How much temp is too much.
/ How much temp is too much. #1
JC-jetro
Elite Member
Kansas
Ford 1700, Kubota MX-4700
Hi Guys,
I was on my place yesterday, it was nice and toasty here in Kansas. After about 1/2 of heavy tall brush hogging my temp gauge moved all the way up just a notch below high in really heavy brush. I raised the hood up and just felt the heat without touching and the engine did not feel excessively hot... I was sweating like a pig myself so my heat tolerance was higher than normal.Ii disengaged the pto and slowly drove to the barn, The temp started to come down but stayed on the right side the middle about 1/8" on the dial. I did not have my infra red thermometer with me to measure actual temp. I'm not too concerned with the needle calibration.
I went back this morning to collect data and like to share it with you all.
Radiator full of coolant, no leak at all, water pump has no leaks, appears to work, belt is tight enough and the fan blade turns with no issue. The radiator screen was a bit dirty which I cleaned. Took my leaf blower with me and blew the radiator core where I got some dirt out but not much.
Cold engine, sender resistance=690 ohms, radiator housing 98 in the shade and ambient of 100 degrees.
normal operating , needle right smack in the middle, sender @140 ohms, T housing 172, head 174, exhaust man 192 and the radiator at 170 deg F.
Hot temp, 1/8" right of the middle.
sender 87 ohms, t stat housing 196, head 197, exhaust man 216 and radiator at 196 deg F.
Really hot, 1/8" left of the overheat mark.
sender 66 ohms, t stat housing 210, head 212, exhaust man 250 and radiator at 210 deg F.
I'd like to know your opinion and experience. I think there is nothing wrong here only that the tractor was chewing more than it could in a really hot day. It seems my rig from normal to really hot was running between 172 to 210 deg F jacket water temp.
Any comments?
JC,:)
/ How much temp is too much. #2
My 1910 will go up to one notch below hot too when bush hogging. Part of the problem is the radiator screen getting dirty. I never run it past that point. I idle down for a bit and then clean the screen and start over. Been doing this for years with no problems other than the pain of stopping and cleaning.
I've thought about putting a real temp gauge on it but never got around to it.
For some reason the Kubota never moves much above the cold mark no matter how hard I work it. I'd bet the new New Hollands cool much better than my old 1910 too.
/ How much temp is too much. #3
Hi Guys,
Any comments?
JC,:)
I say that your gauge and sender are well calibrated, and your tractor is performing well. If and when the gauge gets to the overheating mark, the engine will in fact be overheating or very close to it. With a 7psi or so radiator cap, at 1/8" to the left of the overheat mark, your tractor is running at its maximum thermal efficiency. Diesels do not run well or efficiently while cold or even warm.
/ How much temp is too much. #4
JC, I think there is a problem with some part of your cooling system. Whenever the needle goes above the middle mark on the guage of the 1700 it is above normal in my estimation. When working mine with a 5' brush hog running the normal temp is just to the left of the center mark. When the screen gets dirty or I am overloading the brush hog it will go about 1/16 inch above the center mark. When that happens if I shut off the PTO and it returns to the left of the mark. You could have a water pump going bad. Do some more checking. With the tractor shut down (not running) manually check for any wobble by hand (don't force it) of the pump shaft at the pulley. If no wobble, hose the radiator with water and mow some more and recheck. When my water pump went bad it began to get longer as the shaft moved toward the radiator. It almosted rubbed the radiator causing a flating of the cooling coil. ( the pump seperated into 2 pieces when I took it off). I guess if the pump is ok it might be the thermostat. I would hesitate to continue the mowing if the guage was running that high. Pump replacements can be purchased on ebay. Ray I.
Thanks Rick:) That's what I wanted to hear. I replaced my radiator cap and at the high heat It never released causing any coolant discharge. everything has a limit and I push my little tractor right there. I've started to open up some shooting lanes for upcoming deer season. I think I'll do it a bit later in September and watch not to exceed middle high.
