Generic gasoline engine tuning question
/ Generic gasoline engine tuning question #1
284 International
International Harvester 284
Hi, I have a gas IH 284 that really lacks power. When it attempts to pull a load (even starting itself out with no implement or trailer) the engine bogs, stumbles, and runs roughly. With no load, it runs smoothly, but it is difficult to throttle up: opening the throttle, even with no load, makes it stumble.
I have replaced the spark plugs and fuel filter. The spark plugs were sooty and dark black (including the new ones after less than an hour of use), and the fuel filter was free-flowing. I have replaced the air filter, and even tried it briefly without the air filter, all for no change.
I'm sure these symptoms mean something to someone with more knowledge than me, but I'm out of ideas. What should I try next? Thanks in advance.
There is no visible smoke that I can tell. That doesn't mean it's not there, obviously, just that I haven't seen it. The exhaust is re-routed to exit under the tractor, so it's difficult to see. When cold, it won't start or even run once started at anything other than idle. I need to let it idle for 4 to 5 minutes in order to throttle up. Throttle up unless done EXTREMELY slowly results in a popping death of the motor (it surges a bit, pops, then dies).
Will changing the float height affect the richness of the mixture to this degree?
Egon, sorry to sound ignorant, but I don't have a service manual. How do I change the jetting? Does the entire jet get replaced, or is there a mixture screw?
/ Generic gasoline engine tuning question #6
I am by no means an expert but it sounds to be like a governer problem.
I am not familiar with the 284 but trace your throttle cables from the lever and from the carb. They should lead you to the governer, which could have some levers and springs. Make sure that the springs arent missing/unhooked and that everything looks ok.
The governor theory is interesting. How would that make it run rich? When the tractor is driving, if there is ever any change in load, it bogs as the governor opens the throttle. I don't know how to isolate the trouble, but will check the governor.
/ Generic gasoline engine tuning question #8
I'm not familiar with your carburetor so there are two of us. Usually there are two jets, idle and high speed jet. They are usually little grub screws going through a spring. Some you turn in for more fuel, others you turn out. I'd suspect yours turn out. Most have a proper operating range one and a half turns from closed??
If you adjust on these screws always keep track of what you did or you will end up like I always do not knowing where I'm at and having to start from scratch. Sometimes opening them a little will let junk out of the jet or make up for varnish etc.:)
A carb kit usually has new jets and seats.
Also go easy on them when closing as they can be damaged.
I'll try and find a picture to post.
http://faq.ninja250.org/wiki/How_a_carburetor_works:_Carbs_explained
/ Generic gasoline engine tuning question #9
On the same tolken, a plugged jet in the carb wouldn't allow it to dump more fuel and make it run rich either. If it is indeed running rich, that means either too much fuel or too little air. But the symptoms you descrive sounds like a governer(aside from the black plugs). Not wanting to throttle up and bogging severly under load sure sounds like a governer.
But I am no expert. I am better with autos and they dont have them. I cant tell you what to look for or how to adjust, just give it a once over and see if everything looks in place.
How would the governor be different than the regular hand or foot throttle? Again, I'm semi-ignorant of the operation of the mechanisms at play, but know they exist. What can I do to test or inspect the governor? What should I be looking for?
I'm willing and able to rebuild the carburetor. I am experienced and comfortable with motocross dirtbikes and their components, but while the fundamental principles are the same, the intermittent, highly variable rpm range is a lot different than the constant load and steady rpm of a tractor. Where can I get a carburetor rebuild kit?
/ Generic gasoline engine tuning question #11
Before you delve into the carb, have you done a complete ignition tune up? you mentioned a plug replacement but what about coil, points, rotor, cap and wires? Timing? All these can create the conditions you mention. Be sure you have the right heat range plugs also as cold plugs won't have the hot spark necessary for effecient combustion.
Start the tractor and pop the hood up in the dark of night and look for spark leaking from the wires, bad wires will show spark leakage in the dark.
Check for water in the fuel & add a good fuel filter if one isnt present.
After a complete ignition tuneup if the problems still exist, then look at a carb rebuild. Many times carb's are the first suspect when in reality lack of good ignition creates false symptoms.
