Loader I found the float position--Now what?
   / I found the float position--Now what? #1
baryon
Member
Southern New Jersey
BX25
It's weird that the manual for my BX25 mentions the FEL float position but doesn't explain it. I found a video on youtube that showed me how to put it in float. Then I tired it out, and it worked. To get it to float over uneven terrain, should I rollback the bucket just slightly or keep it level? When I tried it out it just dug into the ground.
   / I found the float position--Now what? #2
There is an old joke and I mean OLD. "How do you get to Carnegie Hall? Practice, practice practice.
I have three different loaders and they all work best in a little different way.
"Best" is going to depend on a lot of variables, but mostly what material you are using and bucket angle. You will just have to experiment, but you will "generally" float better with a slight angle as opposed to flat. Changes in angle whether pushing or pulling will change how much material is moved or how smooth the finish will be. I am still learning on my newest tractor.
   / I found the float position--Now what? #3
Not usually applicable when going forward unless you roll the bucket back. Backing up and using it in conjunction with various bucket angles it works well for light grading and
smoothing. Back dragging.
larry
   / I found the float position--Now what? #4
Rare case that I've used mine in forward but have a few times. Usually used backing up and the angle of the bucket depends on ground surface and what outcome I'm trying to achieve. I often times load the bucket to max then back drag for more weight down pressure when needed.
   / I found the float position--Now what? #5
I guess I am in the minority in that I use float going forward quite a bit; used it yesterday spreading 2" crushed rock in a washout; also use it clearing snow.
   / I found the float position--Now what? #6
I have used float in the forward direction when using the FEL moving snow. Other than that its a back drag function.
You guys are the best. This post hasn't been up for more than an hour and I got four (make that five) very good, very helpful responses. Thanks very much.
Dan
   / I found the float position--Now what? #8
"Back dragging" sure is a lot easier, but with my gullies/ditches/precipices, going backwards is simply not possible.:eek:
   / I found the float position--Now what? #9
I have the same issues here in WV and you better pay attention to where you are going backward or forward. I always wear my seat belt. Around here you are either on a hill or about to be on a hill.:D
   / I found the float position--Now what? #10
I am not sure my "hills" here would really qualify as a hill in WV, but they are enough for me. I grew up as a "flat land farmer", but we bought a couple of hill farms in the late eighties when my father in law retired and it sure was an adjustment. I doubt that I will live long enough to master it.
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2014 CATERPILLAR 308E2 CR EXCAVATOR (A52709)
2014 CATERPILLAR...
2015 Chevrolet Express 4500 Shuttle Bus (A56858)
2015 Chevrolet...
2013 Cadillac SRX SUV (A56859)
2013 Cadillac SRX...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
