Rotary Cutter Thoughts on blade straightening
   / Thoughts on blade straightening #1
rod30215
New Holland 1720
Is there any recommended way to straighten blades or do I just need to suck it up and replace?
   / Thoughts on blade straightening #2
First, Welcome to TBN.
Second, what type of blade? Pictures of the damage would really help.
E/S
   / Thoughts on blade straightening #3
Agree, depends on the blade and how bad. I have straightened lawn mower blades with a bench vise and sledge hammer, also used a hydraulic press on some things. I have also just thrown some away and bought new ones.
   / Thoughts on blade straightening #4
   / Thoughts on blade straightening #5
I'm assuming you are talking about rotary cutting blades. If it is significantly bent, I would worry about metal fatigue pounding it out strait again. A piece of rotary blade flying off would be a significant hazard.
Guess I should have given a few more details. I'm talking about a Woods 5ft rotary cutter. I put on new blades about a month ago and then got into a very high lot with hidden rocks & stumps. The blades are now about 2" out of whack.
   / Thoughts on blade straightening #7
Are they bent up or kinked?
Does the mower run out of balance ?
Are the blades reversible?
Sorry about more questions than answers.
E/S
   / Thoughts on blade straightening #8
You need new blades.
   / Thoughts on blade straightening #9
I saw a guy use a log splitter as a hydraulic press once to straighten a brush hog blade. He had to make a support out of an old 6"x6" and some small pieces of scrap wood. Seemed to get decent results - good enough for a brush hog. Might not have been good enough for a finish mower blade (but then they are lighter and easier to bend, so maybe it would have worked OK?)
   / Thoughts on blade straightening #10
Like a piece of wire that you may bend back and forth to break it,,so goes all metal,,,if you bend a blade back,,to straighten it,,you will work hardened it,brittle point,,,no I wouldn't do it unless I was disperate....have welded broke brush hog blades,,,wouldn't do it again..think about the person you might be cutting their heads off,,[and it would be totally your fault if it happened,,not real good chance of it happening,but still a chance...]
1993 FORD F-350XL SINGLE CAB FLATBED TRUCK (A51406)
1993 FORD F-350XL...
2001 DODGE RAM 3500 (A58214)
2001 DODGE RAM...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2000 Ford F-450 Dump Truck, VIN # 1FDXW46F5YEB20130 (A57453)
2000 Ford F-450...
2020 TAKEUCHI TB260 EXCAVATOR (A52709)
2020 TAKEUCHI...
V-HULL ALUMINUM BOAT (A52708)
V-HULL ALUMINUM...
