Buying Advice Quarter-inching Valve
/ Quarter-inching Valve #41
As some of you are aware, I just purchased a 2009 Kubota B2320.
I have read all post concerning QI operation and I viewed the video.
I am not new to farm tractors--owned many over my fourty years of operation. However QI valve is a first for me.
With all this being said---My B2320 operates basically the same as all my other tractors. I can barely move the lift lever or raise it fast and the lift will start raising and will travel all the way to top. Lowering is the same.
Am I missing something or do I have a "rare breed"?:confused:
/ Quarter-inching Valve #42
Giles, I find your post interesting. My B2620 will do that at lower RPM's, say under 1500, or so, but I can't get it to do that at PTO rpm when I am using my rotary cutter, etc. I get by since I do much of my box blading, etc. at 1800, or so Rpm, but other times it is pretty quick, and can vouch for it making the tractor jump a bit at full pto rpm with my 4' rotary cutter on the back, or my rear snowblower, etc. At full pto rpm, bumping my control lever will bring the implement up a foot, or more usually.
/ Quarter-inching Valve #43
I do not have a tiller, so can't comment on it. I do not find the 1/4" valve on the 3 pt. hitch to be that much of an issue with the box blade or rear blade. I adjust what they are doing more with the top link which controls how agressive they are digging in. I do find it an annoyance with the rotary mower. You can certainly use it, but as you mow, it will tend to sag down, so you have to bump it up every once in awhile. Not a huge issue, but enough to annoy me. I will probably look at adding some type of chain system to limit the drop.
To get a position control on a Kubota, you have to go to the B2630 or an L.
According to my B2920 manual, there is a model B2320 DTN that has a position control valve.
/ Quarter-inching Valve #44
What disappoints me the most about Kubota's lineup is that there appears not to be a tractor that has both a floating MMM and position control.
When I use my sub-soiler to rip the dense clay that I have, the tooth is constantly pulled too deep and the tractor bogs down. I have to stop about every two feet, back up a couple of inches, lift the 3ph and start again. I like the floating MMM on the BX, yet no BX has position control. If I could afford it, I would like to trade up to a B. The thing is, if I am reading everything correctly on Build My Kubota, tractors like the B2620 and B2920 offer a floating MMM, but not position control, while the B2630, B3030, B3200, and B3300 seem to be the opposite: they have position control, but no floating MMM available. In the L series, those that offer an MMM are all ground contact, i.e. no floating MMMs available.
This issue (other than the money) is the main thing that has kept me from even considering trading up to a B. I just can't justify so much money for a bigger tractor when I have to chose between position control or a floating MMM. It seems like a choice one should not have to make. There ought to be a tractor that has both. That is the only way I would start thinking about how to save up the money, as well as start figuring how I'd talk my wife into agreeing to spend it on that.
Messick, Barlow, and other dealers who visit here: PLEASE tell Kubota there needs to be a B or L series tractor on which one may choose options for BOTH position control AND a floating MMM.
/ Quarter-inching Valve #45
I agree. There are other color tractors out there that have both now in that size range, but Kubota does seem so secure in their position that they still feel they can move you up to a more expensive unit to get the things you want. The older B2410 did have position control, but I heard that it was never a good seller. There is reasoning behind this from a manufacturer's standpoint, and I have experience working where the company was changing over to "The Toyota Principle" or "lean manufacturing", but it's best not to get me going on that one!
/ Quarter-inching Valve #46
I agree. There are other color tractors out there that have both now in that size range, but Kubota does seem so secure in their position that they still feel they can move you up to a more expensive unit to get the things you want....!
That's the thing, even in the more expensive Kubota models, you STILL can't get both position control and a floating MMM. I surely do not want to buy two tractors just to have both, though if I could afford an F series for mowing and an L or M for ground engagement (with position control) I would do that. But that's only in my dreams.
/ Quarter-inching Valve #47
I know it's hard to imagine, but some of us B owners (me for one) have no use at all for position control.
/ Quarter-inching Valve #48
:laughing: ... you must use your tractor in strange and mysterious ways.
/ Quarter-inching Valve #49
Front snowblower, mowing, loader work, subsoiler, middle buster, dragging logs, and towing a lawn sweeper. I don't own a single PTO driven 3pt implement yet, but maybe one of these days...
/ Quarter-inching Valve #50
...subsoiler, middle buster...
I am guessing you must have sandy loam soil because my subsoiler submarines (or technically subterraines) very quickly under the resistance of dense clay. A soil with little resistance would not induce such a reaction, however position control would be an immense help to my subsoiler in clay.
