Buying Advice Quarter-inching Valve
/ Quarter-inching Valve #61
Here are the tabs that are being talked about on a Bxx20 series. That works at low rpm on my tractor, but not at full pto rpm.
/ Quarter-inching Valve #62
[/QUOTE]
"I'm surprised your BX2320 doesn't have them since I thought they're required for the QI feature."
I do not have a BX, it is a B2320
Like someone else has stated---He thought there was a model B2320 that had position control. Even my dealer said it had QI:confused
/ Quarter-inching Valve #63
I'm not sure that statement is correct. I had a B7800 and I am pretty sure the mower deck was floating (not suspended).
If you read my post carefully, you will find that all references are in present tense and only to tractors currently in production. No references were in past tense; no references were made to tractors currently out of production. And finally, I did not say that four digit numbers ending in 00 never have had floating MMMs available. That was something you inferred, not something I stated or even implied. My statement was, and is, accurate.
/ Quarter-inching Valve #64
Well, after using the tractor with finish mower, I have concluded that I DO NOT have QI. Regardless of RPM, my lift will raise and lower like all the other larger tractors I have owned.
One interesting thing is that the spring on the rod that is adjusted with "nuts" in your photos, only makes contact with the lift arm tab, when the lift is raise all the way up. It centers the lift leaver to "neutral position" When my tractor is running with the lift leaver centered at neutral, there is about 3/4" space between the spring and the lift arm tab.
Since I bought this tractor used, from a dealer, and the owners manual could not be found, they have one ordered.
Closing off the lift knob, unter the seat, and opening it 1/4 turn, solved the lift drop problem.
/ Quarter-inching Valve #65
You will find that the nut on the end that does not contact the spring can be set to limit how far the 3pt hitch drops which is handy when using the rotary cutter, etc. where you want to go back to the same height over, and over. There is a bit of trial, and error setting it, but it does work.
/ Quarter-inching Valve #66
This thread is very interesting, I as well did not know the full ramifications of the QIV when I was loking at tractors, but it makes me very happy tyhat I did no go with my first instinct when I looked at the B3200 first, the chinsy controls is what turned me off of the kubota
/ Quarter-inching Valve #67
...but it makes me very happy tyhat I did no go with my first instinct when I looked at the B3200 first, the chinsy controls is what turned me off of the kubota
So nice of you to swing by and kick somebody when they're a little down. :rolleyes:
/ Quarter-inching Valve #68
I'm confused by the Kubota website. The BX25 hydraulics specs (under Build My Kubota) list position control while the other BX models list quarter-inching valves.
Does the BX 25 really have position control or is this a typo?
/ Quarter-inching Valve #69
Sorry about that, I was just adding my two cents worth to the thread.
It really was the biggest part of what turned me off about the bota
/ Quarter-inching Valve #70
To the very best of my knowledge, that is a typo. Position control with Kubota starts at the B2630/ B3030 level / size of tractor. All other B's, and BX's just have the quarter inching option.
/ Quarter-inching Valve #71
This is getting interesting. Just got this email.
Dear Mr. Hoyt:
Thank you for your inquiry. Yes, we can confirm that the BX25 tractor
comes with hydraulic implement position control as standard equipment.
Best regards,
Kubota BX Team.
/ Quarter-inching Valve #72
The B series Narrow tractors have position control and more 3 point lift capacity from what I can gather about them. Not many people seem to have experiance with the narrow models. You can adjust the back tire for a bit wider stance but I would imagine its still pretty tippy for general use.
/ Quarter-inching Valve #73
Dear Mr. Hoyt:
Best regards,
Kubota BX Team.
That is a plus if true. It would have been more clear if they had noted that this was an upgrade over the quarter inching system which itself is technically a "hydraulic implement position control" system. Still, it should be easy enough to figure out if you go to see one.
/ Quarter-inching Valve #74
Upon further inquiry, no surprises.
Dear Mr. Hoyt:
The BX25 control is the same as other BX tractors.
Best regards,
Kubota BX Team.
/ Quarter-inching Valve #75
It is remarkable that the Kubota tech support people are too embarrassed to state simply that the BX uses a quarter inching valve system. Could it be that they understand it is a cynical marketing manuver to use it over the position control system in order to drive B/BX customers to larger tractors? Nah, Kubota is warm and fuzzy, they'd never do that.:ashamed:
/ Quarter-inching Valve #76
While closing the deal at my Kubota dealer's today, and while taking my look see of the B2320, I asked whether, during setup and assembling, they adjust the stops. Looking a bit confused, he simply said, "Oh, no those are set at the factory". I pursued it no further. I suspect few dealers would see it much differently.
