The greatest point of clarification is that the engagement mechanically locks two axles together, so they must be moving at the same rpm or both stopped at time of engagement. Damage is done NOT because the diff lock is used when only one wheel had traction, but because the engagement was done while one was stopped and the other turning. The safest thing to do is to be sure both wheels are stopped before engaging. If that is consistently practiced, there will never be any damage to the tractor.
That's right because if you think about it nearly all the weight is on the tire
that's not turning. Popping in the Diff. Lock would instant throw all that torque
onto the wheel that not spinning and has nearly all the weight on it.
A couple years ago in was in the Case IH 5140 2WD 100hp+ tractor and my
wife wanted me the get just a little closer to an area that is known to be wet
from time to time. Next thing I know I'm slowing down to a crawl in like 5
seconds and had a 15' disc harrow behind me. I immediately raised the disc
wheels and remembered from the manual that it said you had to be stopped
before engaging the Diff. Lock, which in this tractor is an electrical switch,
so I stopped turned on the Lock and moved forward about 2' and stopped,
used the power reverser to rock it back and forth and after about 10 tries I
got it out. I was like man I could have buried this thing. It was about the
second time I had ever used the tractor. This a cab tractor and you can't see
the wheels spinning at all from the cab. She and Dad ran everything here
until he passed recently.