I almost am tempted to fabricate a set of adjustable depth gauge wheels for the implement. Does anyone know of a subsoiler with depth gauge wheels or some other plow that already comes with depth gauge wheels that could be modified to accept one ripper shank? If I could use such a device for ripping, I could upgrade to a B2920, which is the biggest Kubota to have a floating MMM, and use this alternative to position control. I wonder, how many of you guys use ground engagement attachments with gauge wheels and thus have no need for position control?
/ Quarter-inching Valve #51
I like Kubota tractors, but in my area the dealers don't wiggle much on price. I will strongly consider just buying a John Deere next time to get the position control in the same size tractor, and the floating mmm too. Roughly the same price around here. I would buy a Massey too, but they don't have anything in this size range, and are more expensive around here.
/ Quarter-inching Valve #52
...I will strongly consider just buying a John Deere next time to get the position control in the same size tractor, and the floating mmm too....
And that drive over deck that attaches without getting out of your seat looks very interesting. Anyone here know whether that particular one floats, or is ground contact only?
/ Quarter-inching Valve #53
I dont get it. Dont all MMMs have to float and have anti scalp wheels and allow for raising to travel.??? I certainly get position control - just not float vs non on mmm. :confused:
larry
/ Quarter-inching Valve #54
larry
On the BX series, and on a four digit B series that ends with 20, the decks hang suspended while mowing and the wheels only hit the high spots to prevent scalping (though you can lower it all the way if you want to). On the other B series and the L series that have an MMM, the deck has to be lowered such that its full weight is on the wheels when the PTO is engaged and the unit cutting. Many of us feel that the MMM that will cut while suspended does a better job on uneven turf as well as doing less windrowing when grass is wet and tall. To others, it doesn't matter. There is a lot re. this in the archives, in fact, here's a recent thread:
http://www.tractorbynet.com/forums/...75582-suspended-vs-ground-contact-mowers.html
I like suspended MMMs, but with Kubota, you can have position control, or you can have a suspended MMM. You just can't have both on the same tractor.
/ Quarter-inching Valve #55
I'm not sure that statement is correct. I had a B7800 and I am pretty sure the mower deck was floating (not suspended).
/ Quarter-inching Valve #56
Sure you can!
Set your gauge wheels all the way up so they won't ride on the ground (or to wherever you feel a good anti-scalp position would be for them), and then with your handy-dandy Position Control, set the deck height to wherever you like and it will stay there.
(Yes, theoretically it works, and No I'm not being completely serious. :D)
/ Quarter-inching Valve #57
Giles, pretty sure the QI valve works the same on the Bxx20s as on the BX's. To use the QI setting, you have to pull the 3PH lever in towards the seat while moving it up or down. There are QI stops that the lever will or should hit when you pull the lever in towards the seat that it will not hit if you pull it up or push it down normally. Just used my QI function last weekend to spread some mulch with my rake. I did many rapid, small adjustments using the QI feature to keep the rake level while the front of the tractor rode up or down some
Look under the fender at your 3PH lever and you should see the QI stops. The position of the stop is adjustable and sometimes you have to move them in or out to get the QI feature to either activate, or only activate for the proper amount of time. When set right, you pull the lever in and either up or down until you hit the stop, then return to neutral. Do this rather quickly and the hitch will move in small increments.
I would have missed this myself had a dealer not demo'd the QI function when I was SCUT shopping.
/ Quarter-inching Valve #58
No there is no "notches" on my control. The only aggrivating thing about my lift is the sensitive response. This especially true when lowering. It will basically DROP! IT IS TOO FAST!! but I will learn:(
/ Quarter-inching Valve #59
I think there is a valve down by your feet on the BX that you can close off to slow the drop of the 3PH.
/ Quarter-inching Valve #60
I will have to look at a Bxx20 series next time I go by the dealer to see what it looks like. The stops are little tabs that jut out into the path of the 3PH lever but you can't see them from the seat and you can't engage them without pulling the lever in towards the seat (at least on the BXs). Better yet, here's a pic of the back side of my BX 3PH levers. I circled one of the stops. You can see they are adjustable along the path of the 3PH lever by loosening the nut and sliding them in or out. I'm surprised your BX2320 doesn't have them since I thought they're required for the QI feature.
As for adjusting how fast it drops, like DelSc said, you should have a control know below the seat for rate of drop adjustment. I keep mine about a quarter to half turn past fully closed.
CASE TR340B SKID STEER (A64279)
CASE TR340B SKID...
2013 Nissan Pathfinder 4x4 SUV (A61574)
2013 Nissan...
1996 Sunflower 1543-38 Folding Disk (A63688)
1996 Sunflower...
2021 JOHN DEERE 331G SKID STEER (A62129)
2021 JOHN DEERE...
2002 WACKER RD25 ROLLER (A59912)
2002 WACKER RD25...
2019 Caterpillar 349FL Hydraulic Excavator (A61572)
2019 Caterpillar...
