replacing a broken grease zerk
/ replacing a broken grease zerk #1
rimshot
Michigan
Kioti CK2510 HST
I noticed one of my backhoe outrigger arm pins is missing a complete grease zerk. Looking at the damage makes the events leading up to this episode obvious. It appears as though the right sized small stone became trapped as backhoe outrigger arm was lifted up and the stone very likely became wedged against and breaking zerk.
So my Kioti backhoe must be made in America and the zerks are straight and are 1/8 pipe thread. The top part (nipple) was broken but it left the threaded barrel screwed tightly in the threaded grease hole. So what do you think the easiest way to repair this. If I drill and rethread I suppose I would drill(11/32" bit) the old zerk right out and then rethread. That means driving pin just past the grease hole, then drilling and then TURNING a thread tap.
Or I suppose I could remove the remaining grease zerk with perhaps and ez out and simply acrew a new fitting in.
Anybody have a solution to this problem. The zerk is tapped into th side of the pin cylinder for this 1" pin so that means the tap can't bore completely through and clean up the threads. Anybody have a remedy for that?
rimshot
/ replacing a broken grease zerk #2
Grind the end of the tap off to make it shorter. Get your depth by tapping so that six threads on the tap still show above the metal on a tapered pipe thread.
/ replacing a broken grease zerk #3
I've got broken zerks out with ez-outs as well. Funny you mentioned the stablizer arms,my friend's Deere 110 has broken them in same spot. I replaced the fittings on both stabilizers last time I greased it. I have grease fittings on my backhoe [M/F] that are exposed. I like the fitting on Kubotas and others that are in the end of the roll pin. plowking
/ replacing a broken grease zerk #4
Years ago, when a small child, it happened a few times on farm equipment. In the toolbox was a 4 way hand tool. One side had the right size ez out, one had a tapered tap, one had a not so tapered tap and the last one had a socket the right size. Generally speaking, easy to get out (never rusted), easy to clean up threads and always in the equipment service toolbox...
I would see if I could drive an ez out in a bit, then get it out. I would avoid drilling if possible to avoid any chance of metal debris getting in to foul things up.
Good luck!
My dad always said if we couldn't fix it, then we had to take it to town and let the high price idiots charge us to figure it out. Always told us we could fix it if we tried.
/ replacing a broken grease zerk #5
Wow- I remember seeing those little 4-way tools- lots of mechanics had them. Back when everything got greased with oil changes... every 3000 miles or so. Thanks for the memories.
/ replacing a broken grease zerk #6
rimshot
Just back it out with an ez out. Heck, most zerks that have broken come out pretty easy.
/ replacing a broken grease zerk #7
There is a type of "easy out" that has four sides and is tapered. Just get the right size and pound it down with a hammer and back out with a small Cresent wrench. They are some type of hardend steel and have always worked for me on heavy equipment.
Thanks for all the excellent tips. True-Valu hardware opens up down town for about 1/2 day. I shall see to getting an ez out. If the drill size is 11/32 as indicated on the 1/8" pipe tap package is correct then I suspect something just less than a 5/16" ez out will work just fine.
thanks again.
rim
/ replacing a broken grease zerk #9
I'm with 2458n. I've always had better luck with the "square" ez outs as opposed to the spiraled type. ~Scotty
/ replacing a broken grease zerk #10
I use tapered reverse spiral extractors to get out busted screws and the like, would probably work great on a zerk. I think they are called Hanson screw extractors.
/ replacing a broken grease zerk #11
I've found that NAPA carries the "square" type E-Z outs. That's what I used to pull my broken zerks out. The fact that zerks typically spend their entire lives embedded in a coating of grease really does aid in the removal process, as there should not be any rust to contend with.
Joe
Well, I checked in at the hardware store. They had a five packk of Master Mechanic ez out extractors for $12 bucks. I went home and drove the main pin that secures the outrigger to the tractor just over 1/2 of the way out to expose and free up the zerk hole. I thought I may have to drill out the bottom out of he remaining zerk threaded body. With the fivee pack of ex out extractors I picked out the largest one so it was not necessary to drill w/o drilling away the bottom panel of the zerk body. It was out in no time.
I have replaced zerks before on this backhoe and the book swears they are 1/8 th pipe thread. The thing is I have yet to replace one that it fails to feel like the thread matches. I have and tried them also in metric and they dont make a fit either. It's in there and takes grease.
thanks for all the suggestions.
rim
/ replacing a broken grease zerk #14
I've found that an old allen wrench works pretty well in a pinch.:thumbsup:
/ replacing a broken grease zerk #15
Rimshot i have just replaced some on my Kioti backhoe and mines were 8mm zerk !!!!! I'm surprised that yours are of a standard thread....
/ replacing a broken grease zerk #16
I think that 8mm is the same as 5/16 "
Jim
Well now! I have a Kioti KB2465 backhoe and on pages 13-36 through 13-37 of the backhoe owner's manual it shows a cylinder and parts ID page. It shows and identifies this object as a grease nipple, p.t (pipe thread) 1/8th inch, part number GNIT-0181. Strange that they would use both metric and Pipe thread.
rimshot
/ replacing a broken grease zerk #18
rimshot
Keep in mind that 1/8" is the nominal inside diameter of the pipe, not the OD of the pipe. OD is probably closer to 3/8". A 1/8" NPT zerk will have the same OD as the pipe.:)
John Deere Z960M Zero Turn Mower (A64047)
John Deere Z960M...
Bad Boy Stand On Mower (A64047)
Bad Boy Stand On...
2006 Mack CV713 Granite Tri-Axle Dump Truck (A61573)
2006 Mack CV713...
2021 Ford Explorer SUV (A61574)
2021 Ford Explorer...
2022 MACK ANTHEM AN64T 6X4 T/A  SLEEPER TRUCK TRACTOR (A59910)
2022 MACK ANTHEM...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
