Starter Solenoid throwing sparks
/ Starter Solenoid throwing sparks #1
LaytonAg
Member
When I tried to start my YM2310 on Saturday I noticed sparks from the engine compartment. So, I opened the hood and observed while I had my son try to start the tractor. I saw sparks coming from 1 of the two large lugs on the end of the starter solenoid. I tried to start it again and just get a loud clicking sound when I turn the key all the way over. What do the sparks mean? Has anyone experienced this? Thanks.
/ Starter Solenoid throwing sparks #2
Did you check the connections at the solenoid to see if they were tight? sounds like a loose connection. The clicking sound is the solenoid trying to engage but not getting enough current.
/ Starter Solenoid throwing sparks #3
I would go ahead and remove and clean the connections just to make sure you have a good clean ones. Just because you tighten them up does not mean you have a good connection. I woud also check and clean if needed my battery and the ground to the tractor while I was at it.
Carey
/ Starter Solenoid throwing sparks #4
Sounds like battery is about shot.
/ Starter Solenoid throwing sparks #5
Carey
Sound advice. Troubleshooting any electrical problem needs a good starting point and that is how you get there.
/ Starter Solenoid throwing sparks #6
it is either loose connections on the starter terminals or the contacts in the cap are arcing out due to a bad contact
Thanks to all for the strategies for solving. I took the connectors off of the solenoid and cleaned them up with a little steel wool and tightened them up good and the tractor started right up.
