BX25 with Leaking Battery
   / BX25 with Leaking Battery #1
jster804
Galveston County, Texas
I pulled the battery out of my 16 month old BX25 last week so I could better access the radiator (clogged up with dog fur but that's a whole 'nother story) and found a little bit of wet and corrosion below the battery! What the heck? My question is what battery, other than Kubota, will work in this tractor. I've been told that the physical size is a "Group 26R" but I need to know how many Cold Cranking Amps I need. What is the original battery rated at? While I'm at it why are the Kubota batteries around $200? Thanks.
   / BX25 with Leaking Battery #2
Kubota and no other tractor maker builds batteries. They use whatever type their electrical vendor supplies.
To replace your battery measure the H- W- D and go to anyplace that sells batteries.
By the HEAVIEST for the money battery that fits your dimensions.
The cold cranking amps can artificially be increased by making a very porous lead battery. An increased CC amp battery is NOT necessarily a better battery.
WHen buying a lead acid battery get the most lead for your $$... It will be more durable and deliver more amp hour service ... KennyV
PS ... you should be able to get a better battery than the OE for less than $75
   / BX25 with Leaking Battery #3
I don't know about the size for the 25 but I put the old one from my wife's 2003 wrangler in it my bx 23 when the 23 died this -+ put the posts away from the hold bracket which was really close in my opinion.
Now they are now on the back side of the battery and put the new one in here jeep.:D
tom
   / BX25 with Leaking Battery #4
A couple of years ago, my brand new B2630 had a leaky battery. At 50 hours, the radiator and all the hydraulic cooling lines had all the paint eaten away. Battery tray severely corroded. I disassembled the whole mess, cleaned, repainted and replaced the battery with an Optima sealed battery. Two years later, no problems. Couldn't be happier. I don't know if these little tractors overcharge the batteries or if it's just the bouncing around, but the problem is fairly common. John Deere sells a battery box to contain their leaks - terrible 'fix' in my opinion.
You can find other sealed batteries besides the Optimas as well. My Optima was purchased on Amazon.com for $141.00. You can ship these batteries as they are sealed.
   / BX25 with Leaking Battery #5
You might make sure it's not overfilled. On my battery I filled it up to the bottom of plastic height indicators inside the battery cells. That turned out to be too high. Need to use the line on the outside of the battery. When it was overfilled some acid came out the overflow tube, once I got the level right it stopped.
   / BX25 with Leaking Battery #7
I just went to walmart and got what fit it the space
   / BX25 with Leaking Battery #8
cool, glad you found something. maybe you could post the model/part number you bought so we know what size will fit? How does it start now? same as before I assume?
   / BX25 with Leaking Battery #10
Some batteries may be rated for rougher service than others.:)
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2015 Volkswagen Passat 1.8T SE Sedan (A50324)
2015 Volkswagen...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
3 pt Aer-Way (A50514)
R&G Trailblazer 1000Gal 28% Applicator (A52349)
R&G Trailblazer...
2019 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2019 CATERPILLAR...
