Kubota BX2200 Leaky Fuel Pump
   / Kubota BX2200 Leaky Fuel Pump #1
phatty70
Hello to all!
I was working on clearing some brush today and got a fuel leak on my BX2200. This happened once before....something came up and pushed off the fuel line...not so lucky today. it seems to be leaking out of the inlet side of the fuel pump (attached a pic). What do you guys think....am I stuck replacing the entire unit or can this be repaired?
   / Kubota BX2200 Leaky Fuel Pump #2
That looks like a filter, not a pump. I'm not familiar with the Kub pump though.
Jim
Jim
I'm not that familiar with the Kub pump either....there is a filter on the fuel tank side and the harness shown in the pic goes into this so I assume it's a pump....I could be wrong. What I know for sure....it's leaking lol
Took the unit off this evening...turns out there was a hairline crack right below the nipple where the line goes into the body. I mixed up a bit of cold weld and after 3 hours of running she's dry as a bone.....only time will tell how long it is until i spend 115 bucks on a new pump :thumbsup:
   / Kubota BX2200 Leaky Fuel Pump #5
If you are good with an iron solder may work also, consider this a warning, next time could be your fan. Get a skid plate or put on a mower deck.
David Kb7uns
David Kb7uns
Yep yep....skid plate is in the works :)
Tandem Axle Rear Truck Frame (A59228)
Tandem Axle Rear...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2023 Chevrolet Tahoe FL SUV (A59231)
2023 Chevrolet...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
2019 VOLVO A45G FS OFF ROAD DUMP TRUCK (A60429)
2019 VOLVO A45G FS...
2019 Deere 35G (A53317)
2019 Deere 35G...
