mini ex thumb
/ mini ex thumb #1
bcantell
Member
Brimfield, MA
Bobcat 873, Mini Volvo EC25, SkyTrac 7038
Newbie here. I'm a building contractor and do some limited landscaping. I bought a really sweet Volvo ec25 mini excavator this spring and she has been excellent. I put a TAG thumb on her and hooked up the hydraulic lines (one metal line was extended by the factory to the end of the boom, and the return metal line I had made locally and installed. I had soft hoses made also.) It works fine but the thumb won't stay in place when retracted. It worked perfectly for about three weeks, then started moving down a little bit and now won't stay in place at all. The company that sold me the TAG tells me it's most likely not the hydraulic cylinder but the valve spring in the valve body (???) I checked out the valve body and the valve that runs the thumb is different in that it does not have a small hose at the top of it. I'm wondering if that is some kind of check valve system and Volvo doesn't include it in the auxiliary line. One buddy told me to change the fluid and filter first. Any ideas??
/ mini ex thumb #2
Welcome to TBN:D
Sounds like the seals are leaking/bypassing internally in the cylinder. Try disconnecting the cylinder and see if it holds position.
/ mini ex thumb #3
The valve that controls the aux is probably a motor spool valve. So in the neutral position, the cyl will try and equalize or move due to the weight of the grapple.
Maybe aux spool leaking.
Did you install new or used thumb cylinder?
What do you mean about the small hole at the top of the valve?
How about a picture of your thumb installation.
/ mini ex thumb #4
Then explain this;
/ mini ex thumb #5
Welcome to TBN:D
Do you mean disconnect the cyl from the thumb, or disconnect the hoses from the cyl. What do you hope to get from that.
I would extend the BH and let it rest on the thumb to see if the cyl is leaking internally. If the cyl is leaking, it will try and equalize. If the spool is leaking, then the thumb will collapse all the way.
If you are not satisfied with the leak rate, then put a pin in the thumb to keep it up, or repair cyl or valve as necessary.
/ mini ex thumb
JJ & Kennyd, thanks for the posts. The Tag thumb was new about two months ago. The mechanic at the shop (not a Volvo shop) were I bought the machine and thumb, believes it's in the valve. I installed the thumb. The machine is out working this weekend but first chance I get, I'll post some pics of the valve body. The valve is different from all the others so I haven't swiched the hoses to test the cylinder because of that reason. I called the local Vovlo service and they really were not much help, basically saying "bring it in"
/ mini ex thumb #7
Your hook on the bucket is a good idea.
Is there a name or number on the valve?
Can you push or pull on the thumb with the power off, and if so, what happens. The cyl may be to tight, but try and see if you can move it.
/ mini ex thumb
JJ
Yeah, the hook on the bucket is very handy. The pic is of my valve body. the valve that runs the thumb is the one to the right of the single yellow capped one. (don't know what the caps are) It's run by a cable. The two to the right of it are for the tracks, also run by cables. Do you know what the tubes coming out of the tops of the other four do? This is all new to me but it's cool to try and figure it out. Thanks for your help
Bill
/ mini ex thumb #9
The lines coming on top of your valve body are pilot lines to push the valves open or close. These would be coming from your joystick.
The valves with the yellow caps, Im pretty sure are Secondary Relief valves or circuit relief valves they may also be called.
The Secondary relief valves are used on some functions ( especially diggers ) as they come under some extreme forces. A circuit or function that is not being used at the time, ( even only for a slight bit of time ) is not open back to the Main relief valve. Therefore when that circuit comes under some extreme forces, and the hydraulic pressure spikes up, then secondary relief valve will open up to dump some fluid back to tank.
The seconday relief valves is set lower ( not by much ) than your main relief valve.
As your Thumb circuit does not have this Seconday relief valve, then I would not worry about it with it falling down. However if it did, then I would be checking this out.
Now to the Thumb falling down:
I really am suspecting your seals in the Thumb cylinder have had it,
however 1st of all just put your Thumb as far back as possible, turn the machine off and go to your valve body and just listen to see if you can hear any fluid bypassing through the valve. If it is, then check out the spool, bore and centralising spring.
If not ( as I suspect ) then lets start the machine up, put the Thumb all the way back, and lower the boom down so that the bucket and Thumb rest on the ground.
Turn off machine and take off the piston side ( not rod side ) hose off. Blank the hose ( I think its a -12 JIC male plug, but please check ).
Now start the machine, leave bucket and Thumb on the ground. Now try and and pull the Thumb back with the Hydraulics. Now there should be NO oil coming out of the piston side of the cylinder. If there is, your cylinder seals have had it. Go buy a new set of seals and install in cylinder.
Ok so your probably asking why have my seals gone if its only 3 weeks old?
Some reasons why I think so.
1/ Cheap cylinder with cheap seals installed.
2/ Thumb does not have a mechancial stop on it, so basically the piston is bottoming out all the time its pulled back. When pulling it back all the way, ensure the operators do not slam it back, make sure they do it smoothly or stop pulling it back before it bottoms out.