/ Quarter-inching Valve #77
Draft control, position control, quarter inching valve. Real farm tractors have draft control and position control.
Use draft control for moldboard plowing, sub-soilers etc. If the implement encounters a harder area as it is being pulled through the ground, the draft control will sense this and automatically raise the implement. When the ground conditions become softer the draft control will automatically lower the implement. Draft control is a internal mechanical system designed to maintain a steady pull i.e. "Draft" on the tractor.
Position control allows the operator to select the implement height regardless of the amount pull on the tractor.
Most modern compact tractors do not have draft control, because this saves
manufacturing costs. If a person was trying to plow a field and knew what draft control did, they would wish they had draft control. It makes moldboard plowing fun.
Quarter inching valve. This is obviously built into the machines to reduce the cost per tractor. :mad:The engineer(s), marketing personnel, and bean counters responsible should be castrated.:thumbsup: That would tend to discourage cost cutting measures that make for an inferior product.
If I were selling tractors, I would use the quarter inching valve against Kubotas and any other tractor so equipped. That would fall under knowing the weak points of your competitors:thumbsup:
/ Quarter-inching Valve #78
The 1/4 inching does work on the BX series. On my BX25 I had to adjust the stops to get it to work correctly, also you can adjust the rate of drop or by turning the knob located between the deck and seat. For it to work (when adjusted right) pull towards you and push the level up or down until it hits the stop....if it doesn't hit either stop you have to adjust, if it hit but its moving up or down to much you have to adjust......Once you get it adjusted it will be fine.
/ Quarter-inching Valve #79
What the heck? The smaller, compacts which have quarter inch valving, are not likely to be out plowing in fields, as you described. Shoot the BX doesn't have the ground clearance for such work.
90% of the small, compacts are never going to be doing what you describe. This is mostly a straw man argument and a slap against Kubota.
Could Kubota make position control standard and raise the price? Sure. These small tractors are plenty pricey now and adding something, that not everyone will use, doesn't make much sense to me. Adding it as an option creates manufacturing and ordering more difficult.
Sooner or later, if Deere and those who do offer some kind of depth control will pressure Kubota and Kubota will respond. There are other threads here about the near future of these tractors and just how fancy the next gen is likely to be.
/ Quarter-inching Valve #80
Respectfully;
Draft control is for plowing fields and pulling sub-soilers.
Position control is used for everything else.
The quarter inching valve is a cheap substitute for position control. Position control is the minimum standard for a usable three point hitch. And then somebody wanted to create a job and cut costs so they dreamed up the QI valve. Just because it is a new idea does not mean it is better.
My personal opinion was as follows, There are Kubota tractors, and then there is everything else. Buy a Kubota
But now; I would not buy a Kubota with a QI valve, it sounds to me like a very poor design.
If Kubota wants to keep the price down they should quit adding bling to the tractors. All those fancy plastic parts are expensive when they get broke.
Has anyone figured out why all new tractors now have curved loader arms?
It all goes back to the Cat backhoes with the curved backhoe boom. The curved boom really serves no purpose (I have used Cat backhoes). It is just a sales gimmick. Then Deere went with curved hoe booms and curved loader
booms. Now everybody has curved booms, and they still serve no purpose.
Engineers are changing things, just so they can have jobs. If you want to make a machine more powerful you turn the hydraulic pressure up.
Personally, I do not like fancy tractors. Fancy is more money, and more things to go wrong.
Kubota V1505-T Turbo Diesel Industrial Engine  Pump Takeout (A63689)
Kubota V1505-T...
2020 Freightliner 114SD T/A VacCon VPD3611 Combination Sewer Jetter Vacuum Truck (A61573)
2020 Freightliner...
2015 Ford Explorer SUV (A61574)
2015 Ford Explorer...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59912)
2016 FREIGHTLINER...
2025 Swict 78in Bucket Skid Steer Attachment (A61572)
2025 Swict 78in...
2015 ISUZU NPR 4X2 16FT BOX TRUCK (A59912)
2015 ISUZU NPR 4X2...
