BX24 diggin out stump
/ BX24 diggin out stump #21
The first 4 hours of a project like that are a lot of fun. After that...
/ BX24 diggin out stump #22
Just keep digging. At this point you are committed. Sometimes I keep digging further away from the stump so it's easier to get to the underside. You can also try to pull on it from different sides as well as pulling in a way that will try to spin the stump instead of pulling it out of the hole. If all else fails take your chainsaw, hose the dirt off the top of the stump, and cut straight down (if you look at the top of the stump it'll look like a pizza cut into slices). Then use a tooth or two on the backhoe bucket to try and split the stump so you can take it out in pieces.
/ BX24 diggin out stump #23
I really wanted to dig out a trench around tree and use the full length of tree to pull down with his cable.
The Safety Police won't like it, but that's usually the first option I go for, after a nice soaking rain. :thumbsup: There are some common sense practices to keep the tree from falling on you while you're digging its roots up, which I won't go into here, but if done right that stump will just pop right up out of the ground. Really helps with bucking too, since the trunk is "propped up" off the ground for you.
Option 2 (when option 1 is determined impractical/unsafe) is like the others said, make your cut as high up the trunk as you can safely reach.
... You can also try to pull on it from different sides as well as pulling in a way that will try to spin the stump instead of pulling it out of the hole.
X2. You'll need to get that good twisting motion going to break those taproots loose. :thumbsup:
/ BX24 diggin out stump #24
Be glad you have the tools for it. I attacked stumps with dirt scoop, axe and a highlift jack. Or just cut them with the ground using chainsaw and let them rotten away.
/ BX24 diggin out stump #25
I feel for you. I did an 20 inch diameter oak yesterday. Took about 2.5 hours and a sharp ax but I got it. Once you get a trench dug all around start digging under it to loosen it up. You'll get her.
/ BX24 diggin out stump #26
Reading this yesterday made me go out and survey some stumps I had.. probably only 6-8". 5 of them. I hit one with an axe and it chipped nice.. so I ended up chopping out all 5 of them... took about 4 hours, and was a good workout! And lets say the closer I got to the middle, the more rubbery it seemed to get..
At our old place we were getting a new septic. I had cut down a very large maple with about an 18-20" trunk. They agreed to take it out for me while digging the new septic with their HUGE backhoe (on tracks and everything.. it was one of the biggest I've seen).
It took him 2 hours. I think it was tougher than he thought. When he finally got under it enough to pull it up, it actually lifted the entire tractor at least a few inches off the ground, popped out the stump, and when the tractor came back down it shook the whole block! It was scary... lol..
Then they just left the stump in the yard... so a neighbor with an old 300 came over and tried to lift it to move it.. couldn't... but, he did end up pushing it with the fell down to a ravine which was nice to get out of the yard.
/ BX24 diggin out stump #27
I was fortunate with my oak stump. No tap root. Once I cut everything around I loosened the dirt under it and was able to pop it out. Moving it with the FEL was an adventure all its own. I nned to start bringing my camera with me when I work.
I finally got the stump to move. Basically I kept diggin and chipping away the dirt around the stump. I was able to use BH to wiggle it free, but its too heavy to lift. I tried to roll it, but its still too heavy. Its got about a foot of dirt stuck underneath the stump. Its time to reduce the weight, gonna cut the stump in half tomarrow. I'm too whipped to tackle it any further today. Hopefull I can cut most of the stump before chain goes dull from touching the dirt.
/ BX24 diggin out stump #29
Here's my stump vs. man and tractor pix. I found this old white pine to be the limit of the little BX. It took about 8 hours of digging and hand sawing the vertical roots under the stump that the bucket teeth couldn't reach to remove it from the hole.
No disrespect - I know there is a certain satisfaction of doing it yourself!! A CAT 963 could have done it (and buried it) in 2 minutes!
/ BX24 diggin out stump #30
Here are some pics of the stumps I removed in May 2008. The clump of stumps were a large cherry tree and also a tree of heaven. I hate those tree of heavens, they are an invasive species and grow worse then a bad weed!
Took me a while and also even used a come a long to tug on the whole mess.....
Craig
thanks guys for your comments. :thumbsup::D
/ BX24 diggin out stump #32
Thank you, Captain Obvious. :D
As long as these guys are having fun doing it, who cares if it took them forever and a day. I'm sure people would think I'm insane for some of the overly-ambitious tasks I've taken on with my "bigger" B.
And that's really the point. :)
:thumbsup: victory!! stump done and over with!! After cutting stump in half as much I could before hitting dirt, I ended up using bucket to crack it open. I was able to flip both halves unside down and use BH to scrape all the sticky clay off the bottom of stump and now its soo much lighter. The FEL could barely curl one half of stump, so ended up driving backwards all the way to resting place. The other half I could barely lift the stump few inches off the ground and take it to the final rest place.:)
The hole is now filled in and need to let it settle before planting grass. I am hoping we will get the rain on sunday help with settling of the dirt. I packed it down as much I could with every 6 inches of dirt I filled in.
/ BX24 diggin out stump #34
Ok Dieznuts I get it - Didnt mean to spoil anyone's fun. Believe it or not I was actually so dumb when I first started buying equipment I didn't understand what each piece was designed for and I needed to get work done (building a house). In the end, I always say when you learn something the hard way, you REALLY learn it. Learned lots about equiment and spent tons of money trying to save money - Just trying to pas some of my learnings along - Not trying to ruin anyone's fun!
/ BX24 diggin out stump #35
Good work Radioman,
Sticktoittiveness Pays Again!!!:thumbsup:
Here's some pics of my Stump Adventures.....Part of me just wanted to see how deep I could dig:laughing:
Good work Radioman,
Thanks wdchyd! I see you had fun as well ! :D
/ BX24 diggin out stump #37
Radioman....
Is that an old Mac 10-10 in the background there in one of your pics? I have one my Dad bought in 1965 and that saw is as strong today as the day he brought it home. They truly dont make them like that anymore!!
Good job on the stump, its a real feeling of pride when you finally get it out of the ground!
Craig
/ BX24 diggin out stump #39
Plus a few hours of transport, unloading and reloading.
King Kutter 7' Lift Kutter Rotary Mower (A66408)
King Kutter 7'...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
Husqvarna K750 Chainsaw (A65579)
Husqvarna K750...
AR500 Coyote Target (A65640)
AR500 Coyote...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A64194)
2015 GMC 3500 HD...
2018 JOHN DEERE 60G EXCAVATOR (A64277)
2018 JOHN DEERE...
