Rotary Cutter Thoughts on blade straightening
/ Thoughts on blade straightening #1
rod30215
New Holland 1720
Is there any recommended way to straighten blades or do I just need to suck it up and replace?
/ Thoughts on blade straightening #2
First, Welcome to TBN.
Second, what type of blade? Pictures of the damage would really help.
E/S
/ Thoughts on blade straightening #3
Agree, depends on the blade and how bad. I have straightened lawn mower blades with a bench vise and sledge hammer, also used a hydraulic press on some things. I have also just thrown some away and bought new ones.
/ Thoughts on blade straightening #4
/ Thoughts on blade straightening #5
I'm assuming you are talking about rotary cutting blades. If it is significantly bent, I would worry about metal fatigue pounding it out strait again. A piece of rotary blade flying off would be a significant hazard.
Guess I should have given a few more details. I'm talking about a Woods 5ft rotary cutter. I put on new blades about a month ago and then got into a very high lot with hidden rocks & stumps. The blades are now about 2" out of whack.
/ Thoughts on blade straightening #7
Are they bent up or kinked?
Does the mower run out of balance ?
Are the blades reversible?
Sorry about more questions than answers.
E/S
/ Thoughts on blade straightening #8
You need new blades.
/ Thoughts on blade straightening #9
I saw a guy use a log splitter as a hydraulic press once to straighten a brush hog blade. He had to make a support out of an old 6"x6" and some small pieces of scrap wood. Seemed to get decent results - good enough for a brush hog. Might not have been good enough for a finish mower blade (but then they are lighter and easier to bend, so maybe it would have worked OK?)
/ Thoughts on blade straightening #10
Like a piece of wire that you may bend back and forth to break it,,so goes all metal,,,if you bend a blade back,,to straighten it,,you will work hardened it,brittle point,,,no I wouldn't do it unless I was disperate....have welded broke brush hog blades,,,wouldn't do it again..think about the person you might be cutting their heads off,,[and it would be totally your fault if it happened,,not real good chance of it happening,but still a chance...]
2008 Case CX240B Hydraulic Excavator (A64194)
2008 Case CX240B...
(2) Truck Rims and Tires (A65640)
(2) Truck Rims and...
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
2001 Ford F-450 Super Duty Flatbed  7.3L Power Stroke Diesel (A63689)
2001 Ford F-450...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
RoGator RG1300C (A63689)
RoGator RG1300C...
