Long 2610 wheel bolt torque
/ Long 2610 wheel bolt torque #1
dwilliams35
Member
I'm short one manual and kinda need this in a relative hurry: my boss's Long 2610 is snapping some wheel bolts,and we need to find out if anybody's got an actual torque spec for these lug bolts: The rears are 14mm x 1.5, the fronts are 12mm x 1.5.. Rears seem to all be grade 10.9, the fronts have 11.9 stamped on them, standard tapered-head lug bolt. Any help will be MUCH appreciated...
Thanks!
/ Long 2610 wheel bolt torque #2
Thanks!
These values are takened out of the 2610 op manuel. I also checked in the 680 op manuel which is same power train. Rear bolt torque is 190 ft. lbs. ( 258 Nm ). Front wheel bolts are 90 ft. lbs. ( 122 Nm). Check all bolt torque after one hour of operation, then once daily until they remain tight. Good luck- Trac
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
2015 Ram 1500 Pickup Truck (A61573)
2015 Ram 1500...
2011 BMW 5 Series 528i Sedan (A61574)
2011 BMW 5 Series...
213324 (A64279)
213324 (A64279)
APPROX. 2000 GALLON FUEL TANK (A63291)
APPROX. 2000...
2019 International LT625 Sleeper 48" (A62613)
2019 International...