I haven't done any other adjustments or tuning except the new plugs, air and fuel filters. The fuel is clean (I've even run it from a separate container other than the fuel tank) and fresh. I don't know what heat range plug is correct, since I can't find any of that information online, but put what it had previously had. I haven't checked the ignition timing or anything else. The engine doesn't run roughly as one does when a plug or plug wire is bad, it feels like a fueling issue, but I can't rule out ignition woes. Do these distributors have a vacuum or mechanical advance built in besides the physical timing advance of the distributor setting?
/ Generic gasoline engine tuning question #13
the most basic of tests for a rich/lean condition is the choke. get the tractor to the point where you are going to put a load on it and cause it to stumble. just as it is stumbling, hit the choke. if the choke helps the problem, then it is most likely a lean condition, and if it stumbles/gets worse, then it is most likely a rich condition.
i know there was mention of soot already, indicating a rich condition, but it's always possible that it's running a little rich at low speed/idle, where it spends a lot of its time, but may be a lean condition as it goes toward high speed.
/ Generic gasoline engine tuning question #15
Tractor runs. Twiddle with the carb jets.:)
if you choose this approach, make sure to leave any implements raised a little. that way, if you end up making it so the tractor will not run at all, then you will at least be able to push it out of the way if needed. :D
Lost Cause, that's the best advice I think I've heard in a decade or more. (To leave the implements up) The choke makes it worse, and is unnecessary to start cold, even when sitting overnight. To be fair, it gets "down" to only 60 degrees or so here, so "cold" isn't COLD.
/ Generic gasoline engine tuning question #17
TBNer's have given you good advice however my 2 cents are to get a manual. They're available online.....somewhere..... keep looking. If you want to delve into this without look for similiar auto engines or similiar carbs. You might be able to get the specs. to use as a baseline. Also like someone said check points, coil etc. Insure that you have the correct parts (coil etc.). Clean everything as best as you can. Any dirt in the carb will cause problems. Also insure that all hoses, filters and tanks are clean.
Good luck.
/ Generic gasoline engine tuning question #18
I just went thru much the same thing with an old Kohler motor. My mechanic explained over the phone, that the idle jet was too rich. When you tried to speed up or increase the load, it would start to flood out. It will be the adjustment screw closest to the engine (if you have a choice). Its between the throttle plate and the intake manifold in the fuel circuit...
Thats about the extent of my carb knowledge......learned over the phone
RPW, I didn't intend to come across as ungrateful. Thank you for letting me know it seemed that way. I apologize. To any who took it that way, I'm sorry and it wasn't on purpose. I really appreciate the tips.
I've got several directions to go now. A trip to Napa yielded nothing in the way of parts, for either the tractor itself or equivalent parts from any Mazda brand vehicle listed. Does anyone know of a source for any parts at all, or, better cross-referenced parts to other applications, if any? There isn't a Case-IH dealer for nearly 200 miles from me.
I think I've managed to find a manual at a semi-local library, of all places. I will pick it up tomorrow (If it actually is for this tractor) and proceed from there. If not, I guess I'll start with the carburetor, so after fiddling with the jet needles (I'll write down and/or mark their starting position) will disassemble and clean everything. Then, pull the points and condenser, replace the coil, wires, and get the next warmer range of plugs. If that doesn't fix it, I guess I'll just be stuck. Thanks again to all who have responded so far. Any other ideas or suggestions?
/ Generic gasoline engine tuning question #20
My first action, from what I understand, would be to check the points and condenser. Isolate the points and check the resistance- should read zero ohms. If you don't know the point gap, I would set them between .017" and .020". You may be able to polish the contacts with fine (4oo grit or finer) sand paper or a burnishing tool (for the old timers). Always clean the points after you set them. I wouldn't replace the coil unless correcting any problem with the points and condenser(replace) failed to resolve the problem. Coils do go bad, but in my experience, not very often.
The carb could be the problem, but I would suspect that its more likely to be ignition. If I'm wrong it certainly would not be the first time.:laughing:
Good luck:thumbsup:
Jim
JMR mini trailer mover attachment (A61567)
JMR mini trailer...
Champion Vibratory Roller (A60462)
Champion Vibratory...
MISCELLANEOUS TIRES (A63569)
MISCELLANEOUS...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
1986 Ford LN8000 Fertilizer Truck, CAT 3406 Engine, Ag-Ready Workhorse (A63118)
1986 Ford LN8000...
2018 VERMEER BC1000 XL PORTABLE WOOD CHIPPER (A63276)
2018 VERMEER...
