How wide should a box blade be?
/ How wide should a box blade be? #1
PastureKing
Crab Orchard, KY
JD 950
I have read numerous threads and concluded that I need to purchase a box blade vs. a grader blade. I really appreciate the value of experience I always find here. I have a JD950 (30hp) and the 5' bush hog matches the width of the rear tires. I don't know if I need to limit the width of the box blade to 5' or if I can go 6'. The road to my house has a ditch to the right of the road and I don't want to slip off into that ditch trying to move gravel back onto the road. I worry the 30 hp will limit the size of the box blade.
Thanks in advance for those willing to share their experience and wisdom...
/ How wide should a box blade be? #3
I use a 7' box blade on my L5030 which exceeds my tread width.
You can easily control how much "work" your blade does by depth and angle to allow your 30 HP machine to "handle" a 6' blade.
If you use a shorter one, you can offset a little to get closer to the ditches.
/ How wide should a box blade be? #5
I have a Land Pride BB.
/ How wide should a box blade be? #6
Where are you located? I have a good used Rhino 6' for sale.
/ How wide should a box blade be? #8
Mr. Triple, d you have a good LandPride dealer who is reasonable on prices? Im looking seriously at a LP tiller. Western Mo here
My Kubota dealer, Davis Farm Supply, handles Land Pride and his prices are good, but I have bought so much there including three tractors I better get a good price:) We are in SE Missouri.
The LP tillers are really good, or at least mine seems to be. It is an RTR0550 that I use on my BX2660.
/ How wide should a box blade be? #9
Keep in mind, some box blades have removable end caps for grading and the angle may be adjusted.
/ How wide should a box blade be? #10
I'd been thinking of going 6' on my (to be) 55" wide CT235, but one use of this will be ballast while I'm working in the woods, so I'm thinking 5' now. I don't really need the 6' and it would get hung up a lot more.
Quandry.
/ How wide should a box blade be? #11
Quandry.
That surely is a consideration, if I was going to be in the woods much, I would have gone with a smaller one too.
/ How wide should a box blade be? #12
Welcome PastureKing. Assuming that you will also have adjustable ripper teeth on your BB, before you buy, flip it over upside down and look at the welds (or lack thereof) on the ripper teeth pockets. I bought a well known name brand BB and had a ripper tooth pocket bend backwards due to NO bottom pocket welding! The company made good and repaired in pronto time. Not sure if all BB manufactures engineer in pockets-can't speak for them. Flip it over anyway and inspect all of the bottom welds.
Thanks to all. I've located a Vassar 6' BB from a private dealer on craiglist and have looked at a 6' BB from Tractor Supply. I am now confident that I want to get the 6'.
Stay cool...
Arrow Quip 10' Heavy Duty Bow Gate (A64047)
Arrow Quip 10'...
2005 International 4400 Truck (A61573)
2005 International...
Adams 16T Tender Body (A63118)
Adams 16T Tender...
2012 CHEVROLET SILVERADO PICKUP TRUCK (A59910)
2012 CHEVROLET...
2012 MACK GRANITE-GU713 (INOPERABLE) (A63569)
2012 MACK...
2023 BOBCAT T770 SKID STEER (A62129)
2023 BOBCAT T770...
