backhoe remove and install times
/ backhoe remove and install times #1
gilraine
eastern CT
none yet
About how long does it take to attach and remove a subframe mounted backhoe from the tractor. I'm looking at a zetor C47l with loader and backhoe. Its got 410 hours and they are asking 16500. do you have to remove the large attaching bracket to use the 3 point hitch.
/ backhoe remove and install times #2
Sorry, no experience with that model. Some are very quick, just a couple minutes. Some (like mine) are a long slow process!
Have the seller drop the hoe, attach a 3pt implement and then put the the hoe back on.
/ backhoe remove and install times #3
On a good day I can drop my JD hoe (4300 HST tractor) in about 2 minutes, then spend 30 minutes installing the 3pth linkage (with weight bar).
Dropping the 3pth stuff, then hooking on the hoe takes about 5 minutes total if I do it right and the hoe is on level ground (rare in my yard)
/ backhoe remove and install times #4
As stated before, it really depends on the tractor model. My NH doesn't require you to remove the 3PH equipment. Detaching takes 5 minutes or less and I'm ready to go. I built a dolly that allows me to roll the BH around and the job I do of aligning the tractor and BH dictates how quickly I can re-attach. But around 10 minutes.
Good luck,
/ backhoe remove and install times #5
I have an L3400 and Woods BH80-X backhoe. The problem is that I have to remove the 3 point arms to attach the hoe... that is what takes the time... I would estimate about 30 min. to remove the 3 pt. and then about 5-10 min to install the hoe and pto pump. When you want to go back to 3 pt. implements you need to spend an equal amount of time to get there. I do know that I would be using my hoe a lot more if I could hook it up without having to deal with the 3 pt. linkage.
/ backhoe remove and install times #6
If I lower my B3030 arms and let them swing to the center position, they slip right inside and underneath the BH80-X frame. I don't have to remove anything... even with the telescoping ends (I never keep the top link on anyway). See pic below.
Have you ever actually tried this? Not sure why it would be any different on your L.
Also, curious why you have the PTO pump... your tractor hydraulics are more than adequate to run the BH, in which case the PTO pump is way more trouble than what it's worth.
/ backhoe remove and install times #7
It sounds like your backhoe is plumbed to the tractor's hydraulic system. What happens if you were to move the 3-pt position control lever while having the BH attached? Is the lever's hydraulic flow neutralized while the BH is attached or is it a best practice not to touch the lever because it too is alive?
/ backhoe remove and install times #8
The 3PH is the last thing in the loop and the pressure relief is ahead of it.
So, what would happen is the arms would stall on the frame and the PR valve would go into relief and squeal at me until I lowered it. Just as if I attempted to lift something beyond 3PH capacity.
Can't say I've ever accidentally done this though, but that's exactly what should happen. :thumbsup:
/ backhoe remove and install times #9
There are basically two types of subframe mounted BH's... most of the responses you have gotten have been concerning a more modern 4-point quick-mount setup, where the subframe stays on the tractor at all times, and the BH detaches from it. Typically the subframe itself is made to work with other tractor attachments and doesn't interfere with anything.
The older style is where the entire BH and subframe is one assembly and is removed/installed together. Since the subframe runs the whole length of the tractor, these are notorious for being difficult and time-consuming to install, and having two people really helps to get everything lined up.
It wasn't 100% clear from your question which you were referring to, or if you're not sure yourself, it might be worth inquiring of the seller.
/ backhoe remove and install times #10
I will have to take a look and see if I can do this with my tractor... the pto pump/hoses/oil reservoir might be in the way... I will have to experiment. I got the PTO pump solely based on my dealer's recommendations. I have dealt with him for a number of years and he has always been fair and supportive, both on price and service, so I don't think he just wanted to make the extra $$ for the PTO pump. He said that it had been his experience that the PTO pump (with the L3400) provided more power and better response than the tractor hydraulics. I also like the idea of keeping implement fluids isolated from the tractor hydraulics... maybe an unreasonable concern on my part.
