Rimguard vs. Methanol
   / Rimguard vs. Methanol #11
Is methanol flammable? I would say yes, because I used to run it, instead of gas in the racing go carts I used to race. Unless there is 2 different types of methanol.zman:cool:
   / Rimguard vs. Methanol #12
Since Methanol is a volatile solvent as well as a poison, it wouldn't be my choice. I wonder what the effect will be on tire rubber which, as far as I know, is not designed to contain a volatile solvent. Long term will be interesting.
   / Rimguard vs. Methanol #13
Did you used to burn it when it was mixed with water[2/3rds water]??
   / Rimguard vs. Methanol #14
Been running methanol mix in mine for 10yrs and no problems, no slippage. REALLY makes a huge difference in pulling power...like getting 20 extra horsepower. My MF 1040 used to spin pulling a loaded 5' box blade, now it will pull the blade without spinning even when the box blade is full and overflowing.
   / Rimguard vs. Methanol #15
Are you aware that you have methanol in your car windshield washer fluid reservoir right next to a hot engine? Has it ever caught fire? Ever heard of a windshield washer fluid fire? Ever heard of a tractor tire fire due to methanol?
IMO this fire/WWF hype is BS. Pure methanol is flammable but mixed with water it does not seem to be a real world problem at all. Yes, it has a flammability warning on it with regard to open flame but it is hardly a high risk solvent. You need presumably more than just a spark to start a fire with WWF and also need a continuous supply of oxygen to sustain a fire. Where are those essential ingredients to be found inside a tractor tire filled 75+% with fluid?
Regarding tire rubber, the tire manufacturers have not seemed to issue any warnings despite the common use of WWF in tires for many years.
   / Rimguard vs. Methanol #16
I have had Rim Guard in all 4 tires on my 3320 for over a year with no leaks or slippage.
Dan
   / Rimguard vs. Methanol #17
Before you respond in a patronizing manner that has NOTHING to do with what I said maybe YOU should reread what I actually said. Did I say that water mixed with Methanol is flammable? NO! Did I say that WWF is flammable? NO! Did I say that Methanol is flammable? NO, although it is! I SAID IT WAS VOLATILE! Volatile as in evaporates quickly. Dictionaries are your friend, use them instead of misunderstanding what people say. Volatile fluids are solvents, among other things, which is something that I wouldn't put in a tire. I DON'T really care what you put in a tire or do otherwise!
Why would a tire manufacturer issue a warning not to ruin their tires? If you ruin the tire you have to buy a new one. Tire manufacturers sell tires not warnings, they're not stupid, they're in business to make money!
   / Rimguard vs. Methanol #18
I've seen this Methanol issue come up over the years and I think this is the first time I've posted to it. I also must say I've laughed every time I've seen it posted too. I can't figure out why folks have a fear of Methanol mixed with water in a tractor tire. This was tobacco country where I live and every tractor had this mix for ballast. Thousands of tractors I might add. I can drive around and show folks tires that have been on tractors since the late 70's with Methanol in them. I sold a 1968 (bought brand new by me) Farmall 140 to a neighbor and it just had new rear tires put on 2 years ago and the old tires had Methanol. BTW they were Friestone tires on it" new" too. I've seen tires with methanol burst from wear in the field and it didn't kill any plants of tobacco. Had one changed in my hay field because of a deer antler rip and it didn't kill any grass. You'll find other sources of ballast that are heavier but for the cost and safety issues you can't beat Methanol mixed with water for ballast. Bought a new Agrofarm 100 last Nov. and the first thing I put in the deal was for the dealer to add Methanol ballast to each tubeless tire but only went 40% fill on the tires because they are radials. Wanted some extra weight without a harsh ride.
I'd hate to have to drive from my home and find a wet tire ballast that didn't have methanol in it. Might have to travel several hundred miles to find something other than methanol. It works and it works safe. Cheap ballast. I'm 58 years old and been farming all my life and never had any problem with methanol. So now I say I've done it and those that have a fear tell me you've done it and the problems you've had. LOL LOL Not trying to pick on you but you always see folks post about something is snake oil or it's a bad product and most have never tried it. Have a good day.
   / Rimguard vs. Methanol #19
My apologies. You are correct. It was the post before yours and a few earlier ones that talked about flammability.
Still, volatility is not much of an issue in a closed system either. Do methanol/water mix tires freeze after the third year because the methanol has evaporated?
Theoretical concerns should be balanced with empiric data. There is a ton of experience strongly suggesting that methanol/water mixture is safe, long lasting and does not cause damage to tires. It is one of the cheaper and easier mixes to add in the field and is generally non toxic to plant or wildlife in the amounts likely to leak from a tractor tire.
I think you are wrong about tire manufacturers and methanol. If methanol was known to weaken tires and they did not inform you as such there would be a herd of personal injury lawyers filing lawsuits against them.
   / Rimguard vs. Methanol #20
Thanks for your reply. I was mostly concerned with damage to the the tire. The previous post to yours pretty well sets my concern aside. I'd say that with that many years of Methanol mix use in a tire, as reported by Charolais, that the Methanol mix idea is a proven safe concept. Good to know, can always learn something new.
Have a good day everyone!:thumbsup:
2012 Chevrolet Malibu Sedan (A50324)
2012 Chevrolet...
2011 Chevy Avalanche (A50324)
2011 Chevy...
SELLICK S80J4E-4PS ROUGH TERRAIN FORKLIFT (A51242)
SELLICK S80J4E-4PS...
2015 Dodge Charger Sedan (A50324)
2015 Dodge Charger...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
(2) 250 GALLON POLY TOTES W/ CAGES (A51244)
(2) 250 GALLON...
