how to build your own custom backhoe subframe
/ how to build your own custom backhoe subframe
The forward to aft dimensions were spot on, otherwise I would not have purchased it.
That's very fortunate. Since you got rid of the Prairie Dog, what hoe
are you going to use?
An integrated TLB, like the Kubota B21, provides an illustration and a
paradigm for hoe attachments to CUTs. Here we see how the subframe
couples the front to the rear of the tractor, while providing structural
elements all around the rear axles, and 4 mounting points. The B21
hoes mount and dismount VERY quickly thru the use of pins and clamps.
You can see the clamps and the huge 1.5" pins in the photo. This
so-called "mainframe" weighs only about 200#, and it exhibts very little
flex under stress.
There is some wiggle, however, which is the only criticism I have for
this design. Although the pins are securely attached, I noticed that the
bolts that hold the clamps tended to loosen up with vibration AND they
can not be easily monitored while the hoe is mounted. So even the
very clever Kubota design is not ideal, and it would take additional hours
of fabrication time to copy.
The hoe is mounted very close in, with little space between the outriggers
and the rear tires. I have several hours of seat time on the B21, and it
is impressive, but the very light weight allows it to be dragged easily by the
hoe, even with only 2000 psi hydraulics. Weight is your friend when digging
holes.
Anyone contemplating their own subframe design and fabrication project
should go and look at these integrated TLBs, as well as other excellent
designs, like the Kubota BX24/BT600 or the Grand L/BH90.
Those who follow my ramblings on TBN have seen some of my earlier
custom subframes. The first I did was of the ladder frame with toplink
style, but I used a permanently-mounted subframe that disconnected
from the hoe with bolts at the lower 3PH hoe mount. So I preserved the
lower 3PH mount on the hoe, but instead of using the 3-pt arms on the
tractor, I used rigidly mounted arms, which were shorter. This allowed
the hoe to be almost a foot closer to the tractor, and no 3PH anti lift
brace was needed. I did use the enhanced toplink. Sorry, but I have
no pix of the subframe.....this project was a long time ago.
/ how to build your own custom backhoe subframe #24
I don't know where this fits in the scheme of sub frame types, but I have a Kukje tractor that has a Humpolec loader frame that goes all the way back to the rear axle where it bolts together with and under the ROPS.
The Amerequip hoe sub frame mounts to the bolts that normally support the 3pt lift arms and at the front hooks over a cross member of the loader's sub-frame.
It works (-:
You bring up a good point, REG. When practical, it makes a lot of
sense to tie a backhoe subframe into the loader subframe. This applies
to custom subframes or ones that come from the hoe vendor. The
B21's "mainframe" above is for the hoe AND the loader.
Also, TBN members will notice that some tractor makers, like Kubota,
put their FEL subframes under the the tractor, while others, like JD,
put the FEL subframe mostly above the tractor's main structure. I
know I am generalizing, but the former type allows you to integrate
the two subframes together. Woods usually requires a tractor mounting
one of their hoes to have the factory FEL or a Woods FEL. Use of
other aftermarket FELs may interfere with or not connect to the Woods
subframe.
The photo is of a Grand L 40 with the BH90 subframe and how it is
attached to the FEL subframe.
/ how to build your own custom backhoe subframe #26
I am fairly sure (from tractor shopping) that just about all backhoes require a FEL frame to be installed first, at least the ones that I got anywhere close to considering required it.
I didn't consider 3pt hoes.
When I put the Amerequip hoe on mine the first time I had to squirm around under the tractor and loosen a lot of FEL mounting bolts, leave a lot of the hoe sub frame bolts loose, assemble it all, then "shake in place" for it to align and fit.
I had bought the hoe some time after the tractor from a different source, hauled it home several hundred miles in a (half clean) horse trailer, a fun project in itself (-:
I might as well state here that the Amerequip hoe is definitely owner installable with only nominal hand tools, no need to pay a dealer to foul it up when you can do it right yourself (-:
/ how to build your own custom backhoe subframe #27
Going hand in hand with all this is ease of installation and use. While having a firm attachment system is great, if it is difficult or impossible for one person (sitting in the driver's seat) to back up to and hook up...well, it's not worth bothering with.
This is the balancing act the designers must struggle with. I know the BH ladder type subframe for my Kioti DK45 isn't all that great (kioti BH). I wouldn't want to use it all day every day, but it sure is easy to hook up.
One that requires crawling under the tractor, installing bolts and other calisthenics should be considered as poor design, in my book.
/ how to build your own custom backhoe subframe #28
This may be what you meant, but I think a moderately difficult subframe installation is tolerable as long as connecting/disconnecting the hoe itself is doable by one person in a few minutes.
Most are probably that way, but on most JDs, the subframes don't touch
at all. Of course, putting a hoe on a tractor with no loader at all (or
no front weights) is a mistake, esp with small tractors. All that weight
in the rear with no counter balance up front makes the steering control
very dicey. I have tried it.
Anyway, here is another JD example...this time a very common 770 with
a brand new JD7 mounted to an undermount ladder-style subframe. An
enhanced toplink with a brace is used. The QA mechanism and cross-
brace (rung) in under the tractor ahead of the axles.
The next subframes I made were for the JD 955, a much smaller tractor.
Both involved a hybrid subframe that was similar to the ladder subframes,
but also had structural elements that surrounded the axle housings. There
was no toplink used....the toplink brackets on the 955 are very small
anyway. Here are some pix of the 2nd one I did. The first one was a bit
different from this one, but I have no pix. I was on a learning curve.
The 955 was a great laboratory because I had several that I refurbished
and the low height of the rear axle housings was ideal for the ideal
mounting height of the hoe. The bottom of the hoe should be 12-14"
off the ground, primarily based on the outrigger design.
