New "old" trailer- tri axle
/ New "old" trailer- tri axle
Got to use the trailer last weekend for a short haul (less then 10 miles round trip). Buddy wanted to borrow my 2030 JD & 3pt hitch backhoe. We pulled it behind his 92 7.3L IDI w/ an ATS turbo. Tractor didn't even squat the truck, granted most of the weight was on the axles.
Good news, lights work good. They were 'kind' to get the marker lights all working and well as the tail/brake lights. Bad thing is, the brakes are MIA.... granted, it could have been the adapter I was using (7 way RV flat to 6 wire round small) or it could have been his truck (controller didn't light up????). Yes, yes, I know, I know.... playing w/ fire not having a proper braking system. This is ag country.... you should see what is going around w/out any brakes here. I'll have to get my truck and test the brakes (I have that plug wired)... granted, it's only a 1/2 ton.
My planned tow rig is a 1999 E350 Extended van w/ a 7.3L PowerStroke. If needed, I can change the pental hitch on it to a 2 5/16" coupler to use a weight distributing hitch. I plan to just use it w/ in a 15 mile radius, but may use it for the occasional long haul to pick things up.
/ New "old" trailer- tri axle #22
Common sense? Puh-leeeze.
They may be rated for 6K, but it's LIMITED USE. Why the "limited use" designation? If you want the straight scoop on Dexter's line of axles, you can go directly to THEIR site. There's no need to go searching for a reply on another message board that aligns with your thinking.
direct from Dexter's site:
Here's a link:
Dexter Axle - Trailer Axles and Running Gear Components - FAQ'S
Thats very interesting but at some point mobile home builders must have used Dexter UTG axles. I suspect they didn't have the cheaper MH limited use axles back then. I've had 4 trailers with the UTG axles. 2 home made, and 2 factory built. A friend built one of the home made trailers and my Dad and I built the other. The axles on the 2 home made trailers came out from under house trailers and were narrowed. None of those axles had "limited use" tags. Brakes, bearings etc were interchangable between all 4 trailers. We even bought replacement brake parts from a local mobile home dealer! That was at least 22-24 years ago. We also had 2 other trailers that had different (I presume limited use MH) axles. I don't recall exactly what the differences were, but backing plates rings a bell. I do remember seeing the two types of axles side by side and there were clearly differences.
/ New "old" trailer- tri axle #23
Yes, there are mobile home "style" assemblies that take the same bearings and such, but those aren't the actual mobile home axles Dexter is talking about. Here's a web page with a selection of Dexter hubs and their components. Towards the bottom of the page you can see the rim-clamp mobile home style hubs. These have been used by equipment trailer manufacturers in the past, and maybe still are in some instances.
These hub assemblies aren't used on traditional mobile home axles though, and that's why the 'limited use" designation exists. Check out the pricing on the rim-clamp style hubs on this link....it's a dead-giveaway.
Dexter Axle - Trailer Axles and Running Gear Components - Hub Kits 5.2K-6K
There is simply no-way, no-how that all of the mobile home axle fans would be actually using these axles if the original mobile home application spec was written so as to equip the mobile home axles in this manner. Everyone that chooses to use MH axles does so because of the pricing. You can buy complete MH axles from hub-to-hub just about everywhere for $50-75....often including a set of springs. The places selling the axles wouldn't let them go for next to nothing if they were originally equipped with components that are more expensive than standard 6K rated axles are.
They cost little, (and carry the limited use recommendation), because they were made with bottom shelf bits and pieces.
/ New "old" trailer- tri axle #24
Pops15 the link at the bottom of this post is from post 15 in this thread. We are not sure why brokenot is so hung up talking about limited use axles as if the wheels fall off after so many revolutions. :D
MH axles are "limited use" axles as they come from the factory BECAUSE they require permits to be used because they are too wide for unlimited use.:D
brokenot knows the truth that bearings, seals and brake parts are available as common size parts. Because the back plates are welded on no you can not buy a loaded back plate (back plate with all new parts already installed) but you can buy the replacement parts and replace them on the welded back plates just like with tractors and older vehicles with drum brakes.
Besides the axles having to be cut in the middle and shorten for legal unlimited use (no wide load permits required) they typically have one heavy weight spring instead of several light weight leaf springs so they ride better for hauling the trailer empty or with very light loads.
DOT approved highway tires are available and affordable.
Do not let brokenot lead you to pass on a quality built trailer just because it is builted on limited use MH axles that have shorted for legal (no wide load permits required) unlimited use like Dexter/others sell that are made short enought from the factory so they can serve as unlimited use axles that do not require wide load permits to be purchased before towing on highways in the USA.