CCsial, The best way to know is to read the temp. Obviously even the best temp meter can be off on either side of real temp. if sending unit out put is linear then one can calibrate the temp needle against some known temp and that's as close as you can get. Those HF Infra Red meters come pretty handy.
JC,
/ How much temp is too much. #6
Original radiator cap is 13 PSI according to my owners manual.
Ray,
My Water pump is working like it should unless the impeller is chewed out which I doubt. There is no wobble at all. Radiator screen was a bit clogged up but not too bad. T-stat housing temp and upper radiator is about the same temp which is kind of indicate t-stat is fully open. The opening might have some calcification as well. I'll keep my eyes open but doubt if I have an issue. changing pump,tstat would be no issue when O need to do it.
Jc,
/ How much temp is too much. #8
Watch it close. Fixing it before it comes apart is a lot cheaper than after. I know you will be on top of it. Good luck! Ray
P.S. I hope you bag a 12 pointer this fall. I planted a food plot on my 12 acres, but I am having trouble keeping the weeds out. I saw a doe with 3 fawns the other day.
Thanks Ray,
I got my eye on the guy below. He and the rest of his buddy marauders are making a mockery of my 8 feet tall deer proof fence:(.
JC,
ps. By the way, I bought the original OEM radiator cap from NH and frankly can't remember the rating.
/ How much temp is too much. #10
Thats going to look good hanging on the wall!:thumbsup:
A bit more info, I did check with my Owner's manual and it rate the radiator cap @ 13 psi. I bought an OEM cap from NH and can't remember the rating. I'll check the marking next time to see if I can figure out. But the point is as Rick said 7 psi cap or 13 the following is true.
Kansas City is 800 feet above sea level with atmospheric pressure of 14.1 rather than 14.7 psia
7 psi radiator cap=14.1+7= 21.1 and water boils at temp of 230 deg F
13 psi radiator cap=14.1+13= 27.1 and water boils at temp of 243 deg F
50/50 anti freeze raises the boiling temp to 223 @ atmospheric condition and up to 275 deg F.
So even at 7 psi it seems the manufacturer has designed the engine to see water jacket temp up to 230 for the cap to pop off.
In no time I exceeded 210 T housing and top of the radiator surface temp.
JC,
/ How much temp is too much. #12
JC, It probably does not make any difference at all which cap you use. Because of my core plug leak, which has not sealed yet, I have been running my 1700 with the radiator cap in the 1/2 half unlocked position (first notch) and it has not made any change in the temperature gauge reading. So you are good to go. However you should keep a close eye on the guage for any changes. When my water pump went bad, the first thing I noticed was the pump shaft started to get longer and moved closer to the radiator with the only thing keeping it from a seperation was the fan belt alignment. So if yours (ever) starts rubbing the radiator coils, shut her down fast for a water pump repair. It may never happen buy just be aware of the chance. Ray
Ray,
I actually took the belt off to inspect the water pump pulley and the shaft. There is no front to back or side play in the shaft. it appears to be solid. I don't see at all any sign of water leak. The coolant level stays unchanged so I have no loss there. I'd make sure belt is tight enough but never to the point to cause premature failure of shaft seal or the bearing. All the heat and rain we had here caused some of the brush to grow like mad. I know the lay of my land and pretty much know all the trees and what I have on ground surface. My mowing was scary as it looked like I'm running my tractor in to a wall. some of the brush was so tall where with me standing on the tractor barely could see the top of vegetation. I reckon I could make out an elephant coming out of the thick stuff but certainly not a deer. I think some kind of disk cutter would be a better choice than brush hog in really thick stuff. By the way, dry heat is one thing and heat associated with humidity is something else. The heat index here today is about 115 degrees and that effects dry heat dissipation rate from the radiator to the ambient condition.
