What trailer do I need?
/ What trailer do I need? #1
pitt_md
Pine Island, MN
Kubota MX5000
I am considering buying a trailer that I can use to haul my tractor/loader around on or haul some large square bales of hay 3 x 3 x 8' ~ 800 lbs. the tractor is a Kubota MX5000 4wd and weighs around 3700 lbs without the loader LA852. I am guessi9ng that the tractor loader weighs around 5000 lbs without any other attachments. It probably would not get used that much if that comes into consideration. I have a 08 F250 diesel to pull it. It needs to be a bumper pull.
I would like to do this as cheaply as possible and still be safe. Anyone have a recomendation on what I should be looking for?
Thanks for your time.
/ What trailer do I need? #2
I would go with a 20' tandem 12,000# GVWR trailer. The trailer will be around 3,500# empty so it will leave you plenty of capacity.
I would get brakes on both axles, low boy style, slide in ramps, and a wood deck.
As for cheap that is all where you live around here I can buy a trailer like this for about $3000 but I have a feeling you will pay 30% more.
Chris
You really think I will need that long of a trailer? I guess I need to measure how long my tractor is but i was hoping a 16' model would work. At any rate thanks for the advice.
/ What trailer do I need? #5
Trailer newbie here, but if you're going to be hauling hay bales, woudn't you want a deckover trailer? Around where I live it's HARD to find anyone who sells a 12,000 lb deckover trailer with 20 feet of actual flat deck (assuming you want a dovetail too).
I know they are out there, but just not real common. You may wind up going to a 14000 lb trailer which is heavier and more expensive than a 10 or 12K model.
/ What trailer do I need? #6
My 25 HP tractor with a FEK and any implement on the rear is 16' long. I have a 18' trailer and it can be tough to balance the load.
I would measure your rig then add at a minimum of 2'. I think you are going to find you will need a 20 or longer trailer.
Chris
/ What trailer do I need? #7
Axle placement has a big impact on how easy it is to get the load balanced.
Locally (Tyler, TX) we see a LOT of trailers of all types that have the axles WAY far back, which places a large tongue load on the towing vehicle.
I prefer to have the trailer axle(s) centered approximately 2/3 back based on OAL, that is hitch assembly to tail. Slight variations can accomodate specific loading needs but 50% of OAL is too far forward and 75% of OAL is generally too far rearward.
/ What trailer do I need? #8
Have a need for a trailer as well. Anyone have any recommendations for dealers around Kansas City?
Sorry for hijacking the thread.
/ What trailer do I need? #9
If I were in Kansas City I would save myself a ton of money and drive down the the Midwest trailer makers capital in southern MO. There are tons of manufactures around Sikeston, MO. I buy from Jerry James Trailers. No the best fit and finish but a lot of trailer for the money. I have sold about a dozen with not a single issue and I use mine atleast once a week for the last 7 years.
It would be a day trip out and back to get your trailer that any dealer in your area will probably be selling anyways. I saved nearly 1/3 the cost by going to pick up my personal trailer at the builders.
Welcome to Jerry James Trailers
Chris
/ What trailer do I need? #10
I have a 16' 10,000# flatbed. Too short for my TN55, too narrow (just --I like the width where it is) and too light duty (needs larger springs. Otherwise good trailer. 20'/12,000# is a good minimum.
My next trailer will likely be 22~24" deck over. Though I have no issues with the one I have now for unloading hay (buy forks).
/ What trailer do I need? #11
Why does it need to be bumper pull?
Your application is where a GN will really shine.
/ What trailer do I need? #12
TC33 with FEL on a 20' flat
youll want 20':thumbsup:
/ What trailer do I need? #14
My F250 is not setup for GN trailers.
Couple hundred bucks would fix that. Don't let that limit your choices in getting the right trailer for your needs.
And, nobody will ask to borrow it.
/ What trailer do I need? #16
Yeah I installed mine myself. That 4 inch hole in your bed is a little daunting, but otherwise no big deal. I also vote gooseneck.
/ What trailer do I need? #17
might check with Woodworth Mfg. near Chillicothe, MO, not going to be the cheapest trailer around, but you won't find better quality! They will build whatever you need.
My 8-1/2' x 16' Woodworth;
500BBL WHEELED FRAC TANK (A67714)
500BBL WHEELED...
2021 CATERPILLAR 420XE HRC BACKHOE (A65056)
2021 CATERPILLAR...
TIRE RACK WITH DIFFERENT SIZE TIRES/WHEELS (A67714)
TIRE RACK WITH...
2009 POLAR TANK . (A67714)
2009 POLAR TANK ...
1995 CHEVROLET KODIAK C7500(INOPERABLE) (A67714)
1995 CHEVROLET...
Unused 2021 Paladin QH1 3 Point Quick Hitch Tractor Attachment (A66734)
Unused 2021...