The result of this 2nd design was a very close-in hoe that worked very well.
Because the tractor was so light (less than 2000# naked), the hoe could
drag it very easily. The same hoe on the other tractors I did were much
more productive, due to 50% or more tractor weight.
In the photos, you can see that I used channel steel that was welded up so
that it fit precisely around the housings, which were made of cast steel. I
could not have done this if the housings were aluminum. All of the subframe
was permanently mounted to the hoe, with a forward connection to the
tractor frame at the mid mount mower bracket. It was very easy to mount/
dismount, which required the removal of the front 2 bolts and the
rear 2 bolts.
As an aside, the 955 with hoe and loader was very similar in size and
weight to the B21. However, the 2500psi hydraulics and AG vs. IND tires
made the 955 a much more productive TLB, IMO. The 50% greater
engine power was also a plus, but second to the other factors.
/ how to build your own custom backhoe subframe #31
That's very fortunate. Since you got rid of the Prairie Dog, what hoeare you going to use?
Sorry for the slow response, modem went and had to wait For them to UPS it to me. Picked up a Bush Hog 850 in Kubota orange, couple of years old but still strapped to the delivery pallet.
/ how to build your own custom backhoe subframe #32
I had issues with the BH scraping the ground when unloading from a trailer because the turf tires on the rear of the tractor. I added a 3" lift to the BH when I constructed this frame. I have the CAD prints somewhere. It's for a Woods 9000 and a NH 2120.
Yes, with some tractors, if your subframe is of the ladder style, it hangs
too low for ideal hoe mounting. You need to put such a jog in the
frame to bring it up. I hope you use a toplink to triangulate the forces.
Some factory undermount frames do that, too, as you can see with this
subframe on a Kioti CK20. It is for a 2365 hoe. The CK20 is a small
2000# tractor and IND tires make it sit extra-low.
The CK20 is one of the few tractors I have run into that have their fuel
tanks mounted up high behind the driver's seat. This makes it difficult
when making the hoe seat mount, limiting how close you can mount the
hoe. The Kubota B2150 also does that.
/ how to build your own custom backhoe subframe #34
I noticed this on my frame and will see if I have to change it. I plan on using a top link stiffener on mine.
My L4350 has the fuel tank there as well, another limiting factor for how much legroom you have when in the seat.
The next subframe I built was for my Kioti CK30. This time I wanted
to make a 4-pt subframe with full encirclement of the rear axles for my
daily use tractor. I planned to make the biggest part of the subframe
(photo) permanently attached to the tractor VERY securely. The other
section stays attached to the hoe, and connects with four 1" bolts.
I published the thread here:
http://www.tractorbynet.com/forums/build-yourself/95092-yet-another-custom-backhoe-subframe.html
In general, I would say that 4-pt subframes are superior to the ladder
style, and offer easier removal and mounting. I also incorporated some
alignment aids to make it easier to get the hoe on. The 3-pt hitch is
not affected at all. I also used, and will continue to use, channel steel
that I have recylced from tractor shipping crates. Bolted connections
may not be the fastest to attach, but I will continue to use them as the
most secure structural attachment method. There certainly are tradeoffs.
Fortunately, my use allows me to keep the hoe on at all times, leaving
my loader for other attachments. It has worked well, but I do have to
monitor bolt tightness.
Next, I will get into the 4300 effort.
Now back to my JD 4300.
I had always planned on building a subframe for this tractor, but once I
got out my measuring tape and started figuring, I can see that there is
no way that I can surround the rear axle castings. (1st photo)
I positioned my hoe up as close as possible, using the hydraulics to set
up the correct height, and the second thing I noticed was the wheel
track is so narrow that I cannot get the hoe in close enough to satisfy me.
One of my goals was to make it so that the hoe was as close-coupled as
the outriggers would allow, with an inch or so of clearance. Well, my
hoe footrest hits the tire before my outriggers do. Even my 955 with
AGs was not this narrow.
Although I can reverse my IND wheels/tires, I don't think I will gain much,
if any, clearance to the tires. JD uses 13" wide wheels with their 15-19.5
tires, instead of the more common 12" wide wheels. If I had AG tires,
then clearance would be no problem. My 2nd photo is of a 4400 with
AGs, set at the widest position. There is so much clearance that I could
design a subframe that wrapped around the axles, on the OUTSIDE of the
ROPS foot. Not an option for me, however, as I will not buy new wheels
and tires. Oh well. Back to the drawing board.
As mentioned earlier, I will hang the full weight of the backhoe and
subframe on the lower ROPS bracket. This is also how Bradco does it.
The 8 ROPS bolts are Grade 10.9 and about 3/4" diameter, so they are
plenty strong enough for the tension forces involved.
Here is the ROPS bracket and the 1/2" A36 steel plate I used. The
biggest piece is 5x6". When all welded up, I reinstalled them so I
could position them with the rest of the subframe before marking for
the holes I will drill.
/ how to build your own custom backhoe subframe #38
I really enjoy reading your posts and envy your playground. Do you need a new neighbor? :)
We do love our 19 wooded acre mountain retreat. We have two
neighbors, who drive our private road, right between our two buildings.
That's a drag, but we could not have afforded the land if it were not
the case. We do look forward to a day when one of the neighbors does
get replaced!
Thanks for the support, guys.
2011 AUXILIARY POWER UNIT (A60736)
2011 AUXILIARY...
2011 GARDENER DENVER TRI PLEX FRAC PUMP (A60736)
2011 GARDENER...
2018 INTERNATIONAL LT625 DAY CAB W/ WETLINE (A62613)
2018 INTERNATIONAL...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61568)
2017 Chevrolet...
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
2022 Schulte 2500 Giant Rock Picker (A56436)
2022 Schulte 2500...
