to pick it up for just $325. :thumbsup:
/ Pallet Forks? #14
Got 'em!
That is sort of shameful putting a deere attachment on a Cat
:laughing::D
TAKEUCHI TL230 SERIES 2 SKID STEER (A64279)
TAKEUCHI TL230...
2019 CATERPILLAR CP54B PADFOOT ROLLER (A62129)
2019 CATERPILLAR...
2020 GMC AT4 CREW CAB TRUCK (A60430)
2020 GMC AT4 CREW...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
1947 Chevrolet Panel (A62613)
1947 Chevrolet...