I have read some state laws do not permit the reuse of MH axles for NEW MH construction. This would provide a source of limited use MH axles that can be shorten so they are legally unlimited use (no wide load permits required) axles.
Official Mobile Home Axle Info [Archive] - Pirate4x4.Com Bulletin Board
"You are correct that your axle is NOT the "one time use" axle that everyone thinks it is. The axles with the bolt on brake are the utility version which was very similar to the true mobile home axle with the weld on brake."
/ New "old" trailer- tri axle #25
Gale, the reason I'm so hung up on it is because you're wrong....and your misinformation is only serving to muddy the waters further for anyone that wants accurate information. The "limited use" designation has NOTHING to do with the axle length. It has EVERYTHING to do with the componentry involved in their construction.
Please quit posting someone's quotes from the Pirate 4X4 forum. Especially since it's totally obvious you haven't read that person's entire post and have only chosen to take out of context the tidbits that you believe support your point. He was fixing up a trailer himself, and it was his FIRST such endeavor. (In other words, far from an expert on the subject.)
He asked someone at Dexter if the stuff he was using was included under the limited use umbrella, and he was told by the Dexter Rep that it was not. Read, (perhaps for the first time), what you've quoted yourself:
Long story short, the axle HE was using is NOT a mobile home axle! Someone at Dexter told him so. Remember Dexter? They're one of the companies that makes the axles. They say the mobile home ones are for limited use only, and you can read it right on their website or call 'em if you wish. You needn't wade through numerous internet ramblings from novices on the subject until you happen across a quotable snippet that you think *proves* your point.:confused2:
Since the axle HE was using was NOT a mobile home axle.....the mobile home axle caveats don't apply to his situation. So I guess the real message, (which is what I've been saying all along), is.....if you don't want to put up with the compromises that mobile home axles come with, then use something else.
Dexter Axle product information: (574) 295-7888
The truth hurts sometimes.....
/ New "old" trailer- tri axle #26
I don't dispute anything you're saying about the current style light duty, limited use, MH axles.
My point was at some point in time MH's used the current UTG style axles so it's not accurate to make a blanket statement about ALL mobile home axles.
So that means, if you see a UTG hub, don't assume it started as a mobile home axle. Look behind it and if it's welded, it was a mobile home axle. If it's bolted, then it means it's a regular HD axle.
/ New "old" trailer- tri axle #28
If you see a UTG hub chances are it didn't come from a house trailer. The majority of house trailer axles I've seen are the "light duty" versions........but not all. I just wanted to point out that some MH's used UTG axles so its not fair to make a blanket statement.
/ New "old" trailer- tri axle #29
There are probably thousands of narrowed MH axels in use today with no problems.Might be a difference of manufs. but I have had the MH axels narrowed for my use and never a problem
/ New "old" trailer- tri axle #30
Lots of people have used them....I've used them myself. But they aren't comparable to standard axles, and that's the point I've been trying to make. If the OEMs describe them as being for limited use, then there's a reason. If that same axle company builds another "line" of axles that they don't tag with the limited use designation, there's a reason. If you can find mobile home axles everywhere in piles, and the asking price is $50 a pop, there's a reason. If you go browsing the new factory-built equipment trailers at your local dealer and none of them are equipped with mobile home axles, there's a reason.
There's nothing mysterious about it, nor is it a conspiracy of any kind.
I'm not saying that users posting up about having used them and not having problems holds no merit, but it's hardly the only thing to consider. Like I said in the other thread, it's akin to someone posting up in a light truck thread and saying whichever 3/4 ton or 1 ton truck the original poster is asking about is a completely unnecessary waste of cash because he could buy a 1/2 ton and bolt on some overload springs and have something that "will do the job just fine".
"It works for me and I've never had any problems.....", has never trumped any manufacturers' recommendations for me. Folks that buy into that logic hook, line, and sinker actually help keep me busy at work though....
/ New "old" trailer- tri axle #31
Crusty most everyone including brokenot knows what he is saying is not functionally true. Read his last line in his last post. I think he may have taken an "honest" pill and may be about to come clean with us as to why his "troll" activity on the web. :D
Watch for him to post he is not trying to confuse readers and that he is only out to save them from themselves.:laughing:
Let us see if he is about to come clean about his $$$$ reasons behind his post after post or post some concrete cases that support his posts other than the soft stuff like manufactures' "recommendations".
We make stuff and we have "recommendations" to potential customers too. :D
Uh oh.... so I've got a troll posting to my post. Dang.
/ New "old" trailer- tri axle #33
BillaVista's Trailer and Mobile Home Axle tech
Pictures and details of parts and the process of servicing/replacing brakes and bearing parts on equipment trailers built using mobile home axles.