JC,
PS. I was thinking of coming with some contraption to honk my horn in case of high temp or low oil pressure. Idea Might have some Merits...may be !! :2cents:
/ How much temp is too much. #14
JC, When I first moved to my 12 acres the brush was as tall as you describe or taller. At that time I had a pull type brush hog on wheels. I mowed down some stuff that the grill on the tractor had to bend over to get past and it did heat up the temp guage. The end result was nome nice walking lanes in the back 10 acres. So after clearing your hunting lanes maybe everything on the tractor will return to normal. I can now mow my paths with my JD rider lawn tractor.:)
/ How much temp is too much. #15
When I rototill with my B7800/5.5' tiller The temp gauge can climb so I just give it a break after a couple of hours of hard tilling. The tiller is probably a little large for the tractor so I take that into consideration, it does do a very nice job. I make sure to idle the tractor for 10 minutes or so before turning it off though. I do not trust the gauge that is on the tractor so when it climbs farther than normal I take notice. Knowing your equipment is important.
Hi Ray,
I was there this morning and cut about 2 acres of brush. Pic below shows what my little 1700 was up against.
JC,
Rick,
I was on my place to cut some of the thick brush. I'm not worked up too much about where the needle rests. There is a mark left of "H". I suppose that is not to exceed limit although I was not able to corroborate that from owner's manual. At where you see the gauge shows, the T housing temp was 212 and the top of radiator was 210. The ambient was pretty high with good heat index 110+. Do you know what maximum not to exceed head/ coolant temp for that vintage diesel engine is? I was not able to find a definitive number anywhere. There was no boil over and not slightest amount of burned oil or gasket smell.
Thanks,
JC,
Has anyone else has an opinion or experience with max not to exceed temp for diesel?
/ How much temp is too much. #18
Rick,
Thanks,
JC,
Maximum operating temperatures vary, but generally are in the 190-210 range.
When the coolant reaches the boiling point, however altered by a pressure cap and antifreeze mixture, the boiling will begin in the cylinder head. When coolant liquid boils away from the head casting, the casting rapidly overheats (because gasses can't transfer heat from cast iron as fast as liquids) warpage/ gasket failure/ cracking can occur. If you have any appreciable amount of antifreeze in the coolant mix, or if your cooling system has sufficient integrity to contain a few pounds of pressure, and your pump has the ability to circulate coolant, your tractor is not about to overheat at the described temperatures. Your tractor is running near peak thermal efficiency. If it has sufficient coolant at startup and is not puking from the overflow, you are OK. Running it another 10 degrees hotter may change things.
FWIW, I would not want a 25 year old radiator to have to keep 13 PSI bottled up over the long haul. Regardless of the application, I would probably install a 7psi cap rather than the specified 13 psi cap if a replacement is needed.
Thanks Rick,
Picked up the number off the radiator cap and will contact my NH dealer to verify the pressure. I too do not want to force cooling system to 13 psi above atmospheric pressure. I don't have my charts here at home but I thought the the temp would jump to 230 at 13 psi above atmospheric. It never puked once either. This is by far the tallest and thickest weed and highest temp I operated my tractor. I slowed down a bit here and there but kept on mowing for 2 1/2 hrs. Thanks for the insight.
JC,
/ How much temp is too much. #20
JC, I was also concerned about my 1900 running around the mark below hot. Like you I checked it with the IR temp gun and found out this is arround 200 deg. I keep saying I am going to put in a temp guage with numbers but never seem to get to it. As RickB said 210 is where must manufactures want there engines to run.
Bill
UNUSED WOLVERINE MSG-11-44W 44" HYD STUMP GRAPPLE (A62131)
UNUSED WOLVERINE...
2003 GMC W4 4X2 BOX TRUCK (A59908)
2003 GMC W4 4X2...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63118)
2019 Cadillac...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59575)
2021 KENWORTH T680...
36" EXCAVATOR DITCHER BUCKET (A62130)
36" EXCAVATOR...
