Mowing Repairing Idler Pulley
/ Repairing Idler Pulley #1
Carl1438
John Deere LA145
I have a John Deere LA145. The idler pulley has a lot of wiggle (play). I purchased a new idler pulley and the bolt but I still need the center part of the ball bearing. Does anyone know which part(s) I need to purchase or how this ball bearing center is assembled and fastened to the deck? I cannot seem to find the specific part on the JD Parts website exploded view does not indicate a part number.
/ Repairing Idler Pulley #2
Hello Carl1438,
From what you explained,it seems there should be a bushing that goes into the center hole of the idler,and the bolt goes into that.
Greg
I have looked on the JD Parts Catalog website and in Catalog 9744, Grid D12, Section 85, Page 6 there is an exploded view corresponding to my mower deck. The idler is #3 on the key but the assembly it mounts to is not indicated as a part. There is another idler (#2 on the key) that points to an assembly with a bushing (#9 on Key) but it appears to be a different assembly. Is this the same bushing I would need?
/ Repairing Idler Pulley #4
I'd go back to the parts man at the dealer. There may have been a bushing that was lost in the packaging.
Another clue might be looking at the old idler that you are replacing.
Or are we talking about a non-Deere idler pulley?
/ Repairing Idler Pulley #5
The assembly that #3 mounts to is welded to the deck. So no separate part #. The #2 idler is mounted to the bracket #10 that is for keeping the belt tight with the spring shown. The #9 bushing is used to fasten the bracket #10 to the deck with bolt #8. That bushing isn't in contact with the idler #2.
The axles for the three idlers (#2 and #3) have the bushings incorporated. If there isn't a tight fit then a measurement to determine if the axle is worn or if the idler has the wrong center diameter would be necessary to find the problem.
In re-examing the entire deck, the bushing fits all 3 idlers but the bushing for one of the #3 idlers that I am trying to replace has broken and I can not figure out how this part is removed from the assembly. Any ideas?
/ Repairing Idler Pulley #7
Sorry, but I don't understand how a bushing is "broken". Could you post a pic?
Almost sounds, to me, like you are talking about the stud (axle to the pulley).
Yes, that is correct the stud is broken. How would you go about removing it?
/ Repairing Idler Pulley #9
I suspect they are welded in place to the bracket that is also welded onto the deck.
Cutting torch, or cut it off, drill it out, and replace with a bolt with the bushing of the correct size to slip over the bolt, slip into the idler bearing, and be the right length to allow tightening. For sure won't be a single part that can be ordered.
Can you come up with some measurements what the stud is and what the bushing should be? Diameters and length?
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A61573)
2013 Ford F-550...
Kubota L5030 (A64126)
MASSEY FERGUSON 2605 TRACTOR (A64276)
MASSEY FERGUSON...
1000 GALLON NURSE TANK TRAILER (A64276)
1000 GALLON NURSE...
2022 JCB 509-42F TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42F...
2019 Chevrolet Tahoe SUV (A61574)
2019 Chevrolet...
