Interested in a Power Trac
/ Interested in a Power Trac #21
The newer 422s and 425s with Robin engines are rated for 20 degree slopes. My 425 is like the one Moss has with a Kohler CH25, and by putting larger displacement wheel motors on it, I can push those 25 degree limits even when the hydraulic oil is hot.
The 1430 with the Deutz is rated for 30 degrees -- that's the smallest that I'd consider for your 27 degree slopes.
My 2 cents, YMMV...
/ Interested in a Power Trac #22
reserve power is a good thing. fwiw, I'm impressed with the deutz diesels.
as for lack of manual, i actually have one for the 2445 but it is essentially a parts booklet with skinny information on maintenance. that said, you won't find a more responsive group that this one. if you ever have an issue, chances are someone has dealth with it and there is an easy to find thorough discussion thread about it or, if you pop a question you'll get a firehouse of suggestions from experienced users.
I talked to the factory, and all the 1400 series tractors are rated for 30 degrees when equipped with the wider turf tires.
I did notice that the 1800 series tractors have more power and less weight, so even if they are single wheel, they have an advantage on the hills.
BTW, the factory said that the conversion from duals to singles is no longer a five minute job. I guess the new design is much more difficult to convert.
The 90" mower interests me a lot though, because the factory said that it is very east to convert from a rough cut to a finish mower. This could prove extremely useful.
Thanks again for all your great replies.
/ Interested in a Power Trac #24
I cannot imagine there is any difference over the years in how the dualies are installed. PT is not prone to making changes. I think I have 8 or 10 lugnuts, You put the bucket down, lift up the front, slide a log under and lower the machine, Off come the back tires with an air wrench. 5 minutes if I am feeling NASCARish. Then pop it back up with the bucket, slide the log out and pull off the fronts. 10 minutes tops...
/ Interested in a Power Trac #25
The 422 i purchased has been the best piece of equipment for the price that i own. I had a problem with a pump and was sent another one asap. I removed the damaged pump and replaced it with the new one and sent the old one back. I am not a mechanic!
/ Interested in a Power Trac #26
I must agree with this statement. This is perhaps the best piece of powered equipment I have ever purchased, bar none. It never fails to get the job done. Now... if I can just learn to weld so I can build more attachments!
-Rob :)
/ Interested in a Power Trac #27
Boy Rob. You should NOT be afraid of the welding. Get on Craigslist and pick up an old Lincoln Tombstone welder for $100 (That is what I paid for my AC./DC).
For crappy welds that will hold, you are more than capable and it works for 90 percent of what you need for a farm.
I am going to build a grapple and a landscape rake this summer, and hopefully this fall try a post hole digger. If those work, I will save my money and build a stump grinder. And I do not know how to weld.
heck, you are really just down the street, why not swing by when I go back home and take spin on the 1850 and weld some metal for me ;-)
Carl
/ Interested in a Power Trac #28
Another machine that you may want to have a look at is the antonio carraro. IO have had the ttr440 for some time now and can use it on a 45 with major pukker factor. I comenly use it in the 35 range very comfortably. I just have the turfs on it . loaded in the rears.
/ Interested in a Power Trac #29
I think all of us that looked at a slope tractor drooled over the AC. Problem was the price point was completely unacceptable except to those who were running orchards and vineyards.
Beautiful tractor and bless you if you can afford one ;-)
/ Interested in a Power Trac #30
Carl
Hi Carl,
Thanks for the encouragement. If you're in SW Washington, you sure are right up the street. It would be fun to meet you.
-Rob :)
2019 John Deere R-4038 (A61306)
2019 John Deere...
TEST YOUR BID BUTTON! (A62129)
TEST YOUR BID...
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A61307)
Hobart Champion 16...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59575)
2021 KENWORTH T680...
2021 CATERPILLAR 300.9D MINI EXCAVATOR (A62129)
2021 CATERPILLAR...
1762 (A58375)
1762 (A58375)
