4x20 Hydro Top Link...
/ 4x20 Hydro Top Link... #1
nmu98
JD 5203, JD 3720, JD 4110, JD 445, IH 1586, IH 886, IH 404......
Is this hydro top link to short for a 4520 cab? I already have it on my 3720 and I hope for it to work.
CCM -
Cat 1- 18-26.5" w/ check valve- 2" Cylinder
I think its one up from what most people put on the 3x20 seires.
Thanks
/ 4x20 Hydro Top Link... #2
Did you check the CCM website to see if that's the cylinder that they offer for the 4x20 series?
2" with 8.5" of travel -- sounds very adequate to me. I'm fairly certain that the hyd toplink on my 110 is the same as the 4x20 counterpart and it's not larger than your current one.
Don't know about overall total length, though.
AKfish
/ 4x20 Hydro Top Link... #3
CCM -
Thanks
I used the hydraulic toplink from by 3720 on my 4520. Worked fine. I would guess the 4x20 series might use 1" more length compared to the 3720 but I used a quick hitch on both and felt the cylinder on the 3720 was just a bit long. It is rare to never that I feel the toplink is too long and occassionally wish mine was a bit shorter.
AKfish
I did look at CCM's web site, but i did not see them recomending it for any tractor. I did do some other searches here and found this one to be the one people use. I really had to dig to find it though...
Great. Thank you!
/ 4x20 Hydro Top Link... #5
When I ordered from CCM, they had two lengths. I got the longer one for my 3320 since I had Pats easy change. It works fine. JC
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
NEW Rachet Tie Downs and Flatpack Tool Box (A62679)
NEW Rachet Tie...
2014 FREIGHTLINER CASCADIA T/A SLEEPER TRUCK TRACTOR (A59914)
2014 FREIGHTLINER...
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63689)
2011 Peterbilt 6x4...
Lockers (A62613)
Lockers (A62613)
