Heavy Duty Vs. Standard Bucket
/ Heavy Duty Vs. Standard Bucket #1
diggdug
Member
Midland, MI
L5030 HSD
Guys, I am thinking of buying a new L5740 with a FEL, I can get either the HD bucket or the standard bucket with quick detatch system for the same price. Can anyone tell me if the HD bucket is worth it? I cant seem to find the specs on the HD compared to the Standard. Th:thanks!!:thumbsup:
/ Heavy Duty Vs. Standard Bucket #2
The HD bucket will cut your net lift capacity so best to have a good reason to have more than the standard bucket IMO. Standard buckets are pretty tough. I'd personally consider the HD only if a primary job was digging in rocky soil.
/ Heavy Duty Vs. Standard Bucket #3
I tend to agree with IslandTractor; bought mine used so I didn't have a choice. You will really have to try to damage a standard bucket and you can add reinforcement if needed.
/ Heavy Duty Vs. Standard Bucket #4
I also agree. The only advantage I see is for someone using the bucket hard on a day to day basis (like in a business) as the HD bucket has a bolt on replaceable cutting edge (were the standard bucket does not). For everyone else the std bucket should be fine and saves on weight as someone else mentioned. I think the Hd bucket is also smaller as I recall it was 66" vs 72" for the Std bucket.
Thanks a lot guys! Makes my decision easier!
/ Heavy Duty Vs. Standard Bucket #6
I bought my loader used and did not have a choice either. I got an LA724 for my L3940 with quick attach and heavy duty bucket. Heavy duty bucket is heavier, has same struck capacity, but has rounded back on the inside. Don't know if this rounded back is better or not. Check Barlow's, he has a few used loaders, that is where I got mine in great condidtion for about $1800 less than new, even came with all new brackets and grill guard. Philip.
/ Heavy Duty Vs. Standard Bucket #7
We have two tractors with standard buckets and one with HD and haven't bent or broken any of them and we are not gentle on equipment. We don't do rocks or concrete slabs which as mentioned would indicate the possible need of HD. I do like the replaceable cutting edge on my HD though.
I think you will really like the 5740.
/ Heavy Duty Vs. Standard Bucket #8
I have HD bucket, would certainly go that way for same price.
Mine has a very heavy rounded top where the chain hookd are attached....makes it CLEAR that there is no additonal support needed when welding chain hooks on.
I prefer the heavy duty bucket.
/ Heavy Duty Vs. Standard Bucket #9
I can't put the replaceable cutting edge on the standard square back bucket? The Kubota web site allows you to configure it that way and I was planning on getting it since I have rocky soil. :confused:
/ Heavy Duty Vs. Standard Bucket #10
rocky soil = need for toothbar on FEL bucket....
I'd strongly recommend a toothbar if you will be messing with rocks/rocky ground
/ Heavy Duty Vs. Standard Bucket #11
I believe someone on here drilled holes in their bucket and put a replaceable
edge on their bucket.
/ Heavy Duty Vs. Standard Bucket #12
My dealer prepared my stock standard bucket to accept a replaceable cutting edge.
/ Heavy Duty Vs. Standard Bucket #13
Depends on what you need to do with it. Seen too many non-HD easily beat up by careless operators. Especially digging in gravel / rocky NE soil or using them for lifting operations when curling with chains over the lip.
Both my FEL & BH have HD.
/ Heavy Duty Vs. Standard Bucket #14
I have twisted the standard duty bucket using a toothbar. I always get the HD bucket anymore but do not get the bolt on cutting edge. Very few folks here use their tractor enough to even come close to wearing the cutting edge of the bucket. I like the way the cutting edge of the bucket works versus the bolt on cutting edge with its protruding bolts. Do get a bolt on toothbar, they work great and are easy to put on/take off when needed.
/ Heavy Duty Vs. Standard Bucket #15
What about getting some sort of replaceable edge if I will be using either type of bucket for snow plowing/moving? I was wondering if they have a rubber edge that could be attached in the winter and then taken off after plowing season is done.
Shawn
/ Heavy Duty Vs. Standard Bucket #16
Would be very good to have the QA bucket - if what you mean is the new skidsteer type hookup - because they are the easiest to change and you could use skidsteer bucket which you would think would be more durable than tractor buckets - plus being able to change implement on loader arms so easy...
/ Heavy Duty Vs. Standard Bucket #17
Shawn
Shawn, if you want to use the bucket on asphalt or other hard surface, it is definitely worth while getting the bolt on cutting edge.
/ Heavy Duty Vs. Standard Bucket #18
I've ordered two of these heavy duty bolt on cutting edge's I believe from Messacks. One on a BX23 TLB and the photo is one on a B3200 TLB. Drill two holes, one on each side edge slips over existing bucket edge and tighten bolts.Real heavy duty and it works great.
DevilDog
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2014 Chevrolet Sonic Sedan (A61574)
2014 Chevrolet...
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
Colombo Twin Master (A64119)
Colombo Twin...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
