testing relays
/ testing relays #1
kak
Member
How are electrical relays tested? I have a JD 4300 and I suspect that there may be a bad relay preventing the engine starting (won't crank when the key is turned). Thanks!
--Karl
/ testing relays #2
--Karl
There are several types of relays but the most common are the little ice-cube relays. About 1.5" square and have 4 terminals. I'll assume you are talking about them.
The terminals are usually labled 85, 86, 87, and 30.
85 and 86 is the control side of the relay and create a magnetic field to close the "switch" between terinals 87 and 30.
The easiest way to test is to check for continuity between 87 and 30. There sould be none, or the switch open.
Then add 12v to 85 and ground 86 and see it the continuity between 87 and 30 goes to 0 ohms (switch closes).
Some relays have an 87a terminal which is a normally closed terminal. meaning it has power (continuity with 30) without 85 and 86 having power and ground, and opens (no continuity) when power and groung are applied to 85 and 86.
Additionally, some relays are controlled with the ground wire on 86 and otherswith the 12v on 85. Depending on your tractor, it may have 12v all the time on 85 and when you what to enetgize the relay, in closes the switch and allows 86 to ground. Others have 86 grounded all the time and when the relay needs to be energized, it supplies 12v to 85.
/ testing relays #3
Dont know about Deer, but most starter motors have a solenoid that does two things;
First there are heavy duty contacts that carry the 200+ amps that run the starter motor.
Second, the solenoid slides a gear along the starter motor shaft that engages with the flywheel ring gear to spin the engine.
The relay that you refer to may be the switch that sends current to the solenoid.
/ testing relays #4
Relays are pretty simple. The coil must be energized for the contacts to actuate. However, depending on how one is designed, it will have either NC (Normally Closed) or NO (Normally Open) contacts. The ones that are NC you should measure near zero ohms across the contacts with no voltage applied to the relay. When the coil is energized, NC contacts should read infinite resistance (open).
For NO contacts, they will measure infinite resistance with the coil de-energized. Once the coil is energized, they should read near zero ohms through them. Oftentimes a relay will have both NC and NO contacts.
The contacts can become corroded over time, especially in humid environments or if they have poor weather sealing. They can also become burned due to arcing over being closed or opened during many cycles of operation.
The coil itself can open up (near infinite resistance measured across it) which means it will not energize. Or, it can have shorted turns (lower resistance than it should measure), this condition may or may not let it energize. The only way to know the proper dc coil resistance that you should measure is to have another known good one (same type) to compare with, or have the manufacturers spec's to it handy to refer to.
/ testing relays #5
I don't think most tractors have the "ice cube" relay involved in the starter circuit, but LD1 explained that nicely if you do have one. Make sure your battery is good. You should have 12.6 volts to begin testing. Find your starter and unplug the small wire at the solenoid. Check to see if you have 12v supplied to it while ignition key is in the crank/start position. If you do, make sure your big wire at the solenoid has 12v, and a good clean connection. If you don't have 12v at the small wire when attempting to start, you need to work backwards through the wiring to find out why. Safety switches on seats or ptos or transmission linkage could be involved.
/ testing relays #7
And be careful about whether the safety switch is normal closed or normal open. I had real fun with a Rx75 until I worked out the seat switch is normal closed. (to by pass the switch simply unplug).
/ testing relays #8
Karl, here is a photo of your fuse panel. Hopefully yours is cleaner. Most
if not all of your relays are the same kind (well-described by LD1). You
can swap the relays around to test them, as well as using an Ohm meter
and a battery. I do suggest that you look at the electrical diagram to see
what each one is for. Also the various safety switches are more likely
your problem, vs the relays.
Since these are standard plug-in automotive relays, you don't have to
get them from Deere. I used Bosch units for my replacements.
/ testing relays #9
This page has a diagram and pictures of the type of relay LD1 describes. Basic Wiring - Custom Airbrush Work and Radical Customizing
Here is another simpler diagram of this relay
/ testing relays #10
This may or may not help. I'm guessing you are thinking one of the relays aren't working. Maybe you need to check your ground. My NH was having starting problems, after replaceing several parts- some were relays - I removed the grounding cable at the frame - It look good, but the back side was really bad. After sanding the cable back and the tractor frame contact point - and reinstalling on the tractor it now starts just fine.
2024 BOBCAT T66 R SERIES SKID STEER (A62129)
2024 BOBCAT T66 R...
2001 KENWORTH W900 72" STUDIO SLEEPER (A62613)
2001 KENWORTH W900...
UNUSED KJ 20' BI-PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20'...
Polaris Ranger 4x4 (A61166)
Polaris Ranger 4x4...
PALLET OF GOLFCART TIRES (A62131)
PALLET OF GOLFCART...
Arrow Quip 10' Heavy Duty Bow Gate (A64047)
Arrow Quip 10'...
