Price Check All set to buy !
/ All set to buy ! #1
Scrambler82
SoCal
Mahindra Max 28XL, HST, TLB
The quote of $17,950 is for a Sc2450 TLB w/3 pt Hitch Hookup, 12" BH Bucket, 48" Box Blade and Grader Blade ?
Asking for a Block Heater and wheel weight, either loaded tires (which are small) or wheel weights. I am sure the loaded tires are less expensive than the weights so that is what he will offer.
I can get an Sc2450 as above plus a few little extras for $16.9K, a $1.5K difference, just one state over, 500 miles.
I am thinking that it will be better for servicing if I buy local and it might keep the dealer in business, might be worth the $1.5K.
Any opinions ? LoL
/ All set to buy ! #2
Nice looking rig.
Did you shop for other brands and price.??
Regardless, I would buy local. In these times, buy everything local.!! Just might save your job.!!
/ All set to buy !
Nice looking rig.
Most of the New England Dealers didn稚 want to bargain; I had to go over the border to NY to get a low price.
Pricing - JD too much money; MF 2400 Series, too much; Kioti CK20SH too much; BobCat more expensive. all of these tractors they were asking over 20K$.
I am trying I have asked for quotes from all of the NE Dealers and as I said it is like they have all of the business they want,, they will not talk on price; at lease to a newbie.
It wasn稚 until I got this quote from NY that I really started to see the hard line on pricing.
/ All set to buy ! #4
If I may.....What was the price on the John Deere.??
How far from your home is the dealer in New York that gave you the best price.??
/ All set to buy !
$25+K, after talking for a while down to $23.5K
CCYanmar $16.5K
I know no contest.
200+ miles, not completely sure, based milage i=on the delivery quote.
I will talk to him again and then to eCCYanmar corp Office to see where I can get Service without a hassle in NE.
ltr
/ All set to buy ! #6
That's a lot of bang for your buck. Not sure about the other brands, but that isn' t the same size machine as the Kioti CK20 or Bobcat equivalent. The K/BC is a bigger, more capable tractor. So, it's important to know that you are comparing apples to apples, which isnt' always possible. In the end, though, if the CC does what you need done, then it's a better choice as you save some money. It seems the favorite in that size machine by many is the MF. Did you look at those?
/ All set to buy ! #7
Just curious what model Deere did you price? The price on the Deere seems WAY high after looking at list price from the Deere website.
/ All set to buy ! #8
What I've been seeing for several months now in my small area of New England is that many dealers have low stock on tractors and attachments and their parent companies didn't anticipate the higher than expected interest level in this economy to keep an inventory. That being the case and the 0% financing incentives has many dealers in my area holding the priceline up more than one would expect. That does not mean you can't find a dealer willing to move things a bit faster through pricing but in my parts they're hard to find.
/ All set to buy !
I believe the JD was a 2320 I like them but CCY appears to be the way to go.
The Dealers in New England are all holding the prices high on most tractors, could be what you said about Supply and Demand. The local Supplier for CCYanmar’s said he doesn’t have a 2450 in and stock but will next month (Mid-Aug), only problem if he gets one then there will be no price breaks. Also, most Dealers I talked to think the Factory Incentives are enough, NOT for me !
I am a little worried about the capabilities of the little Sc2450, still thinking.
My needs are low in HD Duties, a couple of trenches, reducing the height and leveling an area about 10K sq ft, dig out for a sunken patio area and fire pit, so a little tractor may be OK if the Sc2450 is up to it.
The $16.5K price is still good and a drive to NY, along the MA Border isn
t too bad; just need to find some money.
/ All set to buy ! #10
I can't comment on the other brands but if you price Deere you should get a discount of atleast 10%. Most things I buy are discounted from 15% or better.
Sales are low and the economy is in the toilet, so anyone making purchases in hardgoods should shop wisely.
/ All set to buy ! #11
Make sure you are comparing apples to apples. The Sc2450 appears to be much closer to the Deere 2305 than the 2320. The Sc2450 and the 2305 are both subcompacts with similar specs. The 2320 is larger, has more capacity and isn't in the same class.
The Cub may be your best choice but if you are trying to compare prices you need to make sure you are comparing the same class of tractors.
/ All set to buy !
Yes you are correct but I was going on the BH attahment.
CCY 2450 is part of the package.
Not sure if the 2305 will take a BH and the noise the little tractor makes is more than the Kioti and the CCY.
The Kitoi CK20 is nice but pricey and the BH needs extra valving and who know what else.
The CCY comes all set and it is relatively more quite than the JD.
/ All set to buy ! #13
I couldn't comment on the noise, never seen the Cub. The 2305 does come with a BH package. It's a nice setup I had a chance to try one when I bought my tractor.
/ All set to buy ! #14
Any opinions ? LoL
How about if you go to your local dealer and show him the price you can get it for in NY? He might match it, or at least get closer....
2450 is a nice little rig. I drove a 2400 around and really like the shift-on-the-fly.
Good luck!
/ All set to buy !
Good luck!
Ben there done that !
His response was, this guy giving them away !
I e-mailed the local guy and asked him when a 2450 would be in, three or four days ago, he will not respond at all. I even said I have thought over what he said about local service and thought it would be a good idea to buy local.
That is the way the ball bounces.
/ All set to buy ! #16
His response was 的s this guy giving them away !
I e-mail壇 the local guy and asked him when a 2450 would be in, three or four days ago, he won稚 respond at all. I even said I have thought over what he said about local service and thought it would be a good idea to buy local.
That痴 the way the ball bounces.
Well if he's not responding that would seal it for me. When I lived in MI, I had a Cub dealer 1.5 miles from my house. I went there 3 times for small parts. These guys were very slow, and I knew more about the machines than them. After the 3 attempt (strike 3) I vowed to never go there again. I order my parts from other dealers and actually get a better deal even with shipping.
None of my Cubs have ever been in the shop for servicing or repair....so I prefer to shop for price.
I would pocket the $1500 and buy in NY....
/ All set to buy !
X2 on that…
The funny thing was when I asked for different pricing vs the NY Dealer, I told I was going to the other dealer and he played the Service Card.
I figured he would come back to me when I said I have thought about his comments on local purchases but No!
Too bad, I will be borrowing the next door trailer and see take a trip.
ltr
/ All set to buy ! #18
The Sc2450 TLB compares directly to the much more common Kubota BX25, MF GC2410, and JD 2305. Have you looked at these? Pricing should be very close or lower than your local dealer has quoted.
/ All set to buy !
Yes I did also check the same line of tractors but what I did was go out, look at what I liked and then compared what each had to offer vs price.
As it goes I ordered a CCYanmar Sc2450 TLB.
My local dealer wouldn稚 get back to be even when I kissed his @ss telling him he was correct in the service thing and doing business locally.
I ordered the Tractor on Sat, they were busy so I will finalize the order tomorrow and it will be delivered 250 miles on Friday, all for $1500 less than local and the Dealer is throwing in a lot of small items free.
I will now need to find a Service Dealer other than the most local guy and then all should be good, his loss. I am glad for him since he can afford to refuse sale and service money.
I can do the basic stuff myself but if it needs more than that I will have to travel a little.
/ All set to buy ! #20
looking forward to pics and a full report!