His write up and updates are very detailed so if you need to replace parts or service you trailer with MH axles you may enjoy this site. As far as that goes the basis info is good for many brands/lines of axles.
In his case the wheel bearings turned out to be identical to some wheel bearings by the Big 3 auto makers and are not "trailer" specific.
To keep Dexter and brokenot happy you should buy non MH axle using trailers by all means. If you are one of the happy millions using heavy equipment trailers built on MH axles you may find this Canadian's experience and story of interest.
/ New "old" trailer- tri axle #34
Gale. I think your link is going to 'muddy up' the waters further. If you look at some of the picks the leaf springs have multiple leafs. Brokenot's Dexter comment said most use a single main leaf. Those axles could be some of the few that didn't (however I've only seen the single main spring style myself) or the builder of the trailer could have swapped them out. Or it's possible that Dexter isn't the only company making this type of axle.
I have several friends who have trailers built with MH axles and have used them for decades with no problems. I have talked to MH dealers and from what they tell me they pump up the tires far past the rated pressure and put far more weight on them than they are rated for. The only issue he ever has is either a tire blows or while making sharp turns the leading or trailing tires debead because of the sideways torque.
Now back to topic. I have a 79 General trailer with those same axles. The differences I can see are my trailer has wood decking in the middle and steel diamond plate on the outside edge. The I beam runs the full length before being angled in to form the tongue. The front plate has three holes for the pintle hitch and the trailer has a large semi style (6" square ish) jack. The trailer is rated for 22,500 lbs.
The things I would look for is play in the leaf spring bushings.
/ New "old" trailer- tri axle #35
Crazyal that was a good catch. From my research springs can vary and the deciding factor between a retail and MH axle has to be does the back plate have a flange to bolt to or is the back plate just welded on. It does not change the function of the axle and it lowers the cost slightly.
After pulling my old trailer 110 miles empty to get it home at 60 mph and the bearing cap/hub staying cool to touch the whole time I think we are go to go since we may do 100 miles per year at 45-50 MPH max. :D
In looking at Utah's law the number of axles does not even refer to weight but the number is based on how long the trailer is but width (weight) does not matter. That supports what you were told about them running seriously overloaded. We know these bearings are standard off the shelf automotive bearing and if they can run seriously over loaded for 500-1000+ miles at interstate speeds and NOT fail they are an over kill for 90%+ of heavy equipment trailers based on the way they get used in real life moving equipment from job to job or like in our case to take equipment in for service.
I though the guy knocked himself out on going into detail and with great pictures when servicing his MH trailer axles.
/ New "old" trailer- tri axle #36
Gale, I guess the last line in my post went waaaaaay over your head. Let's try it again. I repair things for a living, and have been doing so for 25+ years now. My comment meant that LOTS of what I repair daily, is the result of the end-user taking the advice of someone else that "has always done it that way and never had a problem". In other words, recommendations from the manufacturer on capacity, recommended duty-cycle, maintenance procedures, etc. were ignored and instead replaced by the probably-well-meaning-and-yet-just-plain-wrong advice from others.
And once again, your "research" has muddied the waters. You searched out yet another example of an individual that happened across a trailer with a set of *non-typical* mobile home axles and are posting it up as an example. Do they exist? Yes they do, nobody is disputing that. But good grief man, go to a local dealer that sells used mobile home axles and see what they have for sale. They'll have the much more common and inferior typical mobile home axles. I guarantee it. And those much more common and inferior axles are the ones that can be had for next to nothing....which is why people think they're "worth it" to begin with.
Choose NOT to call an actual axle manufacturer, or visit the website of an actual axle manufacturer if you wish. There are plenty of more Bill Vista and Pirate 4 X 4 type sites out there to visit to support your opinion. It's kind of amusing actually. Everything you've posted up has been the experience of someone that has, well.....no other experience. That's funny enough on its own, but ignoring information from actual manufacturers really illustrates your lack of understanding about the subject and/or shows the lengths you're willing to go to to NOT admit something you don't want to admit.
And I'm a troll.
Funny.
Lastly, during your "research" on the subject, have you stumbled upon any posts from folks that had gone the mobile home axle route and say they wouldn't if they were doing it all over again? And if you have, were those people written-off as trolls with some hidden agenda as well?
/ New "old" trailer- tri axle #37
As far as a MH axle breaking or a bearing burning up and needing replacing using a MH axle would actually prove to be cheaper in the long run. Where as with most axles you'll need to bring parts to a dealer to identify them unless you can find the ID tag on the axle then go through the work of ordering parts if a MH axle breaks you could simply buy another axle for about the same cost and now you have a whole axle with two hubs.
