3 ph lowering speed knob jammed
/ 3 ph lowering speed knob jammed #1
sailorman
Southeast La.
Kubota 2320
B2320 tractor - knob located below seat will not hand turn in either direction. It is set so that the 3ph will raise and lower. Knob has worked in the past, but I 've not tried to turn it lately until yesterday. I 'm reluctant to use any kind of wrench at this time for fear of braking the plastic knob or twisting the metal shaft. I 'm a small man and can 't budge it either way using both hands. Suggestions to safely free up knob or an explanation of what might be jamming it please.
/ 3 ph lowering speed knob jammed #2
Can you access where the adjustment goes into the tranny housing. If yes try spraying some pentrating oil in that area. Suspect it has been a few weeks and it may have rusted up. My BX does this and so far a little liquid wrench has worked.
Roy
/ 3 ph lowering speed knob jammed #3
Have you tried lowering the control lever, this will take some pressure off and may be eneogh to get you out of trouble.
Roy
Possibly, but its gonna be tuff. Everything is covered with plastic cowling or seat none of which I look forward to removing. Maybe with a straw on wd40 can and a chance aim.
3ph is lowered and implement is on the ground. Do you mean keep the lowering lever in the lowering position instead of neutral point ?
/ 3 ph lowering speed knob jammed #6
I mean all the way forward or lowest position to let pressure off, may help. If it were mine and it's not, I would use a pair of adjustable pliers and a rag to prevent marring the knob and clamp onto the knob and apply a small amount of force in the counter clock wise direction to see if you can budge it loose. It shoudn't take much if the pressure is off. Good luck.
Its a mind boggler for me. I put lever in full down position. No luck. I lubed as best I could with wd40. No luck, but am letting it soak a bit. Next step will be gentle coaxing with a wrench or channel locks. If I do get it free, I will remember to exercise the knob from time to time. If I don' t free it, I 'll have a beer and ponder on it :D .
/ 3 ph lowering speed knob jammed #8
I have a BX22 and sometimes have trouble adjusting the height but it seems to me that raising the deck frees it up. Probably need to oil mine too.
Kim
/ 3 ph lowering speed knob jammed #9
The knob will pull straight off and will give you better access to spray, then maybe use vise grips to work it free after it soaks for awhile.
I wondered about how to get knob off. Couldn 't find a set screw or anything else keeping it on shaft. It must be on the shaft pretty tight. I know I ain 't strong enough to pull it off without some sort of tool.
I used a small pry bar and carefully got it to move then it came right off.
Thanks. I 'll try it. Of course I 'll be careful of the rule " if it ain 't broke, fix it until it is ". :D
/ 3 ph lowering speed knob jammed #13
same problem on my l3400 when delivered new. I put penetrating oil on it and let it soak a few minutes. then took a set of channel locks with a rag, and started to move it back and forth just a fraction at a time.. it soon loosened up and works ok now. put some spray white lithium grease on the shaft and kind of rubbed it in with my finger to hopefully keep it from doing it again. It is not something I adjust very often, but it was way fast when I got the tractor. Good luck
James
K0UA
Yep, I been lettin' it soak all day ( if I managed to hit the sweet spot blind ). Gonna give it another shot tomorrow. Too many mosquitoes out right now.
/ 3 ph lowering speed knob jammed #15
I have wondered about the mechanics of that knob. I thought it operates a valve and that is how the lowering speed is accomplished. Is that right? If so, what would cause the valve to jam up?
That 's my understanding. As far as jamming I think junk in threads of shaft if there are threads, light rust, failure to exercise it once in a while. If I get it freed, I will give it a couple of turns from time to time to keep it clear and operational. Gonna give the unjamming another try today with some gentle coaxing via a wrench.
Ok. Problem is solved, but leaving with me a new slight worry problem.
For others that have had the porblem here 's what I did. Sprayed wd40 blindly best I could on shaft base. Let sit over night. Grapped knobed and gave it a slight giggle left, right, up, and down. Freed to turn.
Now the worry. If I grab the shaft/knob I can wobble it slightly like it is loose in the hole. I don 't remember if it was that way when I got it. I would appreciated if some one with a similar knob could let me know if they have the slight wobble. I 'm gonna start it up and check to see if I get any hydro leaks. None right now, but machine has not been run.
So, instead of cursing at it, laugh at it?
Who knew!
:D
In my younger years I wouldn 't believe I actually typed that, but now I 'm old and wise and realize I have senior moments. Ya know a giggle or two might have helped me while I was worrying about the problem :thumbsup:
/ 3 ph lowering speed knob jammed #20
I had the same problem on my B7800. Used the same process you used, except I removed the metal shroud that covered where it went into the rear end in order to gain better access. I used vise grips to grasp it and get it moving.
Yes, mine has a little wobble in it. That has never presented a problem (leaks).
I "exercise" it regularly. As a matter of fact, you post has reminded me and I am going to do it now.
