Hydraulic issues on a 2200
/ Hydraulic issues on a 2200 #1
gatorgrabber
Member
Gainesville,FL
I'm new here, but what a site!
We have recently purchased a very low-hour, 'gray market' YM2200 that's having an issue with the front bucket not being able to hold a setting. When you tip it up, it only holds that position for 30 seconds or so. It did have a loose return hose (repaired) and a mildly leaking hose to the bucket (replaced). The oil level was topped off and all the leaks seem to be fixed. It has at least an hour of run time since the repairs and it's still not behaving. The service book we got is not, shall we say, the best...so I came here for advice! :D
Is it possible that it still has air in the system? Is there a check-valve that may need attention? Perhaps the filter needs cleaning? That said, where is the silly thing? :confused2:
Thanks!
/ Hydraulic issues on a 2200 #2
You need to re-seal the lift cylinder.
Thanks for the ideas. To start out, where can I find info on re-sealing the cylinder? Nest question, how do I determine which is the culprit?? Man, we really need a good manual here...
Private purchase. A local farmer bought it (for use as a spare) and it just sat in the barn for several years. He finally cleaned house and sold it to us with only a hundred hours on it. Even though it's almost new, letting equipment just sit around always seems to result in 'issues'.
/ Hydraulic issues on a 2200 #7
You can usually switch the lift and curl hydraulic lines and determine if it's the valve or cylinder.
/ Hydraulic issues on a 2200 #8
Not really familiar with your 2200 but I think you will find your hydraulic filter right behind your hydraulic pump and a little lower on the right hand side. You will also have a hydraulic screen, probably behind a 3 bolt flange toward the front lower part of the transmission housing.
Do you do this (switch the lines) back at the control levers? Sorry, I'm a truck guy, not a tractor guy! :D
/ Hydraulic issues on a 2200 #10
I think it would work either place but I doubt your hoses are long enough to switch at the cylinders. The easy place would be at the control valve. Make sure you swap all four hoses. You don't want to dead head your system. You can eliminate the control valve being bad with this test but if you do have a bad cylinder it could be 1 of 2 or both.
I'll swap all 4 lines when the rain stops and report back. If in fact the cylinder(s) are bad, can I do the job or do they need to go to a hydraulic shop?
/ Hydraulic issues on a 2200 #12
I can't really answer that, if it were mine I would dive into it. I might make a failure, but I would try. I believe you could go to a hydraulic shop and get seals and o-rings. Might need to take the disassembled cylinder with you. My cylinders have a nut on the end made for a spanner wrench. Doesn't look to me it would be that difficult. Cleanliness is very important with hydraulics.
I've got years of shop experience, so I'll give it a go. Are there any details posted out there with specs for these cylinders?
/ Hydraulic issues on a 2200 #14
Don't know about specs. No telling how many company's and configurations of these cylinders. If you have a name you might google it.
/ Hydraulic issues on a 2200 #15
If it had a hundred hours on the meter it could be 1100 or the 100. The 2200 from what those who know say that that is one of the rebuilds from vietnam. If it has a bulldog loader it is. They usually come with around 15-20 hour on them so he must have put around 75 on it. Any how my point to this is that hoye says that there are not as many parts for these as others and the bulldog loaders have no real source for parts. Going to a hydraulic house is probly your option as far as taking it somewhere and haveing them repack it if you wont try it yourself.
I'd be very skeptical of the 100 hrs myself if it was coming from someone we didn't have history with. That said, I'll never know the actual history of the tractor because we didn't build it. I can say it was in (almost) better condition than the new models sitting down the road out in the weather! :thumbsup: Hydraulic House is just down the street from my shop, so I'll drag the parts to them if that's what it comes to. Should the rams be serviced in pairs if that's the problem?
/ Hydraulic issues on a 2200 #17
Thanks!
If your YM2200 has a hydraulic reservoir under the seat, the screen will be behind the cover with 4 bolts.
Danny
/ Hydraulic issues on a 2200 #18
Thanks!
If there is no reservoir under the seat, the screen will be behind the cover with 3 bolts in a triangle, under the PTO shaft.
Danny
/ Hydraulic issues on a 2200 #19
The YM2200 was built in the early 70's.
Danny
That's great information, thanks! :thumbsup: I'll take a look tomorrow (rain never let up) and see what system's on our tractor.