But I've never seen one break. I'm sure Dexter doesn't put the time or effort into them like they would other axles but it's not like the loads they carry are light or the stresses they will see are mild. Sure the brake pads may not be as thick or the bearings as large (but as long as they are kept greased they will last just as long as any other bearing). I'm also sure Dexter doesn't want the liability or the loss of business of having people use MH axles instead of buying the ones Dexter would like to sell you. Probably the biggest issue you may have with MH axles is the hubs may not be true and you'll wear tires down much faster.
But go to any small race track and I bet half the trailers there are homemade with the axles off mom's MH. Since a pair of them are rated for 6 tons plus a 3000 lb car and 1500 lbs of steel trailer are not going to put much stress on them.
brokenot I understand your point, buyer beware. But if you buy a used homemade trailer there are lots of issues than just the axles to think about. Things like did the guy who made it know how to weld correctly? Did he get the deck flat, did he get the axles true, etc.? Is the rest or the trailer strong enough or is it a 7000lb 2 axle car trailer with 12000 lbs worth of springs under it that'll give the false hope that it can be loaded with too much because the springs aren't sagging?
/ New "old" trailer- tri axle #38
Believe me, I understand what MH axle proponents are saying also....and I can see the attraction to saving some cash.
Buyer beware indeed though. The thing is, a buyer can't truly "beware" unless they're aware of the facts. What would there be to "beware of" if the components we're discussing are comparable? Simply stated, Dexter would have no liability issues or longevity issues to be concerned about, if the MH axles were suited for the uses other than what they were originally designed for. They didn't tool up their factory and start churning out MH axles, just to caution against their use and sell something for more money. They tooled up to build them because there was a market for a lower-cost alternative to traditional axles. Where did the cost savings come from? And what makes the MH axles' intended use different from the intended use of the other products they sell?
As for the bearings lasting as long as any other bearings as long as they're kept greased, well....not exactly. That's partially why the limited use designation exists. Larger bearings can support greater loads. And larger bearings can support any load for a longer period of time because that load is spread out over a larger area. Either the standard 6K axle's weight recommendation in relation to its bearing dimensions is very conservative, or....a MH axle's recommended capacity is optimistic. It could be both of course, but since they say "6K rated" and "limited use" at the same time for the MH axle, well.....;)
None of this has been intended to poo-poo anyone's decision about what they've already used in the construction of their trailer. It has very much been intended to ensure anyone making a decision about an axle choice does so with their eyes wide open.
The information is out there. Just don't ask the guy that has experience with one trailer, and has just finished up his first such project. There are plenty of people with experience over the long run with both types.
:thumbsup:
/ New "old" trailer- tri axle #39
Sounds a lot like my trailer, but mine uses three rows of 2x4 square tubing rather than I-beam. Just redecked mine last fall.
Man, if this topic of UTG type axles and mobile home axles generates this much activity.... I wonder how things were when people tried to research axles BEFORE the internet!!! LOL.
I searched my state website to see if using mobile home axles in a 'new build' is illegal. No such luck yet. Aside from calling them and asking.... just to know. LOL.
If they say mobile home axles are "limited use" axles (ie one time use only), I'm sure that's not how they are being used. But, as I said before, if people are building "trash" trailers or some other type of trailer that they use less then five times a year (short trips, under 100 miles), I'd say those axles would work, since they are being used in a limited fashion.
There are tons of examples that people do things where they shouldn't. The trailer I borrowed prior to buying this one, it was a custom built car type hauler (flat bed). It was a two axle trailer that was built with multi use in mind. It also had 'racks" tall enough to keep cattle in it. Yes, I said cattle. It would haul about 8-10 cattle to the sale. Not sure if it was rated at 10,000lbs or what, but they used it. It has 15" 6 lug (or 5 lug tires). But most trailers I see advertised as car haulers or similar use channel or angle frames. This was built using 3/16" or 1/4" wall tubing. They meant it to stay together. I think it weighs 2500 empty or just shy of 3000. We've loaded a tractor on it that I KNOW is at least 5000lbs.
I've seen tons of trailers running around with out the dust cap too. People don't seem to care, they just hook it up and pull and pull.... especially if it's their trash trailer. The said trailer above has a missing cap and who knows the last time the bearings were repacked with grease.
New/Unused CFG Industrial QK16R Mini Excavator (A65583)
New/Unused CFG...
1998 Volvo VNL64T Sleeper Truck (A62679)
1998 Volvo VNL64T...
UNUSED AGT YC-32G SAWMILL (A64281)
UNUSED AGT YC-32G...
2019 HAMM HD+140IVV DOUBLE DRUM ROLLER (A65053)
2019 HAMM...
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
John Deere LX5 5ft. Rotary Brush Cutter Tractor Attachment (A61572)
John Deere LX5...
