RachelV needs a tractor
/ RachelV needs a tractor #1
RachelV
Member
Ohio
Dont Have Yet, thats why I'm here. My Dad has a CRAFTSMAN LT1000 LAWN TRACTOR that I hate and is old. Its a 42" cut with and 16 HP. It takes all day to mow our yard.
I would like a Diesel and I dont want a Lawn tractor:thumbsup:, I want a bigger garden tractor or bigger Zero turn. I am sick of my dads Craftsman:mad: and want a Beastly Mower that will reduce my 2.2 acres to mere childs play, also I may use it to mow lawns since im doing that. I have 10000 to play with. Please let know what U recomend. I can get new or get a couple used ones to play with.
/ RachelV needs a tractor #2
with 10k, look at a used BX series Kubota or a 2210 JohnDeere. the X700 series is nice too.
/ RachelV needs a tractor #3
A ZTR would probably be the fastest machine for mowing, but you'd be limited to mowing.
If you have other tasks, Johndeere3720's suggestions point you in the right direction. Even a subCUT (such as Johndeere3720 suggested) would be somewhat quicker then your current mower as both the 2210 and BX2200 have larger mower decks.
well the nice man who lives next door is 57, has 15 acres. He has no family, his 1 son died in the gulf war and his wife left. So he lets me have the run of the place. I go get us loads of firewood the man has many bigger trees that have fallen and he just cuts it up with his chain and leaves it for me to come get when we need. we have really stressed that craftsman 1000. hehe. I will want a bigger cart though to handle more at a time. I have told my dad that were over working this mower, and he just says well it does it, dont it. Im like why should it have too. There are bigger machines available that are are made to do work. I would also maybe like to be able to get a snow blade for a bigger tractor, we have a big driveway and again a small snow blower that is doing to much.
/ RachelV needs a tractor #6
well i would say if you want to mow lawns, it's gonna be hard to beat a good ZTR mower over a tractor because of efficiency, turning, and ruts in the yard. Otherwise a BX kubota or maybe a 2305 JD, or a Massey GC2300 series.
One thing to consider is that a 23 hp gas motor and a 23 hp diesel motor will do the same amount of work, the diesel will just cost more to own and repair. If you just need a prime mover and a mower, i would get a cheap 4x4 ranger pickup thats on its last legs and a ZTR mower for mowing. That being said, I totally understand the desire to have a real tractor. The only reason I got a tractor was for the front end loader and back blade to maintian the driveway, bushhog for 6 acres or so, and do work around the yard. It was certainly an expensive luxury, I still use my riding mower for a lot of chores where the tractor is too big/heavy/fuel thirsty.
/ RachelV needs a tractor #7
Sounds like the BX series might work for you as well as the Deeres mentioned.
/ RachelV needs a tractor #8
I have a John Deere 2305 at one location and a BX2660 at another; my preference is for the Kubota, but either will work. In your price range you should be able to find a good used BX, John Deere or one of the other top brands.
I have to disagree with the gas being more or less equal to a diesel in performance and cheaper to own as after many years of owning both, my experience across the board has been just the opposite.
Im an only child, my mom gets after my dad for raising me more like a son than a daughter. I had electric trains that i ran and and i would load them up with a loader. I watched football with my dad and action movies. But I am what I am, and now I want big boys toys.:eek:
/ RachelV needs a tractor #10
If you are going to be mowing lawns for work, a ZT would beat a tractor any day.
/ RachelV needs a tractor #11
From what you are describing and what you want it, sounds like a BX with a FEL (front end loader) would more than suit your needs and then some. There are a lot of low hours BX tractors with FEL for less than $10K. Take the time to go to a few dealers and sit on and run some of the machines. If all you wanted to was cut grass on flat ground I would recommend a zero turn but if other chores are involved then a SCUT(sub compact utility tractor) is the ticket.
/ RachelV needs a tractor #12
If I had 10K I would look at a good ZTR. Do not buy one at a box store. Look for a Bad Boy, Scag, Ferris, ect. You can pick up a good used commercial grade one for the 6K range. I would use the rest to buy something like a Yanmar, Ford 661, ect for a tractor. You can then plow the snow with a $400 rear grader blade.
