Buying Advice CK20S HST, 216HST, or something else?
/ CK20S HST, 216HST, or something else? #11
Does anyone know how the loader/backhoe abilities compare between the ck20s, Mahindra 2216hst, and JD 2320?
Kioti CK20S loader (KL120) vs. Mahindra 2216 (ML104)
Lift capacity: 1074 lbs vs. 915 lbs
Lift height: 88" vs. 76.5"
Breakout Force: 1511 lbs vs. 1828 lbs
Rated hydraulic flow: 7.6 gpm vs. 5.8 gpm
I'd list the John Deere's specs but their site is about as useless as their salesmen and overpriced dealers...
Every tractor model gives a "Deere Models not found" error when trying to get the specs of the 200CX and 200X loaders. For such an overpriced company you would think their site would be better.
/ CK20S HST, 216HST, or something else? #12
Here are the specs for a JD 200CX
200CX
Lift capacity: 800lbs
Lift height: 73.4"
Breakout Force: 1513 lbs
Rated hydraulic flow: 5.6 gpm
Thanks for the loader specs guys, I'll also take a look at the CT122. Unless the economy starts doing a lot better this summer I may have to postpone any purchase until spring... Research doesn't cost anything though! Thanks.
/ CK20S HST, 216HST, or something else? #14
Wow time flies...
Spring is here!
Are you ready for your new Bobcat!:D
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
2007 Sterling 360 COE 40/45 Box Truck (A59230)
2007 Sterling 360...
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
2019 Dodge Charger Sedan (A59231)
2019 Dodge Charger...
