BX torn boots, another solution.
   / BX torn boots, another solution. #21
I have an L3830. The boots are available for about $10 apiece for my model, and I suspect they may be the same on yours. For all the ones that get torn up... surely they are on the parts list. They are not hard to replace. After doing it a couple times, I got it down to less than an hour to replace a boot. Good idea about the radiator hose.
Here's an old thread I posted with pics of my solution. I have not had a problem since...
http://www.tractorbynet.com/forums/kubota-owning-operating/111337-home-made-tie-rod-boot.html
   / BX torn boots, another solution. #22
You guys are great:thumbsup:! I am going to try this on my MF, before anything happens.:cool:
   / BX torn boots, another solution. #23
You can't get the boots separately for the BX.
   / BX torn boots, another solution. #24
My boots have been gone for years. Idly worrying about it has been effective so far. A thousand hrs later the joints are still tight.
larry
Update of 2008 post - Idle worry still 100% effective.
   / BX torn boots, another solution. #25
Thats hilarious. You should change to 0% worry now.
   / BX torn boots, another solution. #27
2015 JCB 930 6,000LB 4x4 Rough Terrain Forklift (A50322)
2015 JCB 930...
Bush Hog 2615 Rotary Cutter - INOPERABLE / PARTS ONLY (A52128)
Bush Hog 2615...
1273 (A50490)
1273 (A50490)
2007 WABASH 53FT DRY VAN TRAILER (A51222)
2007 WABASH 53FT...
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2014 FREIGHTLINER...
2010 Triple B Gooseneck Inclosed Car Trailer (A50514)
2010 Triple B...
