Someone smarter than me please help!
/ Someone smarter than me please help! #1
Gbbob1980
Oliver 550
Hello I'm new here and am looking for some help. Today I was pulling a 5' 3 point tiller with my Oliver 550. Everything was normal then it seemed like I could smell something was running a little hot. I ran to the gas station and did a few things around the house...gave the tractor plenty of time to cool down- probably 40 minutes.
After cooling down I jumped back on the tractor I engaged the pto and as soon as I touch the tiller to the soil the pto/ tiller stops immediately.
A little background I just had the tractor 3 point serviced as I was about to load the tractor up a kid came by and told the owner "I just added another 1/2 gallon of fluid back there"... This was after all work was done.
I just checked the fluids and the hydraulic oil in back that the kid was talking about was waaaaay past the full line on the dipstick...almost to the top of the filler neck. Is this just coincidence or does the fluid being that much over full be causing my pto issues. If so, why would it have worked just fine earlier in the day?
Thanks for your help in advance.
/ Someone smarter than me please help! #2
Welcome to TBN... were you able to determine the source of the smell....from the tiller or from the tractor.....typically, overfilling is not a good thing but I can't tell you exactly what the negative result, if any, might be.
The smell was from the tractor. The tiller is fine, it spins freely no issues there.
/ Someone smarter than me please help! #4
Too much fluid can blow seals in the hydraulics. The wiser folks on here can tell you if the clutch pack for the PTO might have gotten doused and causing the burning smell. Or if the shop that did the service is conveniently located take it back there and let them check it out. I'm curious as to what you find.
PS: Welcome to TBN. There are some guys on here that have forgotten more stuff than I will ever know. So you have come to the right place.
Yeah taking it back to the shop requires a trailer and a 40 minute ride each way...It will be going back to the shop but they are closed till Monday. It just makes me wonder why it worked perfect then stopped after it had time to cool down.
And thanks for the welcoming & your comments so far.
/ Someone smarter than me please help! #6
Is your PTO stopped or is the clutch on the PTO slipping. If not there I would look at the clutch adjustment of the transmission. If you have a 2 stage clutch (push part way to stop the trans and further down to stop the PTO) it could be out of adjustment.
The clutch is not slipping and it is not a 2 stage clutch
/ Someone smarter than me please help! #8
When you let the tiller down, does the PTO shaft stop or just the tines stop? Have you checked the slip clutch on the tiller if it has one,
The pto output completely stops. There is no power to make the slip clutch on the tiller slip.
/ Someone smarter than me please help! #10
Is it just the PTO...
Or does the Tranny stop the wheels too?
J
Wheels keep rolling...no problem there.
/ Someone smarter than me please help! #12
My diagnosis is the extra fluid blew a rear seal and now you've got transhydraulic fluid leaking on the (supposed to be) dry pto clutches.
My Cockshutt/Oliver 550 that I bought this spring suffers from exactly the same problem. Probably not coincidentally, the fellow I bought it from had not long before had the 3-point hydraulics worked on. I got it home, piddled around with it for a day or so and then hooked it to the bush hog. Engaged the PTO - no problem. Slip clutch on mower worked right and no racket anywhere so I started out. I made one round in 2nd gear, stopped to change to third, and bingo - no pto output.
Plus I think I've got some engine oil seal leakage too. Although I haven't opened the inspection plates to see, I can see small drips of darker engine oil on the front plate (guessing this is for the driveline clutch) and clear transhydro drips at the rear. I've never tried to split a tractor before but this might be the time to learn.
Reading your situation I see some similarities: start out cold and relatively drip dry and PTO engages and things seem to work OK (but probably not perfectly), stop to do something or change gears after the oils heat up and you get hot oil in more volume on the clutches and not implement action.
Can't wait to see what the real tractor mechanics and long time ollie owners have to say about it. -WSJ
2016 KUBOTA SVL75-2 (A64047)
2016 KUBOTA...
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
Goat Family (A62183)
2001 John Deere 1780 Planter (A63109)
2001 John Deere...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
