Self made attachments
/ Self made attachments #11
Well, since this is the ONLY attachment I've made so far, I consider it the "best"!! ;)
/ Self made attachments #12
This is the 3 that I use the most. The carryall or weightbox I use more the others just because I use it with the forks and loader bucket. The trailer has move alot of dirt in the last 7 years, but it sure seems small by the end of the day.
/ Self made attachments #13
So far my newly made water buffalo to water our trees during dry winters will be my most used homemade implement. I'd rather wrestle with 20' feet of hose versus 300'+ of garden hose as I did in years past. Fully loaded, it weighs in around 1,400 pounds, and and my 3PH has a 1,700 pound rating.
/ Self made attachments #14
Made from scratch?
PTO Air compressor.
3PT hitch.
FEL-QuickHitch adapter.
Potato 'hiller'
Light duty ripper
Currently in the works....
PTO Generator
PTO Leaf blower
Currently pondering...
PTO trash pump
rotary trencher
'slicer trencher'
/ Self made attachments #15
I did a little modification to a big hydraulic powered Spring toothed harrow on wheels to suit my needs....it had been sitting for probably 20+ years when I was giving the thing.
I had to cut in to pieces to move it on my trailer.
/ Self made attachments #16
The harrow doesn't look that big; is your trailer that small that you had to cut it apart and weld it back together?
I found it interesting that whoever made it used C-channel to fabricate 'square' tubing. I'm guessing they had a lot of channel on hand when it was made.
/ Self made attachments #17
mjncad,
That is a great attachment. If I plant one more tree, I'm going to need one. I especially like the pallet fork slots and the tool tray.
Is the frame made from tubing?
/ Self made attachments #18
That picture is after the mod.....it was about 4 foot wider and had hydraulic actuated axles and wheels.
/ Self made attachments #19
mjncad,
Yes; but I would do it differently to minimize the grinding of welds to make sure the tank sits flat on the frame. Grinding welds sucks.
Thanks for the clarification.
/ Self made attachments #20
Probably my favorite although not most used is the grapple:thumbsup:. SS QA and rear receiver hitch are the ones I use the most. Forks also; grapple connects to the forks:cool:.
Sorry about the snow in the pics; kind of depressing I know:laughing:
1007 (A61166)
1007 (A61166)
500BBL WHEELED...
TANK MANIFOLD (A60736)
2021 JOHN DEERE 6145R TRACTOR (A59823)
2021 JOHN DEERE...
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
2015 MACK GU713 T/A DUMP TRUCK (A59823)
2015 MACK GU713...