Or put in a mechanical stop, to stop the piston bottoming out on the cylinder.
3/ Make sure that when digging, the Thumb is way out of the way. ( It has no secondary relief valve to protect it ) Even to a point of lowering the bucket on the ground, make sure the bucket is on the ground 1st before, you come down with the Thumb.
I can see some paint has rubbed off at the bottom of the Thumb and it looks like it has been dragged through the ground a bit. Not designed for this, even just a little bit.
Ok I hope some of this helps, good luck !
Duff:thumbsup:
/ mini ex thumb #10
Could be detent, float, and/or motor spools.
/ mini ex thumb #11
JJ
Bill
Duffs right, those yellow caps are work port reliefs for other functions, I see the valve section for your thumb is machined and plugged for WPR but they don't have them installed.....I agree with most others as the culprit is most likely blown cyl seals.....one big problem with thumb cyls is the "induced load" from your bucket cyl (usually the bucket overpowers the thumb cyl resulting in way too much pressure)....also your Volvo equipment has a higher pressure rating than the thumb add-on.....
after all is said and done if it were my machine I'd find out from VolvoOEM if those WPR valves are available separately, remove plugs, install 2 (there will be another spot directly under for the other) set the pressure for whatever the cyl manufacturer for the thumb gives for max pressure....if you don't, the potential for more trouble exists (i.e. bending hyd rod ect.)...there are other ways to add pressure controls for that circuit but the best would be to add those cartridges....
Just my :2cents:
/ mini ex thumb
Whew! Alot of what you guys are talking about is Chinese to me, but I'm starting to get it. I believe this is what caused my problems. First of all, I installed the thumb, without real advise on the correct way of doing so. The thumb closes to far and pushes the packing, over time it starts to leak internally. I'm going to take the advise here and after replacing the packing, I'll put a manual stop on the arm to prevent the cyl from closeing all the way. I'll get the WPR valves if possible and install them as suggested. Sounds like wdchyd is right, more problems coming if I don't. Broke a pin in the thumb over the weekend. Gotta tell you, that little Volvo is a sweet machine. Thanks to all for the help. Bill
/ mini ex thumb #13
:thumbsup:I see alot of "Thumb Attachment Issues"over and over....of course I usually see them after bent and broken rods:2cents::2cents::2cents::2cents::2cents::2cents::2cents::2cents::2cents::2cents::2cents::2cents::2cents::2cents::2cents::2cents::2cents::2cents::2cents:
you get the picture?;)
/ mini ex thumb
OWCH!!! Called Volvo today, they want over $560.00 EACH for the WPR valves. Over $1,100.00 is alot of cylinder packing.
/ mini ex thumb #15
Either rebuild it or get an equivalent cyl from Surplus Hyd, for less bucks. You could move your bracket back some and prevent the hard stop.
Either test the cyl as has been mention, or take the cyl to a hyd shop for a test.
/ mini ex thumb #16
You can instead add a cushion valve (Parker - DWV, CROSSOVER RELIEF VALVE BLOCKS, 210 BAR (3000 PSI), INPUT FLOWS TO 94 LPM (25 GPM))
This will do essentially the same, you'll have to mount this somewhere(preferrably ,but not necessary ,)close to cyl...
mount this valve between cyl and main control valve (or one similar & smaller) and add hoses to fit....done.....
There is others that do the same....the nonadjustable type you can add shims internally (use pressure guage when do this!)
The result is the same.....too bad for them (Volvo)....but there is always other ways to skin a cat:laughing::laughing:
Good Luck, Bill
/ mini ex thumb #17
Duff:thumbsup:
Since I'm finishing up the design to build a thumb for my mini-ex, could you please explain how the lack of a mechanical stop on the thumb when retracted creates a problem? Is it considered back practice to allow a cylinder to operate to the fully retracted position? I can understand that if an operator "slammed" it back, there would be a pressure pulse at the end of travel, but wouldn't the pressure pulse also occur when the thumb stopped suddenly because of an external stop?
/ mini ex thumb #18
It is the piston bottoming out that is the problem, not the sudden stop.
/ mini ex thumb #19
/ mini ex thumb #20
Why is the piston bottoming out a problem? The piston seals do not appear to be typically located on the surface which would contact the end of the cylinder.
I did a web search and found a National Fluid Power Association document which provides application guidelines for selection of hydraulic (and pneumatic) cylinders. Nowhere in this document does it specify that a cylinder should not be allowed to travel its full stroke in service.:confused:
2009 International 4300V 24ft. Cab and Chassis Truck (A64194)
2009 International...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2011 Black Troxell T120 Vacuum/Water Hauler (A64194)
2011 Black Troxell...
KMC 13 SHANK H.C. CHISEL PLOW, 3PT (A64278)
KMC 13 SHANK H.C...
40ft High Cube Shipping Container (A65583)
40ft High Cube...