Chris
I like looking at all these Ideas. I dont have the experience U men have with different brands and there are so many.
/ RachelV needs a tractor #14
Hauling a larger cart is not a good job for a ZTR although they are fast mowers. I'm not sure about the snow in Ohio, but that is a consideration too. Tougher tractors than yours start at something like the Simplicity Pestiege, the John Deere X5xx series, and some of the Cub Cadets. Diesel tractors in your price range start at the Kubota BX 1860, and that might be a good one to look at. It is a much tougher tractor than the others mentioned, and not much more money, and is less than the top of the line JD, or Simplicity garden tractors. It is also the smallest, and least expensive tractor really suited to a front end loader. Beyond that price wise are the larger BX series, the John Deere 2305, the Massey GC 2400 series, and possibly the smallest Mahindra. Used tractors are always an option, but sometimes take more experience to sort out. Good to have you with us, and good luck with your search!
We can get terrible snow storms. And when we do it can leave U wishing U had been to the store. hehe. I have a truck with 4x4. I dont want to put a blade on it. Its my baby hehe. It goes through snow good but U really need to clean your drive if U want to be able to go anywhere.
/ RachelV needs a tractor #16
Looking thru the posts, need more info.
How big is the drive that needs plowing?
How much mowing outside the 2 acres do you do?
How difficult is the access to the wood you gather?
So far I see:
Mow 2 acres
plow unknown drive
Gather wood
From that limited info, I would look at a BX or B series(or other brand equivilant). A mid mount mower, and rear blade would mow and plow. A little utility trailer would be esy to tow.
I would add though, that you would be amamzed the things you could do with a loader; gather wood, plow/scoop snow, move mulch, move dirt, carry tools, carry posts ect ect. With the quick attach versions, makes the tractor easy to mow with too.
I would sit down, and try to list out the things you want to do, and how much of that work there is. And, if you will have to transport whatever you get.
The other thing is, look at local rental places. It will probably cost $150 or more, but rent a tractor for a day, and go do some of the tasks on your list. That will give you a good real life idea of what you may want more of, or may not really need. $150 rental is a small investment compared to $10,000 for something that did not fit the bill after all.
/ RachelV needs a tractor #17
I can say Ohio is a pretty state after having been there a few times. Not much in the way of Mountains when you are used to volcanoes all around me. :thumbsup:
I applaud you for what you want to do and your ambition. I am raising my daughter. She knows how to drive the tractor and run chainsaws as well as my chipper. She still likes to be a young lady when she can.
What you might consider is renting a tractor or ZTR if you can and try them out. With the amount of snow you folks can get I would think the compromise of a tractor with a Middle mower would be something to look into.
At least that's my 2cents worth of advice.
We can fit 10 cars on drive easy. and still have a bit of room to shoot baskets. I hope to be having my own lawn bussiness, so I guess allot outside of my house. I also my neighbors when he is sick or having health issues which is another 2 acres of the 15, the rest is wooded.
He has a Tractor trail that goes back in woods. Its nice for a a tractor. Im sure U could fit a truck in there but I wouldnt take mine in it. The branches would scratch it up.
/ RachelV needs a tractor #20
That is not so big; I wondered about 1 1/4 mile drive or something :eek:
I work for the company that probably makes the CPU in your PC. At this facility, they have a Kubota BX series and mid-mount mower. They mow probably 5 acres. ~1/2 that is weekly.
One thing about a SCUT like that though, you will not want to take it out in the woods with the mid-mower on it, I wouldn't think.
I would still, look at a loader. They come off very easy for mowing, back on very easy for other work.
Is your truck a 1500 series or 2500 series? Does it have the tow package?
As you think about the tractor, remember there will be $1500+ for a trailer, chains, binders ect. Factor that in to your budget too.
(4) Trail Finder S2 215/75R/17 Tires and Rims (A64047)
(4) Trail Finder...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
2013 FREIGHTLINER M2 112 S/A 4X2 DAY CAB TRUCK TRACTOR (A59910)
2013 FREIGHTLINER...
Bobcat T650 Compact Track Loader (A64047)
Bobcat T650...
Like New! Low Hours! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Low...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