/ backhoe remove and install times #11
...He said that it had been his experience that the PTO pump (with the L3400) provided more power and better response than the tractor hydraulics.
Well, there isn't any "wrong" answer here, and I don't want to poo-poo your dealer...
But the "more power and better response" reasoning is questionable advice... that's a new one. The only thing the BH needs from the pump is flow at a rated pressure. The flow rate determines the "response". The BH80-X is designed for 5-7 gpm, your implement loop provides 6.3 gpm - no problem. The "power" has little to do with the pump, it's determined by the work cylinders and the BH's pressure relief valve. In no case is my tractor pump the limiting factor. Most people don't even operate them at the rated flow much of the time, because the boom moves too fast.
What I'm trying to say is, you really would not be able to tell the difference between your tractor's hydraulics and your PTO pump. The primary reason they even offer a PTO pump is for older tractors that cannot generate the required flow/sustain pressure; that's not your or my modern tractor.
This is a better argument, you're not the only one who has said that. The only thing I would offer is consider this: All of the fluid running through the work circuits has been filtered (at the HST sump). If you have a FEL, it is running off of the "tractor hydraulics". If your BH was plumbed into the tractor, it would be in the loop with the FEL. So... if it's OK for the FEL, why wouldn't it be OK for the BH? Are we to think the hydraulics of the BH are somehow dirtier than everything else? There are more cylinders, but only one, at most two, are doing anything at a time; the "waste" fluid simply goes back to be re-filtered.
Sorry, not trying to tell you what you should do differently. Just seems there's a situation where it looks you're dealing with a lot of inconvenience, and it's perhaps for zero or little benefit. It's just unfortunate to me that you don't want to use your BH more because of it :(; it's a great machine. :)
/ backhoe remove and install times #12
What is your ground clearance when you do this ,, I go through heavy brush and stumps and would worry they would hang up..???
/ backhoe remove and install times #13
It isn't easy to tell from the angle in my pic, but the cutout that the arms pass through/under is higher than the rest of the BH frame... in other words, the arms do not hang below the frame, the frame is still the lowest point. The arms of course hang no lower than they would if the BH wasn't there with the 3PH down.
So there are probably more things to be concerned about getting hung up on going thru stumps and brush... like an HST filter :eek:
/ backhoe remove and install times #14
I doubt that it's the type of mount that you are talking about, but years ago, I once rented a Kubota L-35 and a box blade for a weekend.
When the rentor delivered the stuff, he went through the process of showing me how the tractor worked AND, since I had the box blade, he showed me how to remove the hoe and reinstall it.
Upon trying to reinstall the hoe back onto the machine, he tried & tried.... ultimately, I think it took him near an hour to get the backhoe installed. I know it wasn't on even ground but then again, it wasn't on a hillside either :)
Since I saw how much time it took him to reinstall it and my rental time was limited, I simply did all my backhoe work and forgot about the boxblade. I never took the hoe off the machine.
/ backhoe remove and install times #15
On my Branson I have to take my 3 pth off first and that takes about 10 min. Even if the hoe isn't on level ground, if I connect the two hydraulic lines first and use the outriggers to get the two rear hoe mount hooks on the lower arm bolts and then lower the ouriggers the front hooks drop into place. Total time on a good day 20 min.:eek:
/ backhoe remove and install times #16
I'll second that! I'd have that bh on & off weekly if it wasn't a pia to get the
3pt on & off.
2015 HYUNDAI HX220L EXCAVATOR (A64279)
2015 HYUNDAI...
2025 JMR 72in. Hydraulic Dual Cylinder Brush Grapple Skid Steer Attachment (A61572)
2025 JMR 72in...
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
2021 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2021 KENWORTH T680...
2021 Jayco Jay Flight 32BHS Camper (A62613)
2021 Jayco Jay...
2 Row Cultivator (A64047)
2 Row Cultivator...
