B7300 front tires
   / B7300 front tires #1
bikerdib
Texas
Kubota L4701
I'm looking to find a more aggressive front tire tread pattern for my 4X4 B7300.
From web searching, I was only able to find the Firestone in the 21X8.00-10 and it is a direct replacement turf tire. Then I found a Trelleborg tire guide:
http://www.semcice.cz/pdf/trelleborg.pdf
If you scroll down to the 10 inch size, you will see a 21X8.00-10 with their 462 tread pattern (looks similar to a R4?). Anyone tired this tire on the front?
   / B7300 front tires #2
Do you have turfs on it now? I had a B7300 and it had ag tires. The fronts were 6-12s I believe. If you have turfs it might be hard to find something else to fit your wheels. Regardless of what you do make sure you keep your front to rear size ratio correct.
   / B7300 front tires
Yea' I'm aware the front & rear must keep the same ratio. That's why I'm on a fact finding mission.
The B7300 came with either an R1 type or turf type front and either an R1 type, turf type or what they call a combined which is sorta in between the other 2. That means 2 different front rims and 3 different rear rims. And the front and rear type have to match. Thus my dilemma. Like I said, Trelleborg lists a 21X8.00-10 ag type which is the original size of my turf and Trelleborg gives the rolling diameter of the tire I'm considering but I'm just trying to make sure. What else do I need to look at?
   / B7300 front tires #4
Sounds like you are on the right track to me. As long as the tires you want fit on your wheels and the rolling circumference is the same as the original tire you should be in good shape.
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2013 Cadillac ATS Sedan (A50324)
2013 Cadillac ATS...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A52128)
NEW 2025 Load...
CUSTOM ALUMINUM 16FT CAR TRAILER (A51222)
CUSTOM ALUMINUM...
2005 GEHL CTL70 TURBO SKID STEER (A51242)
2005 GEHL CTL70...
2012 International Day Cab Truck Tractor (A50323)
2012 International...
